Dear VW-users,
I am in a need of help with deciding what should be done about the below DTC errors that had already popped up 2 times for my Passat 2.0. TDI Variant 2019 (pre-lift).
What happened:
at some point when I started the engine, I got several control lights and info like: Front assist failure, ESP failure, Tire pressure check, park assist failure, failure: road signs recognition. Total of 7 errors. I connected my OBD and scaned for DTCs - the result can be found below. I cleared the errors twice and it was ok. THen couple of days later I received the same set while driving slowly through quite mesy and bumpy road - again: cleared the DTCs and it is working.
Background:
The car was hit in front right wheel and got replaced bumper, wheel with its whole column, some electric stuff and other items including steering wheel column too. I replaced the battery too after I got it a year ago and till now it was running flawlessly.
Right now it is working again, but I want to be prepared what to do if the errors wil continue to appear - what to be prepared for and what to check when they happen. Can you please help?
Car Scaner DTC list:
Code:
Car Scanner ELM OBD2DTC report
Selected brand: Volkswagen
============1==============
17158
Raw code: 004306
ECU: 01. Engine Control Unit
Status: Pending, Test failed since last error reset
U041600: Invalid Data Received From Vehicle Dynamics Control Module
U112300: Databus error value received
============2==============
07150
Raw code: 001BEE
U042800: Invalid Data Received From Steering Angle Sensor Module
============3==============
17158
Raw code: 004306
Status Bits: 1
Priority: 6
Frequency: 1
Index: 255
Odometer: 137750 km
Date, time: 2024.02.25 15:41:55
Engine RPM: 951 rpm
Calculated Engine Load Value: 21.18%
Vehicle Speed: 13 km/h
Coolant Temperature: 90 ℃
Engine Oil Temperature: 63 ℃
Barometric Pressure: 99 kPa
Klemme 30 Voltage: 13
Parametric Values: 20 96 28 17 E0 00 00 17 DD 04 17 DE 00 00 11 87 FF DC
============4==============
07150
Raw code: 001BEE
Status Bits: 1
Priority: 6
Frequency: 1
Index: 255
Odometer: 137750 km
Date, time: 2024.02.25 15:41:56
Engine RPM: 947 rpm
Vehicle Speed: 12 km/h
Parametric Values: 20 96 28 10 60 00 17 E2 07
============5==============
5262624
Raw code: 504D20
ECU: 04. Power Steering [Archive (inactive)]
Status: Confirmed
B202000: Function limitation through missing initialization
============6==============
5262624
Raw code: 504D20
Status: Confirmed
Status Bits: 1
Priority: 4
Frequency: 1
Index: 214
Odometer: 137750 km
Parametric Values: 54 34 70 51 00 00 21 93 24 04 40 01 40 00 03 00 15 00 06 FF 7C 02 C7 05 31 00 00 00
============7==============
13679372
Raw code: D0BB0C
ECU: 10. Parking Assistant 2 [Archive (inactive)]
Status: Confirmed
Read Steering Assistance Control Unit-J500 - LWI_01.LWI_Steering Angle - Read error memory
============8==============
13637426
Raw code: D01732
Status: Confirmed
ESP - ESP_21.ESP_Systemstatus - Read error memory
============9==============
13679386
Raw code: D0BB1A
Status: Confirmed
Read Steering Assistance Control Unit-J500 - LH_EPS_03. EPS_Calculated_Steering Angle - Read error memory
============10==============
13679372
Raw code: D0BB0C
Status: Confirmed
Status Bits: 1
Priority: 6
Frequency: 1
Index: 253
Odometer: 137750 km
============11==============
13637426
Raw code: D01732
Status: Confirmed
Status Bits: 1
Priority: 6
Frequency: 1
Index: 253
Odometer: 137750 km
============12==============
13679386
Raw code: D0BB1A
Status: Confirmed
Status Bits: 1
Priority: 6
Frequency: 1
Index: 253
Odometer: 137750 km
============13==============
02052
Raw code: 000804
ECU: 13. Active Cruise Control [Archive (inactive)]
Status: Confirmed
FAULT_ALP_STEERINGWHEEL_FAIL
============14==============
00795
Raw code: 00031B
Status: Confirmed
FAULT_APS_RELEVANT_ERROR
============15==============
00803
Raw code: 000323
Status: Confirmed
FAULT_BV1_FEHLER
============16==============
02101
Raw code: 000835
Status: Confirmed
FAULT_ESP_STATUS_SYSTEM
============17==============
00928
Raw code: 0003A0
Status: Test failed, Confirmed
U112200: Databus implausible message
FAULT_STOPPING_DISTANCE_CONTROL_NOT_AVAILABLE
============18==============
02068
Raw code: 000814
Status: Confirmed
FAULT_TSK_IRREV_FAIL
============19==============
02052
Raw code: 000804
Status: Confirmed
Status Bits: 1
Priority: 4
Frequency: 1
Index: 253
Odometer: 137750 km
Parametric Values: 02 8D 4C 02 85 82 10 11 03 9D 10 12 FF EB 10 2E 02
============20==============
00795
Raw code: 00031B
Status: Confirmed
Status Bits: 1
Priority: 4
Frequency: 1
Index: 253
Odometer: 137750 km
Parametric Values: 02 8D 4C 02 85 81 10 11 03 88 10 12 FF B6 10 2E 07
============21==============
00803
Raw code: 000323
Status: Confirmed
FAULT_BV1_FEHLER
Status Bits: 1
Priority: 4
Frequency: 1
Index: 253
Odometer: 137750 km
Parametric Values: 02 8D 4C 02 85 82 10 11 03 85 10 12 FE 8E 10 2E 07
============22==============
02101
Raw code: 000835
Status: Confirmed
Status Bits: 1
Priority: 4
Frequency: 1
Index: 253
Odometer: 137750 km
Parametric Values: 02 8D 4C 02 85 80 10 11 03 9B 10 12 FF A0 10 2E 02
============23==============
00928
Raw code: 0003A0
Status Bits: 1
Priority: 6
Frequency: 1
Index: 213
Odometer: 137751 km
Date, time: 2024.02.25 15:57:39
Parametric Values: 02 8D 4A 02 85 79 10 11 00 00 10 12 00 00 10 2E 02
============24==============
02068
Raw code: 000814
Status: Confirmed
Status Bits: 1
Priority: 6
Frequency: 1
Index: 253
Odometer: 137750 km
Parametric Values: 02 8D 4C 02 85 82 10 11 03 99 10 12 FF 83 10 2E 06
============25==============
5262624
Raw code: 504D20
ECU: 44. Power Steering [Archive (inactive)]
Status: Confirmed
============26==============
5262624
Raw code: 504D20
Status: Confirmed
Status Bits: 1
Priority: 4
Frequency: 1
Index: 214
Odometer: 137750 km
============27==============
01555
Raw code: 000613
ECU: 5F. Electronic Information System 1
B201A00: Checking software version management
Software version management check
Check software version management
============28==============
01555
Raw code: 000613
Status Bits: 1
Priority: 6
Frequency: 4
Index: 213
Odometer: 137593 km
Date, time: 2024.02.22 18:20:46
Parametric Values: 02 86 7A 10 02 4D 44 55 56 36 32 34 2F 4D 61 69 6E 20 20 20 20
============29==============
13679372
Raw code: D0BB0C
ECU: 76. Parking Assistant [Archive (inactive)]
Status: Confirmed
============30==============
13637426
Raw code: D01732
Status: Confirmed
============31==============
13679386
Raw code: D0BB1A
Status: Confirmed
============32==============
13679372
Raw code: D0BB0C
Status: Confirmed
Status Bits: 1
Priority: 6
Frequency: 1
Index: 253
Odometer: 137750 km
============33==============
13637426
Raw code: D01732
Status: Confirmed
Status Bits: 1
Priority: 6
Frequency: 1
Index: 253
Odometer: 137750 km
============34==============
13679386
Raw code: D0BB1A
Status: Confirmed
Status Bits: 1
Priority: 6
Frequency: 1
Index: 253
Odometer: 137750 km
============35==============
1123173
Raw code: 112365
ECU: A5. Front Assistant A5 (UDS) [Archive (inactive)]
Status: Confirmed
ESP_21_ESP_Systemstatus
============36==============
1123080
Raw code: 112308
Status: Confirmed
LWI_01_LWI_QBit_Steering Angle
============37==============
1123173
Raw code: 112365
Status: Confirmed
Status Bits: 1
Priority: 6
Frequency: 1
Index: 253
Odometer: 137750 km
============38==============
1123080
Raw code: 112308
Status: Confirmed
Status Bits: 1
Priority: 6
Frequency: 1
Index: 253
Odometer: 137750 km
