Thread: Golf Mk3 Gl Stereo Wiring
  1. Cool Golf Mk3 Gl Stereo Wiring
    Recently bought a mk3 GL and the previous owner had a cd player fitted,but it used bullet connectors, so it doesn't have the ISO box any more, they took the cd player out and i have a panasonic cassete player to fit in which would be simple if i knew what the wires were coming out from the dash, ive looked for a few diagrams but the colors dont match up i was wondering if anyone knew which wire was which or had a simple diagram of the wires
    thanks
  2. Re: Golf Mk3 Gl Stereo Wiring
    Hi everyone, I too have the same problem, my wiring harness has been cut off by a previous owner, now im trying to connect my iso connector wires but dont have a clue which wire is which on the cars wiring loom.
    Can anyone list me which wires I need to use i.e. brown = live, red/white = illumination etc..
    All help greatly appreciated!
    Matt
  3. Re: Golf Mk3 Gl Stereo Wiring
    ....Surely someone must know! Im getting thirsty for information here!
  4. Smile Re: Golf Mk3 Gl Stereo Wiring
    Near Blackpool
    48 Post(s)
    Quote Originally Posted by racingdrivermat View Post
    Its really pretty simple, i have installed many stero systems to a car which has had its ISO Cut, the earth wire is usually the thickest, usually brown/black, to prove this either use a multimeter with the "beep" function hold one stick to unpainted metal on the car and one stick to the wire if it bleeps then thats the earth, move on to the next wire, obviously atleast 8 wires will be speaker cables, so they should be grouped togeather and then wait till the end to wire them up, usually the speaker cables for example will be "Front Left, + Orange with Black Stripes, and -Orange" if you find eight wires like this then pull them to one side, there should be a posative and a ignition posative, with ignition off connect one peg of your multimeter to unpainted metal on the car, then the other on the suspected wire, if there is a voltage then you have a + wire, turn your ignition off and see if the voltage fails then you have an ignition + and if it stays you have your "memory possative", also there should be a Lights possative, then the lights are switched on another + wire will become live, this is to tell the radio to dim its lights so not to dazzle you whilst driving. you then should have your pssatives and negative, there will be an aerial which is obvious (sometimes you will need an adaptor to convert your aerial plug to the new male connector). I know my terminology is rubbish but i am trying to help the best i can, the speakers are easy to sort out, once you have determined your wires for power, then you should have 8 wires left, group them up into 2's you can group them up by using the radio which has its power wired up then keep pressing two wires on to the radios output till you have audio, then you can determin which speaker comes on. set the balance on your radio to full left and then the fader to full front, so only the front left speaker will work, keep trying your speaker wires till the front left speaker comes on, you do thill then to the front left, and then the back ect, this should then be wired up correctly, sorry if i have rambeled but if you get the gist from this then you should be ok!
  5. Re: Golf Mk3 Gl Stereo Wiring
    thats fantastic info! really helpe do the trick! I cant thank you enough, good man!
  1. 96 Cordoba Stereo Wiring.
    By blacklight in forum Ibiza - Cordoba
    Last Post: 20-10-2007, 12:00 AM
  2. stereo wiring harness
    By otis_b in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-09-2007, 02:20 PM
  3. 1967 Beetle stereo wiring.
    By paulm270582 in forum The Classic VW's
    Last Post: 06-08-2007, 01:00 PM
  4. audi a4 1997 stereo wiring help
    By brettcurran in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-07-2007, 10:10 PM
  5. 80 sport stereo wiring
    By Ian W in forum 80 - 90
    Last Post: 18-04-2007, 04:08 PM
