Thread: slight engine judder when cold
  1. slight engine judder when cold
    Jul 2008
    northern ireland
    Getting a slight engine judder when accelerating when cold, goes away when the oil temperature starts to raise. done a scan on vcds and it says there is an electrical fault on 3 of the glow plugs, take it that means bad glow plugs or could it be something else? don't want to have to remove the glow plugs unless i have to. I've attached the readout from vcds. thanks for looking.
    Code:
    Sunday,04,September,2022,16:52:30:02845
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 22.3.1.4  HEX-V2 CB: 0.4615.4
    Data version: 20220407 DS337.0
    Ross-Tech: Home
      License Plate:
    Chassis Type: 3C-VW46 (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 4C 4F 52 53 56 61
              62 72 77
       Mileage: 281100km-174667miles
    01-Engine -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    4C-Tire Pressure II -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (J623-CFFB)       Labels:. 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 PR    HW: 03L 907 309 AE
       Component: R4 2.0l TDI   X25 9979
       Revision: 41X25---    Serial number: 00000000000000 CVN: 940D8C53
       Coding: 00190032042501080000
       Shop #: WSC 92521 052 00000
       ASAM Dataset: EV_ECM20TDI01103L906018PR 003007
       ROD: EV_ECM20TDI01103L906018PR.rod
       VCID: 094F93C3F9B9F393981-805C
       VINID: 9E69EAAAA0D3A935410831490C1678BA6C
    3 Faults Found:
    4984 - Cylinder 1 Glow Plug Circuit (Q10)
              P0671 00 [109] - Electrical Fault
              Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 280431 km
                        Date: 2022.08.22
                        Time: 12:20:30
                        Engine RPM: 0.00 /min
                        Normed load value: 0.0 %
                        Vehicle speed: 0 km/h
                        Coolant temperature: 14 °C
                        Intake air temperature: 15 °C
                        Ambient air pressure: 1010 mbar
                        Voltage terminal 30: 11.940 V
                        Unlearning counter according OBD: 40
                        Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
                        Electric auxiliary heater: shut-off conditions-Bits 0-7: 2
                        Electric auxiliary heater: relay activation-Bits 0-7: 0
                        Pre-glow time: 1300 ms
                        Glow status-Bits 0-7: 0
                        Glow cycles above temperature threshold-Bits 0-7: 11
                        Glow cycles above temperature threshold-Bits 0-7: 214
                        Glow cycles below temperature threshold-Bits 0-7: 0
                        Glow cycles below temperature threshold-Bits 0-7: 7
                        Outside temperature: 19.0 °C
    4985 - Cylinder 2 Glow Plug Circuit (Q11)
              P0672 00 [109] - Electrical Fault
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 280431 km
                        Date: 2022.08.22
                        Time: 12:20:30
    4987 - Cylinder 4 Glow Plug Circuit (Q13)
              P0674 00 [096] - Electrical Fault
              Intermittent - Not Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 280593 km
                        Date: 2022.08.27
                        Time: 17:37:22
                        Engine RPM: 1368.00 /min
                        Normed load value: 30.2 %
                        Vehicle speed: 24 km/h
                        Coolant temperature: 21 °C
                        Voltage terminal 30: 15.000 V
                        Unlearning counter according OBD: 38
                        Pre-glow time: 2200 ms
                        Glow cycles above temperature threshold-Bits 0-7: 221
                        Outside temperature: 16.0 °C
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes        Labels: 3AA-614-109.clb
       Part No SW: 3AA 614 109 AG    HW: 3AA 614 109 AG
       Component: J104   C2 450M VDCA 0023
       Revision: --H07---    Serial number: 00000005209508
       Coding: 0004016
       Shop #: WSC 05311 000 00000
       VCID: 72BDD42FF8AF904BC9B-8026
    No fault code found.
    Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
       Part No SW: 3AA 907 044 F    HW: 3AA 907 044 F
       Component: Climatronic   H03 0101
       Revision: 00001K01
       Coding: 0014004803
       Shop #: WSC 00015 115 00000
       ASAM Dataset: EV_Climatronic A01010
       ROD: EV_ClimaAutoBasis_VW46.rod
       VCID: 3333112BCBB5D94302D-8066
    Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
       Part No SW: 3AA 937 087 F    HW: 3AA 937 087 F
       Component: BCM PQ47 M    421 0464
       Revision: BA421001
       Coding: 000800000000000000180080540000E403510088426D87606480C7200041
       Shop #: WSC 05311 000 08193
       VCID: 3D273713FD711F33E49-8068
       Subsystem 1 - Part No: 3AC 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer 20121  26  0612
       Coding: 00B795
       Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
       Component: RLS 201211 05  54  0403
       Coding: 0230ED
    Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
       Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0025
       Revision: --------    Serial number: 56261134501653
       Coding: 149206
       Shop #: WSC 99999 1023 2097151
       ASAM Dataset: EV_EPHVA2C000000000 002008
       ROD: EV_EPHVA2C000000000.rod
       VCID: 44D142F79E1B6EFBAB7-8010
    Address 15: Airbags        Labels: 5N0-959-655.lbl
       Part No SW: 5N0 959 655 Q    HW: 5N0 959 655 Q
       Component: J234__10J VW10 HI   1918
       Revision: 23016000    Serial number: 003JZPRZ4QSU
       Coding: 0012362
       VCID: 4BC369CBBFC5A1836AD-801E
       Subsystem 1 - Serial number: 6332MTS693593371
       Subsystem 2 - Serial number: 6342MTS634903421
       Subsystem 3 - Serial number: 6351HTS6T6JBV9KJ
       Subsystem 4 - Serial number: 6361HTS66CNPU9KJ
       Subsystem 5 - Serial number: 00000000000000000
       Subsystem 6 - Serial number: 00000000000000000
    Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
       Part No SW: 3C9 953 501 BN    HW: 5K0 953 569 AB
       Component: LENKS.MODUL   014 0140
       Revision: FF010040    Serial number: 20111215101596
       Coding: 1182250000
       ASAM Dataset: EV_VW360SteerWheelUDS A03004
       ROD: EV_VW360SteerWheelUDS.rod
       VCID: 76B5E83F98478C6BE53-8022
       Multifunction steering wheel control module:
       Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TK6  H06 0022
       Coding: E20000
    Address 17: Instruments (J285)       Labels:| 3C8-920-xxx-17.clb-SRI1
       Part No SW: 3AA 920 970 E    HW: 3AA 920 970 E
       Component: KOMBI         H03 0609
       Coding: 461F01
       Shop #: WSC 05314 115 00000
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod
       VCID: 35372F33C5C1C7732C9-8060
    Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
       Part No SW: 7N0 907 530 P    HW: 1K0 907 951
       Component: J533  Gateway H40 1623
       Revision:   H40       Serial number: 181211F1000945
       Coding: 462007
       Shop #: WSC 05314 000 00000
    Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
       Part No SW: 3AA 959 433     HW: 3AA 959 433
       Component:    IMMO         043 0400
       Revision: 00043000    Serial number: VWZCZ000000000
       Shop #: WSC 131071 1023 2097151
       VCID: 76B5E83F94C78C6BE53-8022
       Subsystem 1 - Part No: 3C0 905 861 J
       Component:    ELV          029 0380
       3C0905861J     ELV          029 0380
    Address 2E: Media Player 3 (J650)       Labels:. 5N0-035-342.lbl
       Part No SW: 5N0 035 342 E    HW: 5N0 035 342 E
       Component: SG EXT.PLAYER H13 0240
       Revision: A1001003    Serial number: 7661611790
       Coding: 010000
       VCID: 290FF34319F99393B81-807C
    Address 42: Door Elect, Driver (J386)       Labels:| 3C0-959-70X-GEN4.clb
       Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0534
       Revision: 12110009    Serial number: 0004141158
       Coding: 0212B7
       Shop #: WSC 05311 115 00000
       ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
       ROD: EV_TSGFPQ35BRFVW46X_VW32.rod
       Slave Driver:
       Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0407
       Serial number: 00000002649051
       Coding: 000290
    1 Fault Found:
    66048 - Motor for Front Window Regulator
              B11EC 54 [008] - Missing Calibration / Basic Setting
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 1
                        Reset counter: 231
    Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
       Part No: 1K0 909 144 N
       Component: EPS_ZFLS Kl. 195    3301
       Revision: 00H22000
       Shop #: WSC 02069 000 90108
       VCID: 35372F33C941C7732C9-8060
    Address 46: Central Conv.        Labels:. 3C0-959-433-46.clb
       Component:    KSG PQ47 ELV 043 0634
       Coding: 0191020052830E76340494157C085FCE105C01
       Subsystem 1 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HORN H05 1501
       Subsystem 2 - Part No: 3C0 951 171 C
       Component: Neigungssensor  004 0611
       Subsystem 3 - Part No: 3C0 951 171 C
       Component: Innenraumueberw.004 0611
    Address 4F: Centr. Electr. II (J520)       Labels:. 1K0-907-532.clb
       Part No SW: 7N0 907 532     HW: 1K0 907 951
       Component: EZE_2         H40 1623
       Coding: 00000008
       VCID: 6FBBDD5BE79DBDA3265-803A
       Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
       Component: Analoguhr  004 0003
    Address 52: Door Elect, Pass. (J387)       Labels:| 3C0-959-70X-GEN4.clb
       Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0534
       Revision: 14110009    Serial number: 0004118192
       Coding: 0212B6
       ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
       ROD: EV_TSGBPQ35BRFVW46X_VW32.rod
       VCID: 3635283FD8C7CC6B253-8062
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0407
       Serial number: 00000002651878
       Coding: 000290
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 1
                        Reset counter: 231
    Address 53: Parking Brake        Labels: 3AA-907-801.clb
       Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
       Component: J540 EPB4  VW-64783 0009
       Revision:   H19       Serial number: 00000000568089
       Coding: 0022167
    Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
       Part No SW: 3C8 035 195 G    HW: 3C8 035 195 G
       Component: Radio RCD510  050 0207
       Revision: 00000001    Serial number: VWZ1Z3L6700332
       Coding: 01000400040011
       VCID: 2C010A57160B86BB437-8078
    Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
       Part No SW: 7N0 907 534     HW: 1K0 907 951
       Component: Batt.regelung H40 1623
       Coding: 030F185A
       VCID: 71BFDB23F1A9AB53301-8024
       Subsystem 1 - Part No SW: 1K0 915 181 H    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0180
       Serial number: 00000000008900451668
    Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
       Part No SW: 5K0 035 730 D    HW: 5K0 035 730 D
       Component: TELEFON       H09 2902
       Revision: 1B001001    Serial number: 00007661536965
       Coding: 0A01000000010101
       ASAM Dataset: EV_UHVNA A01719
       ROD: UHVNA.rod
       VCID: 2615F87F0867BCEB953-8072
    End----------(Elapsed Time: 01:29, VBatt start/end: 12.4V/12.4V)-----------
  2. Re: slight engine judder when cold
    130 Post(s)
    1972 Post(s)
    The glow plugs are monitored and are working even during running certain situations, they are classed as a service item rather like a cam belt.
  3. Re: slight engine judder when cold
    Jul 2008
    northern ireland
    Il get some and put them in and see how it goes then, thanks
  4. Re: slight engine judder when cold
    Jan 2016
    Winchester Hants
    29 Post(s)
    The engine management light came on when one of mine went TU. Using my detector it showed No3 as faulty so I replaced them all.
    2013 B7 Passat BlueMotion Sport Estate 2.0 TDi 177PS (CFGC), 6 speed Manual, Metallic Night Blue, Fontana alloys, Start/Stop, RNS-510 (HW H09, SW 5238 V13 maps, 8316) Nav DAB, ACC, XDS, TPM, Westfalia Tow bar, Rear View camera, Keyless Entry, Easy Open/close Electric Tailgate, Park Assist, Electric Parking Brake, DRL's, Amb light, Zebrano wood, Tinted Glass, mud flaps, 61K. Cheat emission software. Nextbase 402G iN-CAR CAM.
  5. Re: slight engine judder when cold
    Jul 2008
    northern ireland
    Quote Originally Posted by UMEL View Post
    My light hasn't came on yet, I changed the fuel filter last week and there was a bit of dirt in the reservoir and filter was very dirty, the juddering has since disappeared from the engine since then, will still change the plugs when I get time thou to be on the safe side
  1. Question Slight clutch judder when it gets hot
    By Inspector Beetle in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-06-2015, 09:31 PM
  2. Trouble starting from cold and judder at idle on 1.9 PD engine
    By iaindhill in forum Golf MK5 - 2004 - 2009
    Last Post: 27-10-2014, 05:52 PM
  3. Question Slight judder when pulling away
    By Alann84 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-02-2012, 08:05 PM
  4. Please Help Slight judder on idle
    By Killakam78 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-11-2011, 10:26 PM
  5. Allroad 2.7T slight engine misfire/judder
    By snugglebum in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-11-2010, 02:50 PM
