Thread: 2k caddy 2.0tdi conversion issues
  1. 2k caddy 2.0tdi conversion issues
    Jan 2021
    GB worcester
    Hi guys recently converted a 1.9 105 tdi caddy to a 2.0tdi 140 from a touran, straight forward swap all running now but I can’t figure out the wiring for the vacuum block, overall I’m left with approx 10 wires from the loom that have no home and no boost, wiring diagrams show no help from either the caddy or the touran, I can update the exact wires tomorrow when I’m with the van but a few off the top of my head... violet/green, red/black blue/black, black, black grey and many more, anyone able to point me in the right direction on which wires I need for the boost side, I also have the old 3 port n75 from the 1.9 if it’s easier to convert to that if anyone can give me some sort of pin out to wire that into the 2.0.
    I converted a 1.9 sdi 2k caddy about 2 years ago to a 2.0 140 from a golf and all I had for wiring was red/black and black/yellow to deal with so I’m stranded as I can’t relay back to that one (pictures of my first one to show I’m not completely clueless lol)
  2. Re: 2k caddy 2.0tdi conversion issues
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Do you have model years and engine codes for the two vehicles? Is the loom you're now looking at the body or engine side of the original Caddy one, or from the Touran? Are these wires loose ended, or in plug housings with various numbers of pins?
  3. Re: 2k caddy 2.0tdi conversion issues
    Jan 2021
    GB worcester
    Quote Originally Posted by VAG-Abound View Post
    I’ll get the years and codes in the morning when I’m back in the unit, and I’m using the caddy body loom and the touran engine loom, the wires are loose ended as I cut them from the touran loom that relays back into the car , plugged in what had plugs now I’m left with wires I’m unsure of
  4. Re: 2k caddy 2.0tdi conversion issues
    129 Post(s)
    1972 Post(s)
    Download the wiring diagrams for both vehicles to their VIN from erWin.
  5. Re: 2k caddy 2.0tdi conversion issues
    Jan 2021
    GB worcester
    I have full wiring diagrams for both vehicles but they’re proving no help, I’ve started working backwards and narrowed the loose wires down to 4 that all lead inside the car so I’m slowly getting somewhere
  6. Re: 2k caddy 2.0tdi conversion issues
    129 Post(s)
    1972 Post(s)
    Post both VIN’s and on Monday I will join in reading the diagrams, what are the colour codes of the wires.
  7. Re: 2k caddy 2.0tdi conversion issues
    Mar 2016
    GB
    I'm doing this swap at the minute. Which ecu are you using? Also what have you done with the steering setup as my donor is electric and the caddy is hydraulic. Also what have you done with clocks and ignition barrel
    Damo
  1. VW Caddy 2010 Key to remote conversion
    By crsperformance in forum Retrofits
    Last Post: 22-08-2017, 09:09 AM
  2. Please Help caddy van issues.
    By stevethemeerkat in forum New Member Introductions
    Last Post: 16-07-2017, 11:23 PM
  3. Caddy 2 to 3 Seat Conversion
    By Mike2.0TQ in forum The Commercial Range
    Last Post: 07-11-2015, 06:47 PM
  4. A6 2.0TDi SE Conversion
    By coolraj003 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-09-2011, 05:13 PM
  5. 2.0tdi singlemass conversion
    By biscuit-a3 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 01-08-2011, 10:07 PM
