Thread: P2011 fault code help please
  1. P2011 fault code help please
    Feb 2024
    Hampshire, UK
    Hello all, after some advice please with my 57 plate Q7
    starts and runs fine when cold but once warm engine note changes/runs rough and then cuts out and won’t re-start until cold. I’ve a basic code reader that brings up fault code P2011
    ive done a bit of research and found it may relate to swirl flaps?
    what I can’t understand is why it’s fine when cold but with in 10mins of running on the drive it starts running rough and dies?
    Any help or advice would be appreciated
  2. Re: P2011 fault code help please
    130 Post(s)
    1972 Post(s)
    I can’t see that cutting the engine out, sounds more like crank speed sensor which often doesn’t come up as a fault code so you have to monitor the value as the engine cuts.
  3. Re: P2011 fault code help please
    Feb 2024
    Hampshire, UK
    thanks for replying. I’ll plug it back in and see if there’s any other fault codes.
    strange it runs fine when cold then splutters and dies when it starts to warm up
  4. Re: P2011 fault code help please
    130 Post(s)
    1972 Post(s)
    That is classic hall sender failure.
  1. Question P2011 Code
    By prophet in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-07-2019, 09:10 AM
  2. Fault codes P2008 and P2011
    By tonyandkaty in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-01-2016, 06:38 PM
  3. Audi A5 - 3.0 TDI Quattro - Emissions Control System - P2011 Fault Code Help!
    By harpy92 in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 27-04-2013, 09:55 PM
  4. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
