Thread: Mk5 tdi rear brake lights constanility on
  1. Mk5 tdi rear brake lights constanility on
    Sep 2021
    London
    HI,
    I need some help with my mk5 TDI 2004, I am having issues with my rear brake lights constantly on
    so the issue is both rear lights constantly on and middle brake light on the window, when the ignition is off and you apply and you apply the brakes they all seem to be working.
    Changed the brake switch, checked fuses, checked VCDS cleared codes,
    on VCDS keeps showing 16995
    VAG 16955 - Brake Light Switch (F): Implausible Signal - intractable problem,
    on the insurtument cluster the glowplug light is flashing, the rear disc pads light isnt going also and they have been changed.
    thanks for your help.
  2. Re: Mk5 tdi rear brake lights constanility on
    130 Post(s)
    1972 Post(s)
    I have had this before on very early Golf 5 and it was the clutch pedal Hall Effect sensor, disconnect the switch, a pain to get your hand down to, and see if the brake lights work correctly.
  1. Please Help right indicator, rear fog light, rear windscreen heater, and brake lights!!!!
    By sutts85 in forum Early Passat Forum - Pre 97
    Last Post: 17-08-2011, 12:13 AM
  2. Brake lights. Rear lights. Not both
    By _sc_ in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-05-2010, 05:22 PM
  3. Please Help Rear brake lights
    By chapmanmx in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 12-01-2010, 06:21 PM
  4. 2003 Audi A4-Brake Lights & Rear Lights
    By csheehy35 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-11-2008, 10:12 PM
  5. A3 - Rear and Brake Lights
    By ronakc in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 26-02-2008, 11:37 PM
