Thread: Adblue fault error + Engine light
  1. Adblue fault error + Engine light
    Apr 2024
    London
    Hey guys - my adblue levels went really low and at around 500 miles left, I pumped in adblue.
    Since then - had an Adblue Fault appear intermittently and more recently an engine light kept popping up.
    Here’s the codes I got:
    5 Faults Found
    5461 - Ignition Switch; ON Position
    P2533 00 [096] - Short to Plus
    Intermittent - Not Confirmed - Tested Since Memory Clear
    9645 - Reductant
    P20E8 00 [104] - Pressure too Low
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 5
    Mileage: 116929 km
    Date: 2024.02.17
    Time: 22:52:38
    Engine RPM: 833.50 /min
    Normed load value: 25.9 %
    Vehicle speed: 0 km/h
    Coolant temperature: 64 °C
    Intake air temperature: 17 °C
    Ambient air pressure: 1010 mbar
    Voltage terminal 30: 14.600 V
    Unlearning counter according OBD: 6
    Outside temperature: 11.0 °C
    Pressure sensor for reducing agent: measured pressure: -120 hPa
    Pump for reducing agent: speed: 2988.0 /min
    Sensor for reducing agent tank temperature: temperature: 13.2 °C
    Reducing agent pump: activation: 50.00 %
    Sensor for reducing agent fill level: fill level height: 47 mm
    Sensor 2 for temp. reducing agent: act. value: 12.5 °C
    11393 - Reductant Pressure Sensor Circuit
    P204B 00 [175] - Implausible Signal
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame
    Fault Priority: 2
    Fault Frequency: 14
    Mileage: 114903 km
    Date: 2023.11.09
    Time: 14:45:26
    Engine RPM: 1223.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 28 km/h
    Coolant temperature: 18 °C
    Intake air temperature: 9 °C
    Voltage terminal 30: 14.660 V
    Unlearning counter according OBD: 40
    Outside temperature: 8.5 °C
    Pressure sensor for reducing agent: measured pressure: -489 hPa
    Pump for reducing agent: speed: 0.0 /min
    Sensor for reducing agent tank temperature: temperature: 7.5 °C
    Reducing agent pump: activation: 0.00 %
    Sensor for reducing agent fill level: fill level height: 86 mm
    Sensor 2 for temp. reducing agent: act. value: 7.0 °C
    9643 - Reductant
    Freeze Frame
    Fault Priority: 2
    Fault Frequency: 10
    Mileage: 116919 km
    Date: 2024.02.17
    Time: 20:33:52
    Engine RPM: 1134.00 /min
    Normed load value: 67.8 %
    Vehicle speed: 83 km/h
    Coolant temperature: 93 °C
    Intake air temperature: 13 °C
    Ambient air pressure: 1020 mbar
    Voltage terminal 30: 14.640 V
    Outside temperature: 12.5 °C
    Pressure sensor for reducing agent: measured pressure: -144 hPa
    Pump for reducing agent: speed: 2960.0 /min
    Sensor for reducing agent tank temperature: temperature: 21.0 °C
    Sensor for reducing agent fill level: fill level height: 49 mm
    Sensor 2 for temp. reducing agent: act. value: 17.0 °C
    23765 - Control unit for information electronics 1
    U1054 00 [032] - No Communication
    [Information electronics control module 1No Communication]
    Readiness: 1 3 0 0 0
    It’s a 2016 Q7 3.0 diesel.
    Any ideas?
  2. Re: Adblue fault error + Engine light
    Mar 2016
    KEnt
    22 Post(s)
    Was wondering if you overfilled it? Did that on mine and had to siphon some out in the end
    Sent from my SM-S908B using Tapatalk
  3. Re: Adblue fault error + Engine light
    Apr 2024
    London
    Oh dear…is that even a thing!? :O might have to wrap it in bubble wrap next time
  4. Re: Adblue fault error + Engine light
    Mar 2016
    KEnt
    22 Post(s)
    Think it's too things
    1: you need to fill with a minimum of 5litres
    2: if you overfilled apparently can impact the starting if the car.
    I Def overfilled mine and siphoned it out with plastic tubing and syringe
  5. Re: Adblue fault error + Engine light
    130 Post(s)
    1972 Post(s)
    You will need the tank with pump and controller plus engine ECU software update. You can see the pump pressure sensor has failed in the freeze frame data, spinning at 3k rpm and producing half a Bar pressure. If you keep running it the ECU will overdose the system and fill the entire exhaust system with AdBlue crystals and they are a nightmare to get out. I have a pile of these tanks in various VAG versions sitting outside as the bin men won't take them. If you find cement like grit appearing in the tailpipes, stop driving but it may be too late by then.
  1. Q74m 2016 crt engine oil and coolant leak plus adblue intermittent fault
    By luckyjimbo in forum Q7 - 4M Forum - 2016 -
    Last Post: 08-03-2023, 11:24 AM
  2. Adblue error (again!)
    By Iainbluk in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 01-12-2021, 09:23 PM
  3. Audi A5 Adblue / ECU error?
    By kiranpithwa in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 08-10-2021, 11:40 AM
  4. AdBlue: error
    By wardienet in forum Q7 - 4M Forum - 2016 -
    Last Post: 13-06-2018, 11:58 AM
  5. Q7 adblue error.
    By Spuff in forum New Member Introductions
    Last Post: 05-08-2016, 07:02 PM
