Thread: GTD 2015- newbie questions on issues
  1. GTD 2015- newbie questions on issues
    Jun 2022
    Lincoln UK
    Hi all
    First time poster; full disclosure I am a self confessed Bimmer geek so don't hold that against me eh?
    Now this is the missus car. Bought it after I had a 63 plate GTD which I loved as a company car. All in good order apart from a niggle I need your advice with- as I am handy with the spanners I am confident to get into stuff myself but also not knowing VAG stuff AND forced induction stuff I would appreciate your views...
    2015 GTD with 125k miles.
    Issue happens when accelerating hard/giving it beans; car goes into limp mode and throws P0299 over/under boost error.
    Also general driving I'd say the car is down on power especially boosting in 3rd and 4th. MPG seems low too.
    Did the usual checked for leaks/obvious hose issues etc, nothing immediate. Took it to my local VAG specialist and his more detailed OBD showed nothing more so he looked for leaks too.
    He suggested as nothing obvious to change the diverter valve which I have done, do difference (other than the error seems to happen more often than it did before??)
    So I am starting to lean towards looking at the turbo actuator to see if thats slow/fouling? Are there any how to guides how to check this?
    What else would you guys suggest I look at?
    Anyone experienced similar?
    Cheers!
    Stuart
  2. Re: GTD 2015- newbie questions on issues
    129 Post(s)
    1972 Post(s)
    16683 (P0299) - Boost Pressure Regulation: Control Range Not Reached
    That is underboost. On these engines this is usually a punctured vacuum actuator, apply a vacuum to the port and you should not be able to draw air.
  3. Re: GTD 2015- newbie questions on issues
    Mar 2010
    Derry ireland
    63 Post(s)
    When your vehicle goes into under/over boost do you re-cycle the ign on/0ff lets know this
  4. Re: GTD 2015- newbie questions on issues
    Jun 2022
    Lincoln UK
    Cheers for the replies
    I’m leaning toward the actuator being the issue
    Yes I do re cycle the ignition and it resets fine
    I ran vcds after the fault happens and got the following screens
  5. Re: GTD 2015- newbie questions on issues
    Jun 2022
    Lincoln UK
  1. Replies: 14
    Last Post: 27-01-2022, 06:05 PM
  2. Newbie VW Tiguan 2015 TSI 4 motion owner (reborn VW man!)
    By onzarob in forum New Member Introductions
    Last Post: 20-12-2015, 05:00 PM
  3. 2015 A6 MMI issues
    By gc6269 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 02-08-2015, 10:50 PM
  4. New member - Couple of questions/issues with my first Quattro
    By HimBigChief in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-08-2011, 08:36 PM
  5. Afew issues/questions about the b4
    By gaz td in forum Early Passat Forum - Pre 97
    Last Post: 18-06-2009, 06:29 PM
