Thread: vw passat limp mode and no codes ???
Results 1 to 8 of 8
  1. vw passat limp mode and no codes ???
    Aug 2023
    co antrim
    hello ive a 2015 vw passat for the last few months it has been going in and out of limp mode and no eml or fault codes shows up
    its seems to go in to limp mode when under pressure like up a hill and then comes back out of itself again, i have bought it to a few diffrent mechanics and all are confused
    all the filters have been changed a month ago , crank seal done, timing belt done, new battery, new
    alternator, octator selenoid and few pipes replaced
    dpf cleaner used and turbo cleaner used, its has been on more diagnostics machines and no code faults even vw are unable to tell me whats wrong with it
    so any help or advice would be helpful
    thanks
  2. Re: vw passat limp mode and no codes ???
    Mar 2010
    Derry ireland
    63 Post(s)
    certainly a vac problem falling off check out with a vac gauge at turbo actuator vac should read 26/27 hg/in
  3. Re: vw passat limp mode and no codes ???
    130 Post(s)
    1972 Post(s)
    If it is really limp mode, it has to leave a code.
  4. Re: vw passat limp mode and no codes ???
    Aug 2023
    co antrim
    Quote Originally Posted by tonymac5 View Post
    thanks
    thanks for the replys will have it checked again this week with the gauge hopefully get a result as its keeps going in and out of limp mode and no codes to tell me when i put foot on pedal and get no throttle over 3000 rpm or boost
  5. Re: vw passat limp mode and no codes ???
    130 Post(s)
    1972 Post(s)
    Which code reading system are you using?
  6. Re: vw passat limp mode and no codes ???
    Aug 2023
    co antrim
    WhatI h code reading system are you using?
    its has been put on all the best main code reading systems available including volkswagens main system and its been reset back to factory setting and still limp mode and no code
    thought it was the dpf a few weeks ago as soot level was 9.3 and now its down to under 3.0. thought it might be the egr value but now i think it is the turbo as i have had to top it up
    with more oil every week, if it was the turbo it should still give out a code ???
  7. Re: vw passat limp mode and no codes ???
    130 Post(s)
    1972 Post(s)
    I can’t accept real limp mode and no codes, it doesn’t add up.
  8. Re: vw passat limp mode and no codes ???
    Aug 2023
    co antrim
    if i knew what was wrong with it i would have it fixed but with no codes it becomes a guessing game with costs
  1. help with these fault codes please car in limp mode epc on
    By kerrylark in forum 2.0T, TSI and TFSI - Engine
    Last Post: 09-11-2016, 12:35 PM
  2. Limp Mode + ESP/EML light and struggling to start (codes in thread!)
    By mgsmagsmags in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-10-2014, 10:33 AM
  3. Please Help Flashing Glow plug warning light - Limp mode - VCDS Codes - help
    By bgvw in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-10-2013, 10:27 PM
  4. Please Help Limp mode Codes (17861-17428)
    By David Harrison in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-08-2013, 09:20 PM
  5. limp mode 8 error codes showing please help !
    By blobby in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-11-2010, 09:19 PM
