Thread: Knocking rear suspension after lowering
  1. Knocking rear suspension after lowering
    North Yorkshire
    Hello, I've just finnished fitting my new jamex springs and they look great. However when going over bumps now the rear knocks.
    I then jacked the wheel up and when you lift the wheel and drop it again it knocks loudly and im not quite sure why, it was totally fine before lowering. Any suggestions?
  2. Re: Knocking rear suspension after lowering
    Apr 2007
    Suffolk
    If someone lowered it for you take it back, If you did it yourself you should get it up on a 4 post car lift like the ones used for the MOT and bounce it up and down to see where its coming from.
  3. Re: Knocking rear suspension after lowering
    May 2008
    I fitted jamex springs and ive got the same problem with knocking. im hoping its somthing todo with using standard shocks!
  4. Re: Knocking rear suspension after lowering
    Frazzly Guest
    When I put my suspension kit in I missed the really small washers which sat on the split o ring on the damper. It knocked badly after that.
    Also It could be your old shocks are not very happy running with lowering springs.
    Fraz
  1. lowering suspension
    By audi90-2.3 in forum 80 - 90
    Last Post: 17-03-2008, 12:39 AM
  2. suspension knocking
    By simonvw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-01-2008, 10:38 PM
  3. Suspension knocking!!!
    By SRA4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-06-2007, 09:11 PM
  4. Suspension Knocking (Bora)
    By Lord Nelson in forum Bora - 1998 - 2005
    Last Post: 21-05-2007, 01:11 PM
  5. Knocking suspension and clicking....
    By kezbo in forum Audi A3 - Archive Topics
    Last Post: 28-02-2007, 11:13 PM
