Thread: Battery Replacement on Passat B8 Estate
  1. Battery Replacement on Passat B8 Estate
    Dec 2007
    Just checking as it looks more complicated than in the past
    My 2017 Passat Estate GT 1.8 TSI 180PS looks as if it needs a new battery.
    VW are some distance away but Halfords Autocentre are nearby.
    Does the car need special codes to fit the battery only available to VW?
    Any comments welcome.
  2. Re: Battery Replacement on Passat B8 Estate
    130 Post(s)
    1972 Post(s)
    Yes it will need coding.
  3. Re: Battery Replacement on Passat B8 Estate
    Dec 2007
    Thanks Crasher, I thought so.
    When I check Halfords do this, will they think I am trying to "teach them to suck eggs"?
    Mike
  4. Re: Battery Replacement on Passat B8 Estate
    Mar 2021
    Ripon
    7 Post(s)
    Halfords will code your new battery but YOU NEED TO MAKE CERTAIN THAT THEY ACTUALLY DO.
    I have heard stories where they have not coded, the car does not recognise it as new battery and it degrades quickly.
  5. Re: Battery Replacement on Passat B8 Estate
    Dec 2007
    Thanks. I wondered about that so will try to monitor the replacing
  6. Re: Battery Replacement on Passat B8 Estate
    Mar 2021
    Ripon
    7 Post(s)
    I believe £20 is the Halfords fitting charge and you will be covered by the warranty on the specific battery up to I believe 5 years once fitted and hopefully coded by them.
  1. Replacement key fob 2006 Passat estate (Spanish import)
    By Avantgerbrochen in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-10-2018, 08:29 PM
  2. Question Replacement Tyres for Passat Sport Estate
    By mikefox in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-02-2010, 10:04 PM
  3. Passat B5 Battery replacement.
    By David Carkett in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-12-2009, 02:51 PM
  4. Passat Estate Rear Lamp replacement
    By Bribc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-03-2008, 04:07 PM
  5. Passat Battery replacement
    By passat owner in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-09-2007, 10:47 AM
