Thread: Gearbox software update
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: Gearbox software update
    Jul 2010
    lichfield uk
    Just a quick update
    I manage to update software in my gearbox from 006 straight to latest 009. I've used Odis E. with Vas5054a took less than 2 minutes. So far I've noticed that gear changes are smoother. Need to test longer to see if that update will help me with my sporadic reverse gear issue.
    System environment
    Login account: xxxPc
    PC name: xxx-PC
    Operating system: Windows_NT
    Processor: x86 Family 6 Model 14 Stepping 8, GenuineIntel
    RAM: 2097151
    Diagnostic hardware: VAS5054
    Vehicle
    VIN: WAUZZZ4G8DN126962
    Daily counter: 3480
    Central unlearning counter: 0
    Mileage: 172132 km
    Onboard time: 20:25
    MCD project: AU57X
    MCD project version: 2.227_(2.7.2_021002)
    Content
    Installation list
    02 - Transmission Control Module
    Update programming
    Communication data
    Update programming
    ECU: 02 - Transmission Control Module
    20.01.2023 20:29:52
    LL_TransContrModulUDS (EV_TCMDL501021_001)
    Flash process
    20.01.2023 20:29:52
    Session:
    4G1 927 156T_ _ 0009
    Result:
    job completed successfully
    Duration:
    01:45
    Property
    Before the update
    After the update
    VW/Audi part number
    4G1927156T
    4G1927156T
    Software version
    0006
    0009
    Hardware part number
    0B5927156J
    0B5927156J
    Hardware version
    H01
    H01
    ASAM/ODX file identification
    EV_TCMDL501021
    EV_TCMDL501021
    ASAM/ODX file version
    001012
    001025
    [SO]_Param_VWTesteCodinInfor
    Coding
    00 00 01
    00 00 01
    System abbreviation
    J217
    J217
    Vehicle equipment code
    00 00 00 00 00 00 00 00
    Parameter set part number
    NULL
    NULL
    Parameter set version
    NULL
    NULL
    System description
    0B5 30 TDIRdW
    0B5 30 TDIRdW
    Program memory status
    programmable Program available
    Programmability
    programmable
    programmable
    Program consistency
    Program present
    Program present
    Parameterizability
    [VO]_NULL
    [VO]_NULL
    Data consistency
    [VO]_NULL
    [VO]_NULL
    Error during last data record download
    [VO]_NULL
    [VO]_NULL
    Data record modification
    [VO]_NULL
    [VO]_NULL
    Vehicle Identification Number (VIN)
    WAUZZZ4G8DN126962
    WAUZZZ4G8DN126962
    FAZIT-identification
    TFK-03020.02.1309040255
    Serial number
  2. Re: Gearbox software update
    Feb 2009
    Ireland
    6 Post(s)
    I had this gearbox. I feel you. At 190k km it started giving me problems. Jerky 2-1, adaptation would help, but it would return to usual nehaviour after a while. Later developed into slipping clutch manifesting in 7th. Replaced the clutch, problems went away, but never had confidence in it, sold as is. It is a mammoth of a gearbox, very complex bit of kit.
  3. Re: Gearbox software update
    Jul 2010
    lichfield uk
    Quote Originally Posted by nordic_b View Post
    Did you had it remapped by any chance ?
  4. Re: Gearbox software update
    Feb 2009
    Ireland
    6 Post(s)
    No, the car was standard, and the gearbox was serviced every 50k with records, and on latest software. During one of oil changes, I spotted pieces of friction plates, then I knew this is the end of it. It was a Q5 though, a little heavier perhaps?
    Audi quoted me 5k for the job, which, of course, I declined.
    One thing I recall, is that when engine had problems resulting in torque reduction, gearbox would become very inconsistent - but it was merely reacting to torque reduction. So before attending the gearbox I knew I had to make sure the engine runs fault free.
  5. Re: Gearbox software update
    Jul 2010
    lichfield uk
    Here's another update
    So the software update didn't fix my reversing problem. So the next step was to replace circuit boards with solenoids ( 0b5398048d ) on the mechatronic unit also fresh ATF, internal and external filters. Took me all day on my driveway but looks like it's fix now.
    Oil I drain was really dark and smelly also filter was made in 2012 so I don't know what to think about oil changes at dealership.
  6. Re: Gearbox software update
    Mar 2013
    Leicester
    Quote Originally Posted by marciolo View Post
    Just a quick update
    System environment
    PC name: xxx-PC
    RAM: 2097151
    Vehicle
    Daily counter: 3480
    Mileage: 172132 km
    Onboard time: 20:25
    MCD project: AU57X
    Content
    Installation list
    Update programming
    Communication data
    Update programming
    20.01.2023 20:29:52
    Flash process
    20.01.2023 20:29:52
    Session:
    Result:
    Duration:
    01:45
    Property
    Before the update
    After the update
    VW/Audi part number
    4G1927156T
    4G1927156T
    Software version
    0006
    0009
    0B5927156J
    0B5927156J
    Hardware version
    H01
    H01
    EV_TCMDL501021
    EV_TCMDL501021
    001012
    001025
    Coding
    00 00 01
    00 00 01
    System abbreviation
    J217
    J217
    NULL
    NULL
    NULL
    NULL
    System description
    0B5 30 TDIRdW
    0B5 30 TDIRdW
    Programmability
    programmable
    programmable
    Program consistency
    Program present
    Program present
    Parameterizability
    [VO]_NULL
    [VO]_NULL
    Data consistency
    [VO]_NULL
    [VO]_NULL
    [VO]_NULL
    [VO]_NULL
    [VO]_NULL
    [VO]_NULL
    WAUZZZ4G8DN126962
    WAUZZZ4G8DN126962
    Serial number
    marciolo I need to do the exact same update as you - 006 to 009 Using Odis E and VAS5054.
    Just waiting on VAS5054 and then I need to source the update file.
    Can I ask please, was this easy to do? And can you share the instructions/steps you performed.
  7. Re: Gearbox software update
    #17
    Jul 2010
    lichfield uk
    Quote Originally Posted by ShanA6C6 View Post
    the whole process of updating the software is fairly easy, but if something goes wrong it will be expensive to fix !
    Make sure you're using good quality Vas5054 unit,
    Updating via USB cable,
    Connect trickle charger to the car before you start updating
    In Odis E. Click flash then pick transmission Control, locate the correct flash file on your laptop for your TCU and hit flash if I remember correctly. You will get all kinds of warnings on your dashboard during update (don't panic it's normal) all process takes around 3-4 minutes to complete. At the end you will have to turn ignition off then back on again. Odis will take you step by step and guide you what to do.
    Ps. The latest software in my gearbox prevents clutches from overheating max temp. they can rich is now around 120 Celsius, before update they were reaching 160 Celsius.
    1 1 0
  8. Re: Gearbox software update
    #18
    Sep 2014
    Tallinn, Estonia, Estonia
    @marciolo that is if you can get ODIS engineering, they won't help me get it! Your car has a gearbox oil change on 2020-07-25 at 69699 miles by Tamworth Audi, unless I am going blind I can't see the software version
    There is this TPI but you have a specific code, there are numerous 0B5 TPI's for all sorts of errors (the 0B5 is a piece of junk) but none that I can see cover P204A.
    Technical product information Transaction No.: 2038130/2
    Hard jerk when pulling away after start-stop and hard knock with 2-1 gear change - 0B5 gearbox Release date: 15-Dec-2014
    Customer statement / workshop findings
    When restarting the engine after a stop-start operation the vehicle pulls away with a one-off hard jerk/knock.orA one-off hard jerk/knock when changing from 2-1.
    Technical background
    No entry in diagnosis address 01 and 02.
    Production change
    Measure
    Try to reproduce the customer complaint so that it can be clearly assigned to this TPI. The following measure must only be carried out, if all the criteria (model/type, chassis number, engine/gearbox code, PR number(s), part number, software version etc. ) match exactly. Otherwise this solution won't work and repeat repairs may be necessary. In such a case, we may reject the warranty claim and redebit the parts.Update the gearbox control unit with SVM code02A089:
    Actual control unit
    Required control unit
    Hardware
    Software
    Version
    Hardware
    Software
    ≥Version
    0B5927156J0B5927156K
    8K9927156M
    8K9927156M
    0005
    8T0927156E
    8T0927156E
    0010
    8T0927156G
    8T0927156G
    0005
    8T0927156F
    8T0927156F
    0011
    8T0927156H
    8T0927156H
    0005
    8K5927156
    8K5927156
    0010
    8T0927156J
    8T0927156J
    0005
    8K9927156C
    8K9927156C
    0005
    8K9927156G
    8K9927156G
    0005
    8K9927156H
    8K9927156H
    0004
    8K9927156L
    8K9927156L
    0004
    8K2927156J
    8K2927156J
    0007
    8K2927156L
    8K2927156L
    0010
    8K5927156B
    8K5927156B
    0004
    8K9927156D
    8K9927156D
    0005
    8K2927156M
    8K2927156M
    0011
    8K5927156D
    8K5927156D
    0004
    8K2927156K
    8K2927156K
    0007
    8K2927156N
    8K2927156N
    0008
    8K9927156P
    8K9927156P
    0005
    8K9927156S
    8K9927156S
    0005
    8K2927156G
    8K2927156G
    0008
    8K2927156R
    8K2927156R
    0007
    8K2927156T
    8K2927156T
    0007
    8K9927156R
    8K9927156R
    0004
    8K9927156J
    8K9927156J
    0005
    8K2927156P
    8K2927156P
    0007
    8K2927156Q
    8K2927156Q
    0008
    8K9927156Q
    8K9927156Q
    0004
    4G1927156F
    4G1927156F
    0009
    4G2927156L
    4G2927156L
    0005
    4G1927156J
    4G1927156J
    0008
    4G5927156
    4G5927156
    0004
    4G9927156
    4G9927156
    0008
    4G2927156N
    4G2927156N
    0004
    4G1927156T
    4G1927156T
    0008
    4G2927156P
    4G2927156P
    0004
    4G1927156K
    4G1927156K
    0008
    4G9927156A
    4G9927156A
    0004
    4G9927156K
    4G9927156K
    0002
    4G9927156L
    4G9927156L
    0002
    4G1927156L
    4G1927156L
    0010
    4G9927156B
    4G9927156B
    0007
    4G2927156
    4G2927156
    0008
    4G2927156R
    4G2927156R
    0004
    4G1927156S
    4G1927156S
    0013
    4G9927156C
    4G9927156C
    0006
    4G1927156Q
    4G1927156Q
    0008
    4G5927156A
    4G5927156A
    0004
    4G2927156D
    4G2927156D
    0008
    4G9927156D
    4G9927156D
    0004
    4G2927156E
    4G2927156E
    0008
    4G9927156E
    4G9927156E
    0004
    4G1927156R
    4G1927156R
    0009
    4G9927156G
    4G9927156G
    0004
    4G2927156F
    4G2927156F
    0008
    8R1927156R
    8R1927156R
    0006
    8R1927156L
    8R1927156L
    0005
    8R1927156S
    8R1927156S
    0008
    8R2927156
    8R2927156
    0005
    8R1927156N
    8R1927156N
    0006
    8R1927156H
    8R1927156H
    0004
    8R1927156P
    8R1927156P
    0007
    8R1927156J
    8R1927156J
    0004
    8R1927156Q
    8R1927156Q
    0006
    8R1927156K
    8R1927156K
    0004
    8R2927156N
    8R2927156N
    0006
    8K2927156E
    8K2927156E
    0008
    4G9927156F
    4G9927156F
    0004
    8R2927156L
    8R2927156L
    0004
    8R2927156M
    8R2927156M
    0004
    8K9927156B
    8K9927156B
    0004
    8K9927156E
    8K9927156E
    0004
    8K9927156F
    8K9927156F
    0004
    Warranty accounting instructions
    Service number/damage code: 3730 / 0041Accounting with APOS:
    Model:
    Repair operation:
    Designation:
    Time units:
    27068950
    Charge battery
    10 TU
    01510000
    Software update
    TU according to diagnosis log
    The times of this TPI are correct at the time of publication.Accounting with APOS/2:
    Illustration:
    Position:
    Number
    Designation:
    Activity
    Time units:
    STA-02
    Battery
    90
    10 TU
    STA-02
    1
    S00042
    Software update
    A8
    Hello,
    Can You give me for my audi new gearbox software versions and SVM code?
    vin WAUZZZF25KN114492
    Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
    Part No SW: 4K0 927 153 AK HW: 0HL 927 156 B
    Component: 0HL 30TFSIRdW H01 0001
    Revision: --H01--- Serial number: 0000000022 CVN: B9C3475500000000
    Coding: 000001
    Shop #: WSC 02391 785 00200
    ASAM Dataset: EV_TCMDL382021 002031
    ROD: EV_TCMDL382021_AU58.rod
    VCID: 76A02B58C9440D21E9-8022
    MTF pump:
    Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
    Component: V553 MTFP 003 0576
    Serial number: 75145041190105002383
  1. Replies: 1
    Last Post: 01-10-2020, 05:01 PM
  2. Question How to update MMI software
    By safisher2001 in forum In Car Entertainment
    Last Post: 13-03-2015, 10:35 AM
  3. How To Sat Nav software update
    By DukeofWhiteley in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-02-2015, 09:46 PM
  4. who can do a gearbox software update in birmingham?
    By skans786 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-04-2013, 11:43 PM
  5. Gearbox software update tricore ecu lock.
    By jcdub in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-06-2011, 01:13 AM
