Thread: Error codes and location of coolant pump c
  1. Error codes and location of coolant pump c
    Mar 2022
    England
    Hi I am getting coolant leaking after driving the car. Pressure check show no loss. And there are no visible leaks by two garages. I was getting these codes three months ago and once cleared didn’t come back
    P013600 - 02 Sensor Circuit, Bank 1 - Sensor 2 Malfunction
    P332500 - Power Supply Terminal 15 Implausible
    P26F800 - Coolant Pump "C" Stuck
    P034100 - Camshaft Position Sensor Circuit Range / Performance
    P014100 - 02 Sensor Heater Circuit Bank 1 Sensor 2 Malfunction
    The mechanic is telling me it could be the water pump. But we also want to know the location of coolant pump c incase that is causing the leak. Any help would be great full as I use my car as a taxi and losing money whilst the car is off road. Many thanks
  2. Re: Error codes and location of coolant pump c
    131 Post(s)
    1973 Post(s)
    Coolant pump C is the stop/start heater support electric pump around the back of the engine near the right driveshaft. It often reports as being faulty (stuck, jammed or cavitating) when really it is the often identical intercooler pump on the front of the engine. We did two of this engine design main water pumps last week, one a Caddy the other a Superb, during the cam belt change; both were leaking and both had a faulty regulator ring. We have another to do, on a T6, on Monday.
  1. Please Help Auxiliary coolant pump / coolant pump B open circuit
    By ahsanx in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 24-07-2024, 01:07 PM
  2. Question Auxiliary/Secondary Coolant Pump Location Polo 6R
    By JSingh1 in forum Polo - Derby - Lupo - Fox
    Last Post: 26-03-2021, 08:36 PM
  3. Question P261A – Coolant Pump 2 issue (pump failure), need advice.
    By jkeeeng in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 07-02-2017, 10:28 PM
  4. P261A error code - auxillary coolant pump B - where is this pump?
    By 3rdpassat in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-07-2015, 08:31 PM
  5. Question Coolant pump 2 location (Passat B6)
    By thegb in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-04-2014, 01:01 PM
