Thread: 2012 Passat b7 2.0tdi Cuts Out
Results 1 to 9 of 9
  1. 2012 Passat b7 2.0tdi Cuts Out
    Mar 2022
    Burton upon Trent
    Hi there
    I have B7 CFFB 2.0 TDI Passat and it has just started cutting out. It will run from cold for 90 seconds before cutting out with an ESC error. The dash is still lit but if you try to restart, nothing happens at all, no cranking. If I take the key out for 5 minutes, I can restart and it runs as normal, but only for 90 seconds before repeating the ESC error. It doesn;t matter if I'm stationary or in gear. Battery is fully charged. I did a code read using OBDEleven and its attached. Aybody have a clue what is happening?
    Code:
    OBDeleven data log
    Date: 2022-03-25 10:51
        VIN: WVWZZZ3CZDE005685
        Car: Volkswagen Passat
        Year: 2013
        Body type: Variant
        Engine: CFFB
        Mileage: 341410 KM
    01 Engine
        System description: R4 2,0L EDC
        Software number: 03L906018PR
        Software version: 2480
        Hardware number: 03L907309AE
        Hardware version: H28
        Serial number: 00000000000000
        ODX name: EV_ECM20TDI01103L906018PR
        ODX version: 003003
        Long coding: 00190012042501080000
        Trouble codes:
            No trouble codes found
    03 Brakes
        System description: J104   C2 450M V464
        Software number: 3AA614109AF
        Software version: 0023
        Hardware number: 3AA614109AF
        Hardware version: K03
        Serial number: 00000005238213
        Coding: 0002992
        Trouble codes:
            01314 - Engine control module (ECM) No signal/communication
                static
    04 Steering Angle Sensor
        Trouble codes:
    08 Air Conditioning
        System description: Climatronic
        Software number: 3AA907044AF
        Software version: 0202
        Hardware number: 3AA907044AF
        Hardware version: H03
        ODX name: EV_Climatronic
        ODX version: A01010
        Long coding: 0014004803
        Trouble codes:
            U111100 - Function limitation due to missing message
                static
            B10AF04 - Air quality sensor Faulty
                Intermittent
    09 Central Electrics
        System description: BCM PQ47 H
        Software number: 3AA937087G
        Software version: 0464
        Hardware number: 3AA937087G
        Hardware version: 421
        Long coding: 0008000000000000009800801400816403510088426D81606480C7200041
        Subsystems:
            System description: Wischer 21051
            Software number: 3AC955119
            Software version: 0612
            Hardware version: 26
            Long coding: 00B795
            System description: RLS 290512 05
            Software number: 1K0955559AH
            Software version: 0403
            Hardware version: 54
            Long coding: 0230ED
        Trouble codes:
            00446 - Function limitation due to insufficient voltage Lower limit not reached
                Intermittent
            00526 - Brake light switch Implausible signal
                Intermittent
            00532 - Supply voltage Lower limit not reached
                Intermittent
            00927 - Terminal 30 right Open circuit
                Intermittent
            00985 - Right Tail Light Lamp Open circuit/short circuit to B+
                Intermittent
                static
            01516 - Terminal 30 left Open circuit
                Intermittent
            02391 - Terminal 30 reference Open circuit
                Intermittent
            02394 - Bulb for left front parking light Open circuit/short circuit to B+
                static
            02746 - Right daytime running lamp bulb Open circuit/short circuit to B+
                static
            02739 - Right brake/tail lamp bulb Open circuit/short circuit to B+
                Intermittent
            03789 - Terminal 75 emergency running active
                Intermittent
            03678 - Start-stop operation coordinator No signal/communication
                static
    15 Airbag
        System description: J234__108 VW10 HI
        Software number: 5N0959655AA
        Software version: 2118
        Hardware number: 5N0959655AA
        Hardware version: 003
        Serial number: 003L7PAQBJRK
        Coding: 0012344
        Trouble codes:
    16 Steering Column
        System description: LENKS.MODUL
        Software number: 3C9953501BN
        Software version: 0140
        Hardware number: 5K0953569AB
        Hardware version: 014
        Serial number: 20120530200345
        ODX name: EV_VW360SteerWheelUDS
        ODX version: A03004
        Long coding: 1182250000
        Subsystems:
            System description: E221__MFL-TK6
            Software number: 3C8959537D
            Software version: 0022
            Hardware version: H07
            Long coding: E20000
        Trouble codes:
    17 Dashboard
        System description: KOMBI
        Software number: 3AA920970J
        Software version: 0705
        Hardware number: 3AA920970J
        Hardware version: H05
        ODX name: EV_Kombi_UDS_VDD_RM09
        ODX version: A04716
        Long coding: 461F00
        Trouble codes:
                static
    19 Gateway
        System description: J533  Gateway
        Software number: 7N0907530AA
        Software version: 1632
        Hardware number: 7N0907530G
        Hardware version: H41
        Serial number: 210512F1002227
        Long coding: 462007
        Trouble codes:
                static
            00381 - Instrument cluster data bus No signal/communication
                Intermittent
    25 Immobilizer
        System description: IMMO         043
        Software number: 3AA959433
        Software version: 0400
        Hardware number: 3AA959433
        Hardware version: 008
        Serial number: VWZCZ000000000
        Subsystems:
            System description: ELV          029
            Software number: 3C0905861J
            Software version: 0380
        Trouble codes:
    2E Media Player 3
        System description: SG EXT.PLAYER
        Software number: 5N0035342F
        Software version: 0530
        Hardware number: 5N0035342F
        Hardware version: H18
        Serial number: 7662676602
        Long coding: 020100
        Trouble codes:
                static
    37 Navigation
        System description: RNS315-EU
        Software number: 3C0035279M
        Software version: 0319
        Hardware number: 3C0035279M
        Hardware version: H52
        Serial number: VWZAZ2M5914487
        ODX name: EV_RNS315EUV2UDS
        ODX version: 001705
        Long coding: 040004010400110000019002
        Subsystems:
            System description: EUR_W_0038���
            Software number: 3AA919866��
            Software version: 0038
        Trouble codes:
    42 Driver Door
        System description: TUER-SG FT
        Software number: 3AA959701A
        Software version: 0534
        Hardware number: 3C0959793C
        Hardware version: 002
        Serial number: 0005068404
        ODX name: EV_TSGFPQ35BRFVW46X
        ODX version: A04001
        Long coding: 0202B7
        Subsystems:
            System description: J389__TSG-HR
            Software number: 3AA959704A
            Software version: 0501
            Hardware version: 004
            Serial number: 00000002944372
            Long coding: 010290
        Trouble codes:
            B11EC54 - Motor for front window regulator No basic setting
                Intermittent
                Intermittent
    44 Steering Assistance
        System description: EPS_ZFLS Kl. 195
        Software number: 1K0909144P
        Software version: 3305
        Trouble codes:
                static
    46 Comfort System
        System description: KSG PQ47 ELV 043
        Software version: 0634
        Long coding: 0191020052830E76340494157C085FCE105C01
        Subsystems:
            System description: LIN BACKUP HORN H05
            Software number: 1K0951605C
            Software version: 1501
            System description: Neigungssensor  004
            Software number: 3C0951171C
            Software version: 0611
            System description: Innenraumueberw.004
        Trouble codes:
            00332 - Activation for tank flap Short circuit to ground
                static
    4F Central Electrics 2
        System description: EZE_2
        Software number: 7N0907532
        Long coding: 00000008
        Subsystems:
            System description: Analoguhr
            Software number: 3AA919204A
            Software version: 0003
        Trouble codes:
    52 Passenger Door
        System description: TUER-SG BT
        Software number: 3AA959702A
        Hardware number: 3C0959792C
        Serial number: 0005064070
        ODX name: EV_TSGBPQ35BRFVW46X
        ODX version: A04001
        Long coding: 0202B6
        Subsystems:
            System description: J388__TSG-HL
            Software number: 3AA959703A
            Serial number: 00000002941763
            Long coding: 010290
        Trouble codes:
                Intermittent
                Intermittent
    53 Parking Brake
        System description: J540 EPB4  VW-86594
        Software number: 3AA907801H
        Software version: 0010
        Hardware number: 3AA907801H
        Serial number: 00000000238295
        Coding: 0022167
        Trouble codes:
                static
    56 Radio
        Trouble codes:
    61 Battery Regulation
        System description: Batt.regelung
        Software number: 7N0907534
        Long coding: 030F1859
        Subsystems:
            System description: J367-BDM
            Software number: 1K0915181H
            Software version: 0180
            Serial number: 00000000008900382886
        Trouble codes:
            02252 - Generator mechanical malfunction
                Intermittent
    62 Rear Left Door
        Trouble codes:
    65 Tire Pressure
        System description: RDKBERU30
        Software number: 3AA907273D
        Hardware number: 3AA907273D
        Hardware version: H09
        Serial number: 10000000132956
        ODX name: EV_RDKBERU30
        ODX version: 003012
        Trouble codes:
    72 Rear Right Door
        Trouble codes:
  2. Re: 2012 Passat b7 2.0tdi Cuts Out
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    From the fault codes it looks to me that you are intermittently loosing 12v power to the ECU & other modules.
    Trouble codes:
    Trouble codes:
    Intermittent
    Intermittent
    Intermittent
    Intermittent
    Intermittent
    static
    Intermittent
    Intermittent
    static
    static
    Intermittent
    Intermittent
    static
    All those codes point to loss of 12v power.
    The problem will be finding the break/ loose connection as it's intermittent.
    Start by checking around the engine bay fuse box, look for anything that looks melted or loose.
    Check all the bolted 12v power connections at the front of the fuse box for corrosion, loose connection or sign of melted insulation.
    If nothing found, try running the engine while physically pulling around various parts of the wiring loom to see if you can cause it to fail.
    You may need to get a copy of the wiring diagram to see which ECU terminals should be live & work back from there.
  3. Re: 2012 Passat b7 2.0tdi Cuts Out
    Mar 2022
    Burton upon Trent
    Thanks for that Phillip!
    I've inspected all easily accessible fuses/relays (not tested them) and wiring including wiggling. Still can't find the problem.
    One further symptom is when the car does start then stall after 90 seconds or so, the cooling fans come on after 15 seconds. However the car is cold so it doesn't make sense. It's this an indication of a problem anybody has experienced before? ECU, temp sensor?
  4. Re: 2012 Passat b7 2.0tdi Cuts Out
    Mar 2022
    Burton upon Trent
    And how easy is it to swap out ECU? Does it include lots of recoding and we'll the immobiliser be a problem?
  5. Re: 2012 Passat b7 2.0tdi Cuts Out
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    The ECU is one of the most reliable parts of the car & very unlikely to be faulty.
    The immobiliser would need re-coding or an ECU with the immobiliser deleted.
    There are at least three 12v supplies to the ECU, some permanent & some switched, I suspect one is failing which is giving you the problem.
    You will need a wiring diagram to check the 12v supplies at the ECU before & after the failure, then trace from there to find out why one is missing.
  6. Re: 2012 Passat b7 2.0tdi Cuts Out
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Have you checked the battery voltage & that it's charging when the engine runs?
  7. Re: 2012 Passat b7 2.0tdi Cuts Out
    130 Post(s)
    1972 Post(s)
    I have seen a few of the ECU's on these suffer water damage. The reason the fans kick in is the controller in the main fan can see the ignition is on so it assume the engine is running but it can't see the temperature signal from the ECU so it assumes to worst and goes into full overheat mode. They drive me mad when they do this and you are trying to work on the engine so I pull the fuse. Following from what Phil said, you need to monitor the power feed at the ECU which means wipers and scuttle trim off (potential for cracking the screen) and them cutting off the ECU chastity belt and opening up the harness to back probe the power feeds.
  8. Re: 2012 Passat b7 2.0tdi Cuts Out
    Mar 2022
    Burton upon Trent
    Thanks both!
    I have not yet ckeced alternator/rectifier function. But the battery is about 3 months old and is fully charged.
    Wipers and scuttle trim is off already, and I've started hacksawing a slot into one of the shear headed bolts on the anti tamper ECU frame. Hackswa blade is blunt. Went to Notts to work over the weekend at the house Im renovating and forgot to bring my angle grinder back.... most of my tools are there.
    Its reassuring to hear Im heading in the right direction as I wasn't too confident.
    Very helpful to read the description of the fans and why they turn on!
    I'll report back when I got further.
  9. Re: 2012 Passat b7 2.0tdi Cuts Out
    130 Post(s)
    1972 Post(s)
    Did you fit an AGM battery equivalent to a 096 specification and code it into the battery monitoring unit?
  1. wiring diagrams needed for 2012 a6 2.0tdi
    By zu11y in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 05-11-2020, 08:57 PM
  2. Please Help 2008 A4 B8 2.0Tdi - Intermittently wont start or starts and cuts out EPB, ESP & EML lights on
    By chrisk8117 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-08-2016, 08:47 PM
  3. Question Considering 2012 A8 3.0tdi. Feedback on real world MPG please
    By FortyPlus in forum A8 - S8 - V8
    Last Post: 08-11-2012, 07:56 AM
  4. 3.0TDI sometimes cuts out as I come to a halt
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-04-2010, 04:42 PM
  5. 2.0TDI Sport - Starts then cuts out after 500 yards
    By ibarker in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-01-2008, 02:05 PM
