Thread: A4 1.8t Part in my engine glowing red. any ideas??
  1. Angry A4 1.8t Part in my engine glowing red. any ideas??
    Hi There,
    I just had the oil pump replaced and the oil line to the turbo as the boost wasn't kicking in. all driving well and when I got home tonight, I just had a look to see if everything was well. See photo attached, the circled part was glowing red in the dark. I think this is a part of the manifold/turbo, but I'm not sure... does anybody know if this is normal or what.. please help and I won't start it untill you advise me.. Thanks for all your previous advise..
    SPM
  2. Re: A4 1.8t Part in my engine glowing red. any ideas??
    May 2007
    knee deep in clunge
    14 Post(s)
    Thats the turbo and exhaust manifold which will glow a bit as there is a lot of heat developed hence oil and water flow through the turbo to reduce heat.
  3. Re: A4 1.8t Part in my engine glowing red. any ideas??
    Thanks for that, Never looked at before, so I kinda freaked out, visions of it going on fire etc...
    once again... this site has saved me buckets of cash and sleeples nights...
  4. Re: A4 1.8t Part in my engine glowing red. any ideas??
    Is there any way of checking if the coolant is getting through the turbo???
  5. Re: A4 1.8t Part in my engine glowing red. any ideas??
    There is really nothing which can stop water circulating through the turbo,if the engine temp,is ok, then the water is circulating You will be able to feel the differance of temperature on the inlet and return water pipes on the turbo be carefull they are hot
  6. Re: A4 1.8t Part in my engine glowing red. any ideas??
    Thanks again bud...
    SPM
  1. Engine part
    By adhussain in forum Chat - Anything with wheels
    Last Post: 01-11-2007, 10:37 PM
  2. 1998 Leaking Issue. Part Cause and Part Fix
    By 1998FTW in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-06-2007, 03:10 PM
  3. A6 Handbrake Light glowing with engine off
    By lcs in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 10-03-2007, 04:58 PM
  4. VW Cat Convertor Glowing Bright Red
    By DieselTrader in forum Archive posts
    Last Post: 11-10-2006, 11:45 PM
