Thread: Torque reduction due to exhaust temperature 1
  1. Torque reduction due to exhaust temperature 1
    Feb 2007
    Having problems with my A6 C7 CNHA with no boost. No fault codes. Loads of black smoke out of the exhaust when you’d expect it to be on boost. Checked EGR valves, turbo, turbo actuator etc.
    Had a Exhaust Bank 1 S1 Short to Ground code last week which set glow plug light flashing. Reset, not reoccurred.
    Just noticed same sensor is only reading 40c whereas next one is 300, next 280 and next 240. I’d expect S1 to be the hottest.
    Also noticed in measuring values that ‘torque reduction due to exhaust temperature’ has a value of ‘1’ next to it. Does that mean it’s active?
    If so, do we reckon the under reading sensors could be the cause?
  2. Re: Torque reduction due to exhaust temperature 1
    131 Post(s)
    1973 Post(s)
    During a forced regen I have seen sensor 4 reading 900 degrees c... I would replace sensor one and see what happens.
  3. Re: Torque reduction due to exhaust temperature 1
    Feb 2007
    I’ll replace the sensor but does anybody know what this torque reduction thing normally reads on a good engine?
  1. P246e bank 1 exhaust gas temperature sensor 4
    By Dorra69 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-04-2023, 12:01 PM
  2. P242C Exhaust Gas Temperature Sensor B1 S3
    By billa79 in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 05-05-2019, 09:13 PM
  3. Please Help Exhaust gas temperature 1 say 18.0 °C
    By Fredrik Torsvik in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 22-05-2013, 09:50 AM
  4. EML on. Which exhaust gas temperature sensor ? Please Help
    By Radders567 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-09-2012, 04:34 PM
  5. Exhaust Gas Temperature Sensor fault
    By looney in forum VCDS - Help Requests
    Last Post: 20-06-2012, 09:03 PM
