Thread: Clutch and flywheel replacement
Results 1 to 8 of 8
  1. Clutch and flywheel replacement
    Jan 2023
    leeds
    Hi guys its time to replace my clutch as its slipping (revs going up when accelerating but cars not accelerating accordingly)
    Which clutch/flywheel do you recommend? i have bought an LUK clutch from a local parts store now sourcing a flywheel
    I have found this
    new Genuine LUK Dual Mass Flywheel DMF 415049510 Audi A4 B7 with Bolts | eBay
    Its all in LUK packaging but then says made by sachs??
    Will this be okay to fit with my LUK clutch. im so confused there are so many different part numbers for the same item GSF and euro car parts all different too! HELP!
  2. Re: Clutch and flywheel replacement
    131 Post(s)
    1974 Post(s)
    Sometimes you can mix, sometimes you can't, what is the VIN? When we do a clutch we only order a full matching kit from one supplier as imagine if you get a warranty problem, say a judder? Then each supplier will blame the other and you are piggy in the middle, trust me, been there and suffered.
  3. Re: Clutch and flywheel replacement
    Jan 2023
    leeds
    WAUZZZ8E47A145867
    yeah I understand just confused with the Sacha part in the LUK box! I did some research and apparently this is normal ?
  4. Re: Clutch and flywheel replacement
    131 Post(s)
    1974 Post(s)
    Yes it is normal when the box contains reconditioned parts, not new as with when you buy a genuine VAG clutch. Your car was built with an LUK flywheel, the current number is 03G 105 266 BH which is an LUK 415 0244 10. I get the kit without DMF you need as 624 3308 00.
  5. Re: Clutch and flywheel replacement
    Mar 2010
    Derry ireland
    63 Post(s)
    never ever mix clutch parts
  6. Re: Clutch and flywheel replacement
    Mar 2023
    Portugal
    Ive just had a full 4 piece Sachs clutch kit . Moderator tells me its of the highest quality so im pleased about that .Id go for a complete clutch kit not separates. Hasnt solved my problem of 1st and reverse gears not disengaging unfortunately.Its an intermittant problem when engine warm after the first fifteen minutes car running .Good luck choosing.
  7. Re: Clutch and flywheel replacement
    Jan 2023
    leeds
    Is it best practice to replace both clutch and flywheel together? Similar to timing belt and water pump
  8. Re: Clutch and flywheel replacement
    131 Post(s)
    1974 Post(s)
    Quote Originally Posted by barry140tdi View Post
    With both jobs, if someone asked me to do it without the DMF or water pump (when relevant) I would refuse.
  1. Clutch and Flywheel replacement
    By markmck in forum Passat CC
    Last Post: 12-11-2015, 10:15 AM
  2. Question Clutch and flywheel replacement BMR engine
    By gresty in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-02-2013, 10:33 PM
  3. Clutch & Flywheel Replacement
    By carlsbergy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-04-2010, 04:46 PM
  4. Clutch and flywheel replacement....
    By JAY_1 in forum The Commercial Range
    Last Post: 29-09-2008, 08:19 PM
  5. Replacement clutch / New flywheel?
    By JasonC in forum Passat - Archive Topics
    Last Post: 20-07-2007, 11:49 PM
