Thread: Fault codes
Results 1 to 10 of 13
  1. Fault codes
    Jan 2024
    Corsham
    Hey all, I have inherited my dad’s A6 avant. It’s throwing up some fault codes, they are :P1654, P1653, U1007, P1573, and P1018. I know one of them is inlet manifold, do I need to replace it or can I clean/service it? Thanks gang
  2. Re: Fault codes
    130 Post(s)
    1972 Post(s)
    What is the VIN?
  3. Re: Fault codes
    Jan 2024
    Corsham
    Luckily I took a photo of that!
    WAUZZZ4F78N040846
    hope that helps
  4. Re: Fault codes
    130 Post(s)
    1972 Post(s)
    That is a 2008 model with the BPP 2.7 V6 TDI. P1654 will be in a controller such as the transmission and indicates a fault in the engine management system which is affecting its operation. P1653 is similar indicating a fault in the ABS which could be referring to the same problem. U1007 is again referring to a fault in another module, this time the battery monitoring unit. P1573 is a failed left engine mount.
    17426 (P1018) - Intake Manifold Runner (Bank 2): Lower Limit not reached
    This is a standard problem on this engine and means a new left bank manifold although there are bodges around it which we won’t employ.
    All the other faults could just point to the manifold issue.
  5. Re: Fault codes
    Jan 2024
    Corsham
    that’s brilliant, thank you for that. I guess at a minimum I’m looking to get a new engine mount and replace the intake manifold, best practise would be to replace both intakes I’d imagine?
  6. Re: Fault codes
    130 Post(s)
    1972 Post(s)
    Yes but daft money, £991.34 per side and quite a few hours labour.
  7. Re: Fault codes
    Jan 2024
    Corsham
    Local garage doing it for £1300 both sides and engine mount which I thought was reasonable
  8. Re: Fault codes
    130 Post(s)
    1972 Post(s)
    They will be replacing only the motors which often does not work and you end up buying the complete units anyway and then putting the new none returnable motors on fleaBay, there are always a few on there so some inexperienced person to try.
  9. Re: Fault codes
    Jan 2024
    Corsham
    Car is back from the garage, all done. Both inlet manifolds done plus engine mount. Just shy of a lot of money!
    thanks for all replies, hoping to keep the car a while so will be posting more “how do I”
  10. Re: Fault codes
    130 Post(s)
    1972 Post(s)
    Fingers crossed.
  1. Please Help Dpf and EGT Sensor fault code - fault codes P2002 and P242A
    By Svwpolo11 in forum 1.2TDi - Engine
    Last Post: 11-06-2024, 06:37 PM
  2. Fault codes
    By aks1989 in forum Golf MK4 - 1999 - 2004
    Last Post: 18-03-2016, 11:50 AM
  3. Please Help A3 Fault codes Radio Fault
    By MAFED in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 02-05-2010, 04:21 PM
  4. A8 fault codes.....
    By Steve-T in forum A8 - S8 - V8
    Last Post: 11-04-2009, 08:18 PM
  5. vag-com fault codes
    By j.johnson23 in forum VCDS - General Questions
    Last Post: 23-11-2008, 05:47 PM
