Thread: 1.6 petrol ALZ (B5.5) crankshaft position sensor location?
Results 1 to 8 of 8
  1. 1.6 petrol ALZ (B5.5) crankshaft position sensor location?
    Mar 2018
    Dublin
    Hi, firstly let me say this is actually for an Audi A4 B6, 2002, I posted this question in another forum but did not get an answer so trying here in the hope this engine is more popular in the Passat
    I have a '02 1.6 petrol, engine code ALZ with a P0322 Engine Speed Sensor (G28): No Signal
    Whereabouts is the sensor? All my web searches yield other engines and I have a Haynes manual but it just covers the 1.8 (was given to me, I didn't buy the wrong one!). And is it easy to change?
    This is the engine with the single ignition coil, not the one with the individual coil per plug. I attach a pic of it, thanks!
  2. Re: 1.6 petrol ALZ (B5.5) crankshaft position sensor location?
    129 Post(s)
    1972 Post(s)
    It is down at the back of the block on the cars left directly below the coolant expansion tank is is held into the engine by a 5mm hex cap screw. This points directly at an 60-2 impulse rotor on the back of the crank web behind cylinder 4. The part number has been revised to 071 957 147 which costs £129.27 but you can get the aftermarket from Bosch under their number 0 261 210 177 for less but beware of cheap unknown brands, the G28 is THE critical engine running sensor and cheap ones may work but cause random glitches which can confuse diagnostics.
    1 1 0
  3. Re: 1.6 petrol ALZ (B5.5) crankshaft position sensor location?
    Mar 2018
    Dublin
    Thank you so much for the detailed reply. So this is on the inlet side? I fount a connector with 3 pins on the bulkhead but it appeared to be going off to the exhaust side, maybe it was something else.
    It was raining here in Dublin today, I'll try to get a look during the week and report back. I'll have a look on auto Doc for that p/n, thanks.
  4. Re: 1.6 petrol ALZ (B5.5) crankshaft position sensor location?
    129 Post(s)
    1972 Post(s)
    Find the grey plug, follow the cable.
    1 1 0
  5. Re: 1.6 petrol ALZ (B5.5) crankshaft position sensor location?
    Mar 2010
    Derry ireland
    63 Post(s)
    Your engine code po322 covers a multitude the crankshaft position sensor on this vehicle has 3terminals marked 1-2-3 easily enough checked out either on the vehicle or off check the ohms reading on terminals 2& 3 which should be between 930-970 ohms terminal 1 black wire Terminal 2 grey wire terminal 3 blue wire magnetic type sensor
  6. Re: 1.6 petrol ALZ (B5.5) crankshaft position sensor location?
    Mar 2018
    Dublin
    Thanks, yes the plug I mentioned was grey, I'll have another look!
  7. Re: 1.6 petrol ALZ (B5.5) crankshaft position sensor location?
    Mar 2018
    Dublin
    Hi I've only got a chance to get back to this today, before I tell you my findings a little background.
    Car has had cold starting issues for over a year now and I found unplugging the MAF makes it start. I didn't want to just replace it without doing some diagnosis so recently got a loan of a cable for VCDS Lite. Another fault developed where it stalls at pretty much the same point into my into work and home again. VCDS indicated the sensor (forget what it said about MAF).
    Anyway today I measured the resistance of the crank sensor and was 885R pins 2/3 and open pins 1 to 2 or 3. So given it stalls when warm I let it idle until it stalled and measured again, pins 2/3 now open! so, a result confirming bad sensor.
    I'll be surprised if this fixes the cold start issues since it seems to be OK when cold, but who knows. One thing, I accidentally started it with the crank sensor disconnected and it started fine! Is this normal, can it work just off the cam sensor?
    I followed the cable to the back of the block under the coolant tank as described, was going by feel and it seemed to go into a larger harness. Access looks impossible - is this done from under the car?
    Thanks Crasher and mickeybo for your posts, most helpful.
  8. Re: 1.6 petrol ALZ (B5.5) crankshaft position sensor location?
    Mar 2018
    Dublin
    Just another update, job done at the weekend and it was located as described, just near the oil filter, a little to the right of it as you're looking at the filter.
    Removed a U shaped, circa 25cm long support bracket that went from the block to the inlet manifold for better access (this is on an A4 assume Passat is the same). Got it from under the car. A mate was helping, I guided in the socket set and he did the turning from up top.
    If anyone is doing this, and you are near an oil change, removing the filter will make life a lot easier.
    Thanks again for all your help!
  1. Question Petrol 1.6: camshaft position sensor location
    By norrie rugger head in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-07-2016, 12:42 PM
  2. Replies: 1
    Last Post: 03-11-2012, 02:41 PM
  3. Crankshaft Position Sensor Location (Error code P0322)
    By Harv91 in forum Polo - Derby - Lupo - Fox
    Last Post: 06-05-2012, 08:19 AM
  4. where is crankshaft position sensor?
    By lpg boy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-09-2010, 05:53 PM
  5. crankshaft position sensor location
    By collym3 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-04-2010, 01:32 PM
