Thread: 1.5 TSI DACA thermostat waterpump housing coolant leak, can I replace gaskets ?
Results 1 to 10 of 11
  1. 1.5 TSI DACA thermostat waterpump housing coolant leak, can I replace gaskets ?
    Aug 2016
    Birmingham
    My car is a 2018 24k miles and I have coolant leak on right side of engine just above bell housing, coolant level warning light came on. I checked engine bay and it seemed nothing obvious until I noticed that coolant had been weeping collecting onto the bell housing.
    Having read a few posts now it’s apparent coolant leak is a common issue mines leaking oil on the right side of engine when standing in front of car.
    Cars lost half litre and did not overheat. The hoses don’t seem to be leaking. Having read numerous posts stating that the housing is a common issue. Is it the gaskets that perish ? Because I managed to find a supplier for the gaskets ? I don’t fancy purchasing a whole housing just because of gaskets or is it the case the housing warps ?
    My housing seems to be made of metal not plastic.
    I’ve attached pic of replacement thermostat waterpump housing and the replacement gasket and link for gaskets anyone with similar issue.
    Someone pls advise if I can get away with just replacing gaskets
    thanks in advance
    thanks in advance
    Last edited by Crasher; 21-06-2022 at 11:50 AM. Reason: So old gits like me don't have to squint...
  2. Re: 1.5 TSI DACA thermostat waterpump housing coolant leak, can I replace gaskets ?
    131 Post(s)
    1973 Post(s)
    Usually that is the pump module which has been revised to part number 05E 121 111 R and costs £200.04 genuine retail inc VAT. This does come with the gasket but not the belt. If yours has the ally top cover it means it will already have been replaced.
  3. Re: 1.5 TSI DACA thermostat waterpump housing coolant leak, can I replace gaskets ?
    Aug 2016
    Birmingham
    Thanks this is mine from the side angle, should it have failed the leak is quite discernible is it the gasket that fails or the whole housing that warps ?
  4. Re: 1.5 TSI DACA thermostat waterpump housing coolant leak, can I replace gaskets ?
    131 Post(s)
    1973 Post(s)
    The info on ETKA is confusing, it says that type was only used from August 2021 but it looks older than that. When it is off, it should have a manufacturing date and part number on it. If it is less than two years old and genuine then it has a two year dealer backed warranty BUT you need the TPS or dealer invoice. What is the VIN?
  5. Re: 1.5 TSI DACA thermostat waterpump housing coolant leak, can I replace gaskets ?
    Aug 2016
    Birmingham
    WVWZZZAUZKW029607
  6. Re: 1.5 TSI DACA thermostat waterpump housing coolant leak, can I replace gaskets ?
    131 Post(s)
    1973 Post(s)
    Built 05.10.2018 so when it comes off it should have part number 05E 121 111 J which is now 05E 121 111 R
  7. Re: 1.5 TSI DACA thermostat waterpump housing coolant leak, can I replace gaskets ?
    Aug 2016
    Birmingham
    What did they change in the superseded part no ?
    We’re the older ones prone to failing ? it is it just the gasket that fails ?
  8. Re: 1.5 TSI DACA thermostat waterpump housing coolant leak, can I replace gaskets ?
    131 Post(s)
    1973 Post(s)
    It has so far chnaged part number and design five times, the silicon seal is never the problem, it is the design of the unit.
  9. Re: 1.5 TSI DACA thermostat waterpump housing coolant leak, can I replace gaskets ?
    Aug 2016
    Birmingham
    Thanks I’ll swap it out
  10. Re: 1.5 TSI DACA thermostat waterpump housing coolant leak, can I replace gaskets ?
    Apr 2025
    West sussex
    Hi did you swap this in the end I have the same issue on my car and the 1.5 tsi dada engine the code on my thermostat is 05E 121 117 h it's a 2019 looks the same as yours but wanted to check that it's not different on the dada.
    Liam
  1. Please Help Passat 2012 B7 1.6 tdi water / coolant leak at oil cooler housing
    By Strath44 in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 12-12-2018, 01:13 PM
  2. draining coolant to replace thermostat then reusing?
    By bk.bas99 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-12-2014, 04:04 PM
  3. If replacing the Thermostat housing on 1.8T, always replace the plastic plug behind it.
    By rhencullen1989 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-03-2014, 08:45 PM
  4. Coolant leak possibly from plastic piece just to left of thermostat housing
    Last Post: 03-03-2014, 10:35 PM
  5. Please Help Coolant Leak From Coolant\Water pump Housing
    By Chappio in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-04-2009, 03:30 PM
