Thread: 00575 map sensor fault?
  1. 00575 map sensor fault?
    Jun 2019
    Braintree
    96 1.9 AFN Starts and drives fine at low throttle inputs but give it the beans goes flat and has cut out a few times pulling away hard
    got code 00575 (MAP) also every now and then the brake servo seems not to work hard peddle little braking force very possible there related vacuum leak?failing servo? Sorry not familiar with these engines any help or advice welcome.
  2. Re: 00575 map sensor fault?
    130 Post(s)
    1972 Post(s)
    00575 - Intake Manifold Pressure: Control Limit Not Reached
    That is underboost almost always a result of a loss of vacuum, take the small pipe off the servo feed and apply suction, you should not be able to pull air and easily hold a vacuum... if not, trace the leak.
  3. Re: 00575 map sensor fault?
    Jun 2019
    Braintree
    Cheers crasher Vacuum leak was found and fixed brakes haven't played up since but still goes flat on hard acceleration no codes show what should I look at now?
  4. Re: 00575 map sensor fault?
    130 Post(s)
    1972 Post(s)
    Does it reset after cycling the ignition?
  5. Re: 00575 map sensor fault?
    Jun 2019
    Braintree
    Sorry crasher could you just confirm cycling the ignition at what point while driving or pull over and stop start again
  6. Re: 00575 map sensor fault?
    130 Post(s)
    1972 Post(s)
    At all, ignition off and back on, but doing this whilst driving is dangerous.
  1. Fault 00575 - Manifold Pressure Sensor
    By BadgerBoy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-09-2014, 07:12 AM
  2. Oil in my MAP sensor & 00575
    By jwalman in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-08-2010, 10:40 PM
  3. Fault cold 00575
    By tazzie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-05-2009, 06:32 PM
  4. 00575 manifold absolute pressure sensor, loose of boost and black smoke.
    By shaiboy_uk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-04-2009, 12:31 PM
