Thread: multifit wheels
  1. multifit wheels
    Edinburgh
    Hi folks, can someone enlighten me as to how the multifit system works, I took my alloy off yesterday but can't get my steel wheel to fit, do I have yo remove the alloy spacer or what ?????
    thanks, jim
  2. Re: multifit wheels
    Tyldesley, Manchester, UK
    Never used "multifit" before, but I assume the wheel is not the same PCD as your car so an adaptor is fitted. If this is the case then this "spacer" probably needs removing as the PCD is different from your VW.
    One German, Two Italian.
  3. Re: multifit wheels
    Edinburgh
    Hi and thanks for your response, like you i don't really know what multifit wheels are but I assume you are right i'll give it a try when it stops raining, cheers Jim
  4. Re: multifit wheels
    Dec 2006
    Manchester
    Multi-fit wheels are quite simple..... most commonly for 4 or 5 stud vehicles....
    eg, a 5 stud vehicle pcd 5 x 100.....
    The multi fit wheel will have 10 holes in it.... 5 x100 and maybe 5 x 112 (or something similar)...
    It just means the wheels will fit most types of car with 5 studs....
    Hope that makes sense?
    Nick
    example
    1.9 tdi PD 100 Bora
    110cc pitbike, 4 speed semi-auto
    110cc Off road buggy, 4 speed semi-auto
  5. Re: multifit wheels
    Edinburgh
    Thanks Bora(ing) I suspect i've not got multifit wheelsas only five stud holes it seems the spacer is probably for the alloys which are fitted - vw 15 " Highline model, thanks again, Jim
  1. new wheels
    By pablo287 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-10-2007, 10:06 AM
  2. Wheels
    By carrera2s in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-10-2007, 04:51 PM
  3. RS4 Wheels
    By Grinning Giant in forum Audi A4 - Archive Topics
    Last Post: 25-04-2007, 12:50 AM
  4. Need Some Wheels Man!!
    By M4YTY in forum Passat - Archive Topics
    Last Post: 26-02-2007, 11:20 PM
  5. a6 Wheels
    By trickya6 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 20-01-2007, 05:07 PM
