Thread: ELM327 OBDII Diagnostics
Results 1 to 8 of 8
  1. ELM327 OBDII Diagnostics
    Dec 2021
    Turkey
    Does anybody have any positive experience in using OBDII to read error codes, live data etc.?
    I bought an ELM327 Mini OBDII bluetooth reader and installed Android apps to my phone to read through it, but i cannot be successfull other than just reading speed, RPM, MAF value and 5 or 6 any other basic stuff.
    I need injector readings and error codes for example.
    There is also a DPF app for reading live soot volume but that app also failed.
    thanks in advance
    Audi a6 2009 3.0 TDI ASB
  2. Re: ELM327 OBDII Diagnostics
    Jul 2008
    Lisburn
    16 Post(s)
    which app? torque pro seems to be a good one but its been a while since i dabbled with my elm327.
    I have OBDeleven, it used to be really good but recently with software updates functions seem top be dropping off.
    I think they are more focusing on newer cars and the boy racer with joker lights and needle sweeps...
    there is no replacement for VAG com, VCDS, maybe do a shout out and there could be someone local to you to give you a hand.
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  3. Re: ELM327 OBDII Diagnostics
    Dec 2021
    Turkey
    I tried 6/7 apps which have ratings greater than 4 stars on Google Play. Basic readings are all possible with most of them but "Injector MissFires", "last regen time" or "injector compensation values" are all N/A.
    Thanks for your response. And yes VCDS seems necessary.
  4. Re: ELM327 OBDII Diagnostics
    Jul 2008
    Lisburn
    16 Post(s)
    As the wife is not loyal to any brand i also got a Foxwell NT530 - it was pricy at £150 but allows me to ad software for other manufactures as she upgrades for a modest £50 or so with free updates . i have Honda Landrover/jag on there so far - thinking of sticking on VW as the obdeleven seems to be loosing its shine.
    Stewart
  5. Re: ELM327 OBDII Diagnostics
    Sep 2012
    Romford, UK
    I ordered the below one couple of days ago. Will be delivered tomorrow. Seems to offer full VAG diagnostics and coding as per the info on the page and done you tube videos. It also comes with alligator clamps to use as a battery tester. I paid £26.
    Car OBD2 Code Reader Automotive VAG Full System Scanner Tool Battery Tester 3in1 | eBay
    There was one more in stock when I ordered, but right now it's out of stock.
    I also have a Bluetooth elm327 adapter. I find the Car Scanner app on Android very good. It can provide advanced diagnostics on some newer Audis but not for the C6.
  6. Re: ELM327 OBDII Diagnostics
    Jul 2008
    Lisburn
    16 Post(s)
    Let us know how it goes - i am a bit sus you get a full system scanner for £26
    Stewart
  7. Re: ELM327 OBDII Diagnostics
    Sep 2012
    Romford, UK
    Quote Originally Posted by swwalker View Post
    I was only after a battery analyser and bumped into this on eBay. I am not really sure if I will use any of the offer functions.
    Below is a YouTube video with the demo of the product. It may make more sense to you than me.
    JDiag V600 VAG SCAN TOOL Full System diagnosis and Service reset maintenance. - YouTube
    Sent from my XQ-AT51 using Tapatalk
  8. Re: ELM327 OBDII Diagnostics
    Jul 2008
    Lisburn
    16 Post(s)
    doesn't look bad for £26 they have cut corners on the software as such its a bit like the c110 i had for BMW - it lists everything control unit possible for every iteration of build, not what is only fitted to the car its plugged into.
    The c110 didnt have the quick scan function, you had to scan it and see if it was fitted and if there was a fault code. It was very time consuming i would like to see how the quick auto scan feature works.
    you could be onto a winner for someone who only tinkers now and then making VAG com too dear.
    good luck
    Stewart
  1. OBDII ELM327, Scangauge II and 2008 2.0 TFSI
    By Raj_UK in forum 2.0T, TSI and TFSI - Engine
    Last Post: 28-04-2015, 11:45 PM
  2. OBDII ELM327, Scangauge II and 2008 2.0 TFSI
    By Raj_UK in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 28-04-2015, 04:10 PM
  3. A3 OBDII + Can
    By jonathanfenton in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 24-05-2012, 07:41 PM
  4. ELM327 Question
    By daclyn in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 18-06-2010, 07:20 PM
  5. 1998 A4 & ELM327/Vag Com Problem
    By ianjay1es in forum VCDS - General Questions
    Last Post: 15-07-2008, 09:31 AM
