Thread: Golf 2.0 Tdi Poor start & rough running
Results 1 to 10 of 14
  1. Golf 2.0 Tdi Poor start & rough running
    Nov 2023
    Sittingbourne, England
    Hello everyone, I'm new to VW and to the forum. I have been asked to help a relative who has a problem with his Golf, it's been to a specialist who has changed the common rail diesel sensor, the camshaft position sensor, the fuel filter and had the injectors tested (and charged him £880) The fault is still exactly the same though, very poor starting, poor idle and rough running, it's very erratic, sometimes it will idle and sometimes it won't. It also sounds as though there's some sort of pre-ignition going on every now and then too. I've put a scanner on it today and the injector variance doesn't look right to me, can anyone tell me what the max/min variances should be? Another thing to mention is that this all apparently started when he removed a fuse (he can't remember which one!) to get the ABS light to go out!! There's not fuel legend in the car for me to check either so it would also be helpful is anyone has one of those for this car. Many thanks, Alan. Injector Variance.jpg
  2. Re: Golf 2.0 Tdi Poor start & rough running
    130 Post(s)
    1972 Post(s)
    You can't test those injectors... What is the VIN?
  3. Re: Golf 2.0 Tdi Poor start & rough running
    Nov 2023
    WVWZZZ1KZEK001873, many thanks.
  4. Re: Golf 2.0 Tdi Poor start & rough running
    130 Post(s)
    1972 Post(s)
    A friend of mine called Daryl runs a highly respected company called Gee Diesel and I asked him about these injectors and he said apart from in engine leak back tests and other basic test with a diagnostic system you can’t do anything with them so as as we do, only fit Bosch exchange units 0 986 435 166, even VW have given up offering recon units.
  5. Re: Golf 2.0 Tdi Poor start & rough running
    Oct 2012
    Ireland
    Is this a 2L GTD golf, what engine code?
    What price are the new exchange Bosch injectors?
  6. Re: Golf 2.0 Tdi Poor start & rough running
    130 Post(s)
    1972 Post(s)
    The VAG price is £706.45… each! Search the Bosch number above and there are less painful alternatives but do factor in the costs and complications of returning the old “core” unit(s) back to suppliers not in the UK such as Aut0doc and its myriad shadow companies in Germany.
  7. Re: Golf 2.0 Tdi Poor start & rough running
    Mar 2010
    Derry ireland
    63 Post(s)
    The cars reg no or engine code would be helpful plus mileage
  8. Re: Golf 2.0 Tdi Poor start & rough running
    130 Post(s)
    1972 Post(s)
    CFHC engine
  9. Re: Golf 2.0 Tdi Poor start & rough running
    Oct 2012
    Ireland
    Crasher, would you know the engine code of a mk7 2.0L GTD golf and the engine code of the mk7 150hp version, please?
  10. Re: Golf 2.0 Tdi Poor start & rough running
    Nov 2023
    Thanks for the replies guy's. I've got loads of screen shots from the tester but I can only attach one at a time by the looks of it. The only code I got was for the glow plug relay but that cleared and hasn't come back on. The engine takes ages to start and then runs very erratically, I'm really not convinced it's the injectors, I've got a suspicion it may be bad fuel, I'm going over again next Friday with fresh fuel (I'll bypass the cars system a feed straight into the HP Pump) and see what happens! Can anyone answer the injector volume variance question? Thanks again.
  1. Rough running and poor acceleration but no codes?!
    By Angus33 in forum Golf MK4 - 1999 - 2004
    Last Post: 06-11-2019, 01:31 PM
  2. Poor MPG/Rough Idle/Smokey Start
    By freshconnexions in forum Golf MK4 - 1999 - 2004
    Last Post: 19-05-2015, 08:00 PM
  3. Replies: 2
    Last Post: 16-04-2015, 07:05 PM
  4. 1999 6N Polo rough idle, poor cold start
    By Golf tdi Hal in forum Polo - Derby - Lupo - Fox
    Last Post: 18-02-2014, 11:12 PM
  5. 1.8t a3 running rough poor idle no power???
    By djglovehead in forum Audi A3 - Archive Topics
    Last Post: 10-04-2007, 06:33 PM
