Thread: Code P0405: Exhaust Gas Recirculation Sensor A Circuit Low
  1. Code P0405: Exhaust Gas Recirculation Sensor A Circuit Low
    Nov 2022
    boston
    Hi I have done a scan an I am getting this error, is there a sensor I can easily change, or would it be worth spraying some de-carbon spray into my manifold, to clean my EGR or will it have to be dismantled, to clean or even replaced
  2. Re: Code P0405: Exhaust Gas Recirculation Sensor A Circuit Low
    Mar 2010
    Derry ireland
    63 Post(s)
    It would be more helpful to post up your engine code & model
  3. Re: Code P0405: Exhaust Gas Recirculation Sensor A Circuit Low
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    And even in the right section might be nice.
  4. Re: Code P0405: Exhaust Gas Recirculation Sensor A Circuit Low
    129 Post(s)
    1972 Post(s)
    He is from Boston after all, "too much sky" as Mrs Crasher says but she is from upt norf
  5. Re: Code P0405: Exhaust Gas Recirculation Sensor A Circuit Low
    Dec 2022
    Glastonbury,UK
    Depends on the codes your getting
    But what you say can be done clean out the egr system and get it working efficiently again as long as the egr value isn’t done for
  1. P0546 Exhaust Gas Temperature Sensor Circuit High (Bank 1)
    By nick.king in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-07-2019, 07:18 AM
  2. Question Fault code P2563 Turbocharger Boost Control Position Sensor Circuit: Implausible Signal
    By Audikiller in forum New Member Introductions
    Last Post: 29-08-2018, 12:21 PM
  3. Fix Audi code 01032 Exhaust Gas Recirculation Sensor B & 01027 Exhaust Gas Rec Circuit
    By niall campbell in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-12-2017, 02:57 PM
  4. Replies: 1
    Last Post: 08-01-2014, 07:37 PM
  5. Replies: 0
    Last Post: 24-01-2010, 12:57 PM
