Thread: Particulate Filter Regeneration Duration Bank 1 - code P245800
  1. Particulate Filter Regeneration Duration Bank 1 - code P245800
    May 2007
    A colleague of mine with a Q5 had a DPF regen problem today and I happened to have my OBDeleven in the car, and the error logged was Particulate Filter Regeneration Duration Bank 1 - code P245800. I have reset the error. I've never owned a diesel myself so I just wanted a quick steer on what the best way forward is? The car tends to do local trips which won't be helping, so regens quite frequently I gather - and I assume the error means it's pretty clagged up and taking too long to do it's thing. I've suggested a really good long run might help but I'm not sure if this will be enough to stop the error coming back. Any thoughts appreciated. Thanks!
  2. Re: Particulate Filter Regeneration Duration Bank 1 - code P245800
    129 Post(s)
    1972 Post(s)
    You need to look at the DPF soot and ash loading figures. It will probaly need a service regeneration whilst standing, I don't know if OBD11 and do this.
  3. Re: Particulate Filter Regeneration Duration Bank 1 - code P245800
    May 2007
    Thanks Crasher - mine is OBDeleven Pro which I bought before I got VCDS. I've found posts that suggest it might be able to, so I'll look into that. Do you happen to know if VCDS will do it without using up a VIN (I've a Hex-V2 with a three VIN licence and they are all spoken for!).
  4. Re: Particulate Filter Regeneration Duration Bank 1 - code P245800
    129 Post(s)
    1972 Post(s)
    I have never used a VIN based HEX-NET, I would have used three VIN's today and we kept it quiet today with people off.
  5. Re: Particulate Filter Regeneration Duration Bank 1 - code P245800
    May 2007
    Thanks Crasher - I'll give it a go and see what it can do.
  1. Particulate Trap Bank 1 P2002 00 [237] - Efficiency Below Threshold
    By gareth23 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-09-2023, 10:34 AM
  2. Please Help. A6 error 19226 Particulate trap bank 1
    By cip82 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 23-04-2022, 12:47 PM
  3. 009263 - Diesel Particulate Filter (Bank 1) Location
    By dean warren in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-12-2019, 06:41 PM
  4. Please Help Fault Code P2454 - Diesel Particulate Filter Differential Pressure Sensor
    By TonyMc06 in forum Polo - Derby - Lupo - Fox
    Last Post: 18-06-2016, 07:14 PM
  5. Regeneration of Diesel Particulate Filter
    By Arcady in forum Golf MK5 - 2004 - 2009
    Last Post: 05-08-2009, 10:10 AM
