Thread: No Heater Blower
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. No Heater Blower
    Dec 2022
    Oakham
    Hello,
    I have a problem that I have no heater blower on my Audi A6 C6 3.0tdi 2006. The fault from VCDS on the HVAC unit is:
    1 Fault Found:
    02071 - Local Databus
    012 - Electrical Fault in Circuit
    Fuses are fine. Now an internet search seems to reveal that unplugging the G395 Air Con Pressure switch allows the fan at least to start working. Due to a short of some kind interfering with the comms / bus. I have unplugged mine but still no blower. Could the actual connector be causing the short for instance?
    Any idea what to try next? A new blower unit is the obvious choice but the VCDS error concerns me that this wont fix it. The blower just has a positive and negative terminal so I'm not convinced this will help with the databus fault?
  2. Re: No Heater Blower
    131 Post(s)
    1973 Post(s)
    What is the VIN?
  3. Re: No Heater Blower
    Dec 2022
    Oakham
    What is the VIN?
    WAUZZZ4F86N162208
    Thanks.
  4. Re: No Heater Blower
    131 Post(s)
    1973 Post(s)
    Check fuse 41 in the right dash side fuse board has power across it, if it does my initial suspicion would be the F126 blower controller 4F0 820 521 A, the fan itself is easy to test
  5. Re: No Heater Blower
    Dec 2022
    Oakham
    Thanks. My thoughts too.Fuse is all good. Already ordered the heater controller. 😁
  6. Re: No Heater Blower
    Dec 2022
    Oakham
    Replaced the heater controller / resistor and got the same problem. Also put 12v on the fan. It worked fine.
    Now lost. Any thoughts?
  7. Re: No Heater Blower
    131 Post(s)
    1973 Post(s)
    You have checked for power on the red/blue wire where it changes to red/black at the 3 pin plug?
  8. Re: No Heater Blower
    Dec 2022
    Oakham
    So the red and black has 12v. The red and blue has nothing.
  9. Re: No Heater Blower
    Dec 2022
    Oakham
    There is 0.5v on the yellow.
  10. Re: No Heater Blower
    131 Post(s)
    1973 Post(s)
    It is black/yellow on the diagram, that is the control head signal line
  1. Please Help Heater Blower
    By Rajsta in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-02-2020, 01:30 PM
  2. Heater blower u/s
    By deanosabby in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 01-04-2014, 08:17 AM
  3. Heater blower
    By raymondbilko in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-10-2010, 11:23 PM
  4. Heater Blower
    By Turkster in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-05-2007, 03:05 AM
  5. NO HEATER BLOWER
    By EMILY in forum Passat - Archive Topics
    Last Post: 23-01-2007, 05:38 PM
