Thread: MK7 Golf water ingress locations
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: MK7 Golf water ingress locations
    Apr 2024
    south wales
    Air con not getting cold, it does appear to drain on the outside. I have booked it in for a service at My local VW dealer. We've not had much if any rain locally today & yet after drying my front passenger floor this morning, it is once again damp ! In the 18 months that I have had the car I haven't had to put any coolant in. I have gone over all the common points of water ingress. Has anyone got any thoughts on what else to do ?
  2. Re: MK7 Golf water ingress locations
    Apr 2024
    south wales
    I think that the underlay in the car is still slightly damp & the heat from the plastic heating duct is causing some condensation to build up in the floor. The only thing that I can think of is to possibly remove the underlay & either replace it or leave it dry out completely 🤔 ? Does anyone have any thoughts on this ? I'm quite sure that no water is leaking in, but will probably try some leak detection fluid. The car is a great drive, but this issue is annoying.
  3. Re: MK7 Golf water ingress locations
    Apr 2009
    Surrey
    177 Post(s)
    If you are able to park the car off the road you could try leaving a dehumidifier or carpet snail running in the car to help dry the carpet sound deadening out
  4. Re: MK7 Golf water ingress locations
    Apr 2024
    south wales
    I have tried using a small dehumidifier for a short time, but nothing is being drawn out of the carpet/underlay. Maybe try a dehumidifier overnight ? Or it's getting to the point where I remove it & dry on the radiator. It seems whenever I use a fan heater to dry the underlay out & then leave it cool down naturally that whatever moisture is left in the underlay. Once I drive it & heating is on, then it seems to "sweat" & I get condensation. I'm 99.99 % positive that it isn't leaking any water now !
  5. Re: MK7 Golf water ingress locations
    Apr 2009
    Surrey
    177 Post(s)
    Quote Originally Posted by vw mk7 golf View Post
    Yes at least overnight. May take several sessions to get it clear. If you have a wet vacuum try and use that to suck out as much water as possible
  6. Re: MK7 Golf water ingress locations
    Apr 2024
    south wales
    cheers for the advice, as I don't have a big dehumidifier I'm going to try a bowl of baking soda & put some fans in the car to help. I will update in a few days hopefully 👍
  7. Re: MK7 Golf water ingress locations
    #17
    Apr 2024
    south wales
    just a little update. With all the heavy rain lately, there has been no water ingress into the car. I have washed it once & checked under the carpets & all appears to be dry. In my opinion the original problem was the rear speaker seals, I have replaced the speakers, but will probably run a bead of sealant around them as a precaution. As I have heard that even the mk8 golf has rear speaker issues. I used a dehumidifier & fans to dry what dampness was left after I pulled as much water as possible out of the car ! It's shocking though to hear of mk8 golf's having similar issues !
  8. Re: MK7 Golf water ingress locations
    #18
    120 Post(s)
    1916 Post(s)
    Yes, they still leak. Wait until some salty water finds its way into the electrics of an high voltage VAG product... smokin!
  1. Golf Mk iv 2000W Water Ingress
    By Peter Sproston in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2011, 06:26 PM
  2. MK5 Golf - water ingress through top of windscreen ?
    By IPreferMyJag in forum Golf MK5 - 2004 - 2009
    Last Post: 06-12-2009, 10:03 AM
  3. Question Water ingress driver side door 3door golf MK4
    By Rubyturner in forum Golf MK4 - 1999 - 2004
    Last Post: 03-09-2009, 05:47 PM
  4. Golf water ingress problem
    By Adrian Wood in forum New Member Introductions
    Last Post: 09-08-2009, 11:11 PM
  5. Water ingress in Boot on Golf Mk 4
    By tobert in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 29-05-2007, 12:11 PM
