Thread: Dsg clutch position sensor electrical fault
  1. Dsg clutch position sensor electrical fault
    Birmingham
    7 Post(s)
    The missus 2.0tdi 4 motion tiguaun went into limp mode today. She limped it home but could only get even gears on the 7 speed dsg. A quick scan an it came up with this code
    It has cleared and drives alright for the moment,but how do I change the sensor? Or do I? Will it just need an adaptation? Or is it gearbox out? I have to do a cambelt and dsg service anyway so if the box has to come out I am thinking of taking the lot out and doing it on the bench for ease of access
    Cheers Mike
  2. Re: Dsg clutch position sensor electrical fault
    130 Post(s)
    1972 Post(s)
    That is a built in part of the Mechatronic, what is the VIN?
  1. Throttle position sensor - strange fault
    By Ants in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-01-2019, 07:58 PM
  2. Please Help 58 plate Passat clutch position sensor implausible signal problem
    By Thomas2309 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-10-2018, 07:58 PM
  3. Cam Position Sensor/Timing Fault
    By GarethB in forum Jetta MK3 - 2005 - 2013
    Last Post: 15-03-2017, 11:10 PM
  4. Please Help Clutch position switch/sensor Golf Mk5
    By Norbertpanhandl in forum Golf MK5 - 2004 - 2009
    Last Post: 28-03-2014, 09:20 PM
  5. Please Help camshaft position sensor fault
    By alanscottgraham in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-04-2013, 08:56 AM
