Thread: Tiptronic Gearbox Fault/Failure
  1. Tiptronic Gearbox Fault/Failure
    Dec 2017
    GB
    So finally got car mot'd and on the road. Its a 2005 3.0 TDi quattro s-line automatic. When I bought it, it had an issue where it would drive fine, then all of a sudden feel like it was in neutral, revs would shoot up to redline, you would have to lift off and eventually it would engage again but would shift past 3rd gear until you turned engine off. Because it had no mot decided to get that done first. Picked it up earlier, took it for a drive, did as it was before drove fine for a bit using all 6 gears, then it did its usual rev with no gear engaged then stuck at not being able to get past 3rd.
    But....when I turned into my road all of a sudden there was a massive clunk and now there is no drive at all. Any ideas where to start? Is it a gearbox off to see job?
    Can select PNRDS fine just when you press accelerator pedal nothing happens other than car revs go up. When using Tiptronic or Manual mode you cannot change up gears. Any advice appreciated as don't want to spend loads of it if it is something simple.
    TIA
    Here are some VCDS measuring block images, not sure if the will help
    20221219-184448 — ImgBB
    20221219-184525 — ImgBB
    20221219-184613 — ImgBB
    20221219-184628 — ImgBB
    20221219-184639 — ImgBB
    20221219-184654 — ImgBB
    20221219-184752 — ImgBB
    20221219-184800 — ImgBB
    20221219-184822 — ImgBB
    20221219-184903 — ImgBB
    20221219-184911 — ImgBB
    20221219-184921 — ImgBB
    20221219-184932 — ImgBB
    20221219-184944 — ImgBB
    20221219-184953 — ImgBB
    20221219-185005 — ImgBB
    20221219-185049 — ImgBB
    20221219-185143 — ImgBB
  2. Re: Tiptronic Gearbox Fault/Failure
    Jan 2009
    Birmingham
    36 Post(s)
    whats the faults codes stored
  3. Re: Tiptronic Gearbox Fault/Failure
    Dec 2017
    GB
    Quote Originally Posted by arman123 View Post
    None at the moment, before it went completely and was drivable these are the codes it had
    Address 01: Engine Labels: 059-907-401-ASB.clb
    Control Module Part Number: 8E0 910 401 F HW: 8E0 907 401 AJ
    Component and/or Version: 3.0L V6TDI 001AG 0040
    Software Coding: 0011171
    Work Shop Code: WSC 66565 257 00032
    VCID: 224B5F8FFDCFF89FF9-8076
    8 Faults Found:
    005489 - Left Engine Mount Solenoid Valve (N144)
    P1571 - 001 - Short to Plus
    Freeze Frame:
    Fault Status: 01110001
    Fault Priority: 0
    Fault Frequency: 3
    Reset counter: 255
    Time Indication: 0
    Freeze Frame:
    RPM: 756 /min
    Torque: 46.8 Nm
    Speed: 0.0 km/h
    Voltage: 14.06 V
    Bin. Bits: 0
    Bin. Bits: 0
    Bin. Bits: 0
    005658 - Glowplug for Cylinder 1 (Q10)
    P161A - 001 - Open Circuit
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Time Indication: 0
    Freeze Frame:
    RPM: 882 /min
    Torque: 105.3 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 14.21 V
    Duty Cycle: 24.1 %
    Temperature: 15.3°C
    005659 - Glowplug for Cylinder 2 (Q11)
    P161B - 001 - Open Circuit
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Time Indication: 0
    Freeze Frame:
    RPM: 882 /min
    Torque: 105.3 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 14.21 V
    Duty Cycle: 24.1 %
    Temperature: 15.3°C
    005660 - Glowplug for Cylinder 3 (Q12)
    P161C - 001 - Open Circuit
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Time Indication: 0
    Freeze Frame:
    RPM: 882 /min
    Torque: 105.3 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 14.21 V
    Duty Cycle: 24.1 %
    Temperature: 15.3°C
    005661 - Glowplug for Cylinder 4 (Q13)
    P161D - 001 - Open Circuit
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Time Indication: 0
    Freeze Frame:
    RPM: 882 /min
    Torque: 105.3 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 14.21 V
    Duty Cycle: 24.1 %
    Temperature: 15.3°C
    005662 - Glowplug for Cylinder 5 (Q15)
    P161E - 001 - Open Circuit
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Time Indication: 0
    Freeze Frame:
    RPM: 882 /min
    Torque: 105.3 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 14.21 V
    Duty Cycle: 24.1 %
    Temperature: 15.3°C
    005663 - Glowplug for Cylinder 6 (Q15)
    P161F - 001 - Open Circuit
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Time Indication: 0
    Freeze Frame:
    RPM: 882 /min
    Torque: 105.3 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 14.21 V
    Duty Cycle: 24.1 %
    Temperature: 15.3°C
    012697 - Control Circuit for Intake Manifold Runner (Bank2)
    P3199 - 002 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00110010
    Fault Priority: 0
    Fault Frequency: 10
    Reset counter: 255
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Torque: 241.8 Nm
    Speed: 0.0 km/h
    Voltage: 11.55 V
    Duty Cycle: 84.8 %
    Duty Cycle: 0.4 %
    Duty Cycle: 20.5 %
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Control Module Part Number: 8E1 910 156 HW: 09L 927 156
    Component and/or Version: AG6 09L 3.0lTDI RdW 0050
    Software Coding: 0000001
    Work Shop Code: WSC 06325 000 00000
    VCID: 64C71997A75BB6AF4B-8030
    3 Faults Found:
    17167 - Shift Monitoring
    P0783 - 000 - 3-4 Shift - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 204132 km
    Time Indication: 0
    Freeze Frame:
    RPM: 2496 /min
    RPM: 2336 /min
    RPM: 1248 /min
    (no units): 42.0
    (no units): 101.0
    Temperature: 28.0°C
    T.B. Angle: 54.5°
    17119 - Gear 5
    P0735 - 000 - Incorrect Ratio
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 204152 km
    Time Indication: 0
    P0783 - 001 - 3-4 Shift
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 204132 km
    Time Indication: 0
    Freeze Frame:
    RPM: 2496 /min
    RPM: 2336 /min
    RPM: 1248 /min
    (no units): 42.0
    (no units): 101.0
    Temperature: 28.0°C
    T.B. Angle: 54.5°
  4. Re: Tiptronic Gearbox Fault/Failure
    Jan 2009
    Birmingham
    36 Post(s)
    Gearbox from a ruputable garrage will cost more than the car.
    If this was my car il strip it down for parts or scrap it.
  5. Re: Tiptronic Gearbox Fault/Failure
    130 Post(s)
    1972 Post(s)
    I agree, the likely costs to fix will in parts alone would be double the cars value… mind you, that’s never stopped me in the past; I have a 2003 Octavia L&K on the middle lift and £1500 of engine bits on the bench waiting to be built into a recon block.
  1. I did a 2.5 tdi tiptronic to manuel gearbox conversion. Fault 00550 17-10
    By Wenderby in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-09-2015, 09:46 PM
  2. gearbox transmission fault A4 SE Auto Tiptronic
    By bwfcboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-06-2010, 08:23 AM
  3. tiptronic total sudden drive failure
    By cmp260 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-08-2009, 10:05 AM
  4. Please Help Audi A6 2.5TDI Tiptronic failure
    By akhan in forum New Member Introductions
    Last Post: 04-06-2008, 07:49 AM
  5. Tiptronic gearbox fault
    By ProfDMW in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-02-2008, 09:15 PM
