Thread: Air Suspension Fault Codes - Leak?
Results 1 to 10 of 14
  1. Air Suspension Fault Codes - Leak?
    Sep 2015
    Belfast
    Had my 2016 Q7 Almost a year now, and the only problem I was worried about having has now appeared
    So I got a yellow warning on my dash for a fault in my air suspension last week. Only appeared first thing in the morning. By the time I grabbed a coffee on my way to work it disappeared for the rest of the day.
    VCDS fault codes:
    Compressor for suspension Level Control
    C118D 07 [008] - Mechanical Failure
    Intermittent...
    Pressure Accumulator for Level Control
    C11AF F0 [008] - Leak Detected
    Intermittent...
    I guess it's stating the obvious 'leak', but to begin with I checked all of the level sensors at each wheel as I knew they had plastic arms which tend to break, like every Audi I've owned. But they were all fine.
    Now the fault seems to have got worse as the compressor runs for a good 60+ secs then stops, yellow warning comes on, and none of the suspension settings can be chosen - Comfort, Off road etc...
    New VCDS fault codes:
    Address 74: Chassis Control Labels: None
    Control Module Part Number: 4M0 907 777 E HW: 4M0 907 777 E
    Component and/or Version: Fahrwerk-SG H10 0104
    Software Coding: 98505048F8
    Work Shop Code: WSC 31414 790 00001
    ASAM Dataset: EV_ChassContrContiAU736 002013 (AU73)
    ROD: EV_ChassContrContiAU736.rod
    VCID: 3B233F6323EB97521A9-806E
    10 Faults Found:
    what
    3178509 - Compressor for Suspension Level Control
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 4
    Fault Frequency: 18
    Reset counter: 136
    Mileage: 130290 km
    Date: 2023.05.02
    3178501 - Valve for Quick-Filling of Air Suspension
    C11C6 F0 [008] - Maximum On-Time Exceeded
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 125
    Mileage: 130219 km
    Date: 2023.04.29
    Time: 11:54:18
    3178504 - Outlet Valve for Level Control System
    C11F2 07 [137] - Mechanical Failure
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 96
    Mileage: 130935 km
    Date: 2023.05.09
    Time: 19:39:50
    3211271 - Level Control System
    C10D3 F6 [008] - Raising of Front Left Implausible
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 3
    Reset counter: 136
    Mileage: 130845 km
    Date: 2023.05.08
    Time: 17:18:23
    3211272 - Level Control System
    C10D3 F7 [008] - Raising of Front Right Implausible
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 4
    Reset counter: 136
    Mileage: 130847 km
    Date: 2023.05.08
    Time: 17:20:16
    3211273 - Level Control System
    C10D3 F8 [008] - Raising of Rear Left Implausible
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 136
    Mileage: 130923 km
    Date: 2023.05.08
    Time: 18:24:53
    3211274 - Level Control System
    C10D3 F9 [008] - Raising of Rear Right Implausible
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 136
    Mileage: 130924 km
    Date: 2023.05.08
    Time: 18:25:27
    3211266 - Pressure Accumulator for Level Control
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 22
    Reset counter: 136
    Mileage: 130231 km
    Date: 2023.04.30
    Time: 10:46:40
    3211267 - Air Spring or Air Line; Front Left
    C1147 07 [008] - Mechanical Failure
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 136
    Mileage: 130844 km
    Date: 2023.05.08
    Time: 17:17:36
    3211268 - Air Spring or Air Line; Front Right
    C1148 07 [008] - Mechanical Failure
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 136
    Mileage: 130844 km
    Date: 2023.05.08
    Time: 17:17:36
    The same fault code 'C11AF F0 [008] - Leak Detected' appears, and after a google search, there is a tech bulletin for a repair kit to correct a manufacturing problem. Anyone aware of this?
    I would like to start at the compressor and work my way to each wheel to check for leaks but I can't find any info/diagrams on the Q7 4M. 7zap only has the old model version, is there another resource for the Mk2?
    Any guidance would be much appreciated
    Ta.
  2. Re: Air Suspension Fault Codes - Leak?
    Mar 2017
    Hindhead UK
    Had an air suspension fault similar to this on my old 2017. It was a know fault where the air suspension line rubs on the chassis, eventually leading to a leak. Mine was repaired under warranty at the time.
  3. Re: Air Suspension Fault Codes - Leak?
    Jul 2008
    Lisburn
    16 Post(s)
    IMHO there is only 1 fault - Leak Detected the rest being a knock on effect. i didn't check the log times - is this the first by any chance?
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  4. Re: Air Suspension Fault Codes - Leak?
    Sep 2015
    Belfast
    Just got the bad news from my mechanic after quite thorough testing, the compressor is shot. So the question is, OEM only? Or is there a decent after market compressor or brand to go for?
  5. Re: Air Suspension Fault Codes - Leak?
    Apr 2014
    London
    Hi - I’m replacing mine with a used one from eBay, off a vehicle that has been scrapped. Audi wanted £2.2k!
  6. Re: Air Suspension Fault Codes - Leak?
    Jul 2023
    London, UK
    Just to throw in, you say thorough testing but does that include pressure testing all the lines without the compressor to check for leaks? Often air suspension compressors burn out because they are working harder/more often to maintain pressure due to small leaks.
  7. Re: Air Suspension Fault Codes - Leak?
    Apr 2014
    London
    @Razputin - how did you get on with the compressor replacement?
    I had mine swapped for the replacement, but now getting dash warnings of faults…
    Did your system need recalibration?
  8. Re: Air Suspension Fault Codes - Leak?
    130 Post(s)
    1972 Post(s)
    That is why we refuse to use second hand electronic/electrics as you don’t know if you are introducing a problem
  9. Re: Air Suspension Fault Codes - Leak?
    Apr 2014
    London
    That’s perfectly understandable.
    Would you expect a replacement compressor and valve block to be plug and play, or need further configuration/calibration?
  10. Re: Air Suspension Fault Codes - Leak?
    130 Post(s)
    1972 Post(s)
    These systems can be a real PITA if the calibrations get corrupted. A few months ago I went through torture with a Toerag 2 and it’s Porsche Active Suspension Management which is like yours with knobs on. The ECU flatly refused to play ball even using the dealer system ODIS and every time we set it level, after the ignition was cycled the front collapsed and the rear stuck its **** in the air. Eventually my friend used Autel to get it down into a workable rage when ODIS started working again. The PASM has the additional complication of a 10 Bar Nitrogen filled dual chamber air tank which uses the same fitting as the AC system so a standard air con system cylinder does the job.
  1. Please Help Dpf and EGT Sensor fault code - fault codes P2002 and P242A
    By Svwpolo11 in forum 1.2TDi - Engine
    Last Post: 11-06-2024, 06:37 PM
  2. Air suspension leak from where?
    By zit501 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-03-2024, 06:44 AM
  3. Please Help Leak through bonnet release and Multiple Fault codes
    By JimA4B6 in forum Golf MK7 - 2013 - 2019
    Last Post: 13-12-2021, 08:25 PM
  4. Self Levelling Suspension Fault - Locked Suspension Yelow Warning on Dash
    By ceilidhalfie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-12-2014, 05:01 PM
  5. Please Help Audi A8 fault codes SUSPENSION
    By JEFAXN in forum A8 - S8 - V8
    Last Post: 12-03-2013, 10:25 AM
