Thread: Audi A5 2.0 cr tdi, Non start, No Codes
  1. Audi A5 2.0 cr tdi, Non start, No Codes
    Dec 2021
    essex
    HI all,
    friends Audi a5 died the other day leaving him stranded on the M25.
    symptoms were major vibrations then it just died.
    he got it recovered home and i then popped rounf to scan it.
    no codes showed, so i went to start it and it would crank but not fire.
    at this point i checked the injector variance, and noticed injector 2 was massively difference to the rest.
    See below
    Address 01: Engine (03L 906 018 JG)
    10:02:02
    IDE01387 Injector 1: rail pressure calibration point 1 0.00 µs
    IDE01388 Injector 1: rail pressure calibration point 2 0.00 µs
    IDE01389 Injector 1: rail pressure calibration point 3 0.45 µs
    IDE01390 Injector 2: rail pressure calibration point 1 1.20 µs
    IDE01391 Injector 2: rail pressure calibration point 2 -17.60 µs
    IDE01392 Injector 2: rail pressure calibration point 3 -13.90 µs
    IDE01393 Injector 3: rail pressure calibration point 1 2.85 µs
    IDE01394 Injector 3: rail pressure calibration point 2 0.60 µs
    IDE01395 Injector 3: rail pressure calibration point 3 -0.95 µs
    IDE01396 Injector 4: rail pressure calibration point 1 0.00 µs
    IDE01397 Injector 4: rail pressure calibration point 2 0.00 µs
    IDE01398 Injector 4: rail pressure calibration point 3 0.00 µs
    feeling fairly confident that injector 2 was faulty, purchased a new one and fitted it.
    coded it, went to start the car and nothing!
    again it cranks but will not start.
    11:40:32
    IDE00475 Fuel Pressure Regulator Valve 44.59 %
    IDE00476 Fuel Metering Valve 29.14 %
    IDE00589 Fuel pressure 11950 kPa rel
    IDE01392 Injector 2: rail pressure calibration point 3 0.00 µs
    Fuel is getting to the injectors, i have not yet checked the bowl on the HPFP (next to do).
    But wondered if anything else would stop it starting.
    i can confirm crankshaft sensor registers rpm when cranking, Fuel pressure rises.
    Anyone else had this ? as i suspect it is not unique to this car.
    Regards jim.
  2. Re: Audi A5 2.0 cr tdi, Non start, No Codes
    131 Post(s)
    1973 Post(s)
    Does it fire up with a sniff of brake cleaner?
  3. Re: Audi A5 2.0 cr tdi, Non start, No Codes
    Dec 2021
    essex
    Shall be checking this tonight now i have some.
    also looking to check for blocked filter or failed pump after i have given it some squirt to see if it fires.
  4. Re: Audi A5 2.0 cr tdi, Non start, No Codes
    131 Post(s)
    1973 Post(s)
    Be very sparing with the sniff and have a hand on the key to shut the V157 flap if the engines goes ballistic… serious brown trousers time.
  1. Please Help ESP light on.... no codes, struggled to start earlier :(
    By Jennie55 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 26-11-2012, 01:28 PM
  2. car wont start and no fault codes
    By mav84 in forum Golf MK5 - 2004 - 2009
    Last Post: 09-01-2012, 09:56 AM
  3. tdi codes hard to start
    By roboman in forum Golf MK3 - 1993 - 1999
    Last Post: 13-10-2010, 12:11 PM
  4. no codes displayed car will not start
    By mr rugby in forum VCDS - General Questions
    Last Post: 01-12-2008, 10:18 PM
  5. Please Help Whistle on cold start + codes
    By Cornish_Richie in forum Golf MK4 - 1999 - 2004
    Last Post: 28-09-2008, 06:38 PM
