Thread: Audi a4 b8 2.0tdi turbo actuator problem
  1. Audi a4 b8 2.0tdi turbo actuator problem
    Jul 2022
    Serbia
    Hello,
    Im having a problem with turbo actuator for nearly 2 months.
    Problem is: when glowplugs light(coil) start to flash car lose power and after a while mil icon apears aswell.
    Is happenas randomly, even on start and in the middle of driving.
    Diagnostics shows turbo actuator low input as i rember well.
    So turbo was removed cleaned and changed full cathridge. So basicliy new turbo,and was tested on machine with old actuator and results are great.
    Turbo was back on car and same error...
    My mechanic told it has some bad circuit 5v to the actuator, electic mechanic messed with some pins on some connector near car computer(some white conector) suggesting that there starts bad connection to voltage problems on actuator. And again same error. Glowplug light still flashes. Pls if some1 had problem and fix pls write it.
    Thanks.
  2. Re: Audi a4 b8 2.0tdi turbo actuator problem
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Does that mean that the electrician thought he'd identified a problem with the 5V line, but didn't fix it? Or he did try to fix that but the problem remains?
    It does sound like it could be a fractured wire, where the signal is lost briefly causing the ECU to go into limp mode. Can you get a reading of stored errors using VCDS or similar?
    What is the engine code - something like CAGX?
  3. Re: Audi a4 b8 2.0tdi turbo actuator problem
    Jul 2022
    Serbia
    Hello,
    Thnx for replying
    He did fix "something" some loose contacts, wire was tested and is ok, its not broken.
    Problem still remains, it was bad conduct thro the wire on the actuator,and that fixing of conectors solved problem with 5v. That is what he told me...
  4. Re: Audi a4 b8 2.0tdi turbo actuator problem
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    If that fix did nothing and you still have the same problem than perhaps it was never a problem in the first place, although it might have looked corroded.
    Code reads may give a clue what is happening.
  5. Re: Audi a4 b8 2.0tdi turbo actuator problem
    Jul 2022
    Serbia
    Il read codes again tomorrow, had one code and is related for actuator.
  6. Re: Audi a4 b8 2.0tdi turbo actuator problem
    Jul 2022
    Serbia
    Still dodnt fix it. Code is P256400
  7. Re: Audi a4 b8 2.0tdi turbo actuator problem
    130 Post(s)
    1972 Post(s)
    You need to have the setup checked using a vacuum pump and measuring blocks display
  1. P3348 Turbo Actuator doesn't move, new turbo and actuator installed too!!!
    By alan0259 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-10-2021, 03:38 PM
  2. Please Help 2.0tdi turbo actuator 2009 a4
    By bigred84 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-03-2017, 11:37 PM
  3. Replies: 6
    Last Post: 16-11-2015, 05:36 PM
  4. Turbo actuator problem?
    By smohamm527 in forum Bora - 1998 - 2005
    Last Post: 30-01-2008, 02:29 AM
  5. AUDI A4 T-Sport Actuator valve problem
    By indy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-09-2007, 04:01 PM
