Thread: Testing the high pressure fuel pump/troubleshooting
  1. Testing the high pressure fuel pump/troubleshooting
    Jun 2021
    clydebank
    Hi guys,
    Not had a lot of luck getting responses to my threads but here goes.
    I'm wondering if anyone knows of a way of testing if the high pressure fuel pump is actually working? on my 3.0 tdi b7 quattro
    I have zero pressure according to a diagnostic system(not VagCom) that a mechanic tried, He also cleared all faults. This was after I was tracking down an oil leak which ended up being the oil cooler.
    All together I've had the entire fuel system inside the engine bay off the car ,the pump, the injectors, the overflow return pipes and I replaced the fuel filter while I was sorting out the oil cooler.
    Once everything was back on the car I tried starting the car but was unaware that the fuel filter required to be filled with diesel and that Vagcom was required to activate the lift pump. I've never worked on diesels before and I have to say I really hate them after this.
    So is it possible that I've damaged the high pressure pump?
    Pretty sure I've spent about a grand replacing stuff and hours and hours of my time on this car ,As well as a lot of time wasted waiting on parts to arrive . And to add insult to injury today I took the car off the axle stands its been sat on for 3 weeks and the near side rear spring has managed to break.
    This is the 2nd Audi I've owned and I swear I'm cursed when it comes to them.
    Any ideas where to go from here would be greatly appreciated
    Rob
  2. Re: Testing the high pressure fuel pump/troubleshooting
    131 Post(s)
    1973 Post(s)
    If you cranked the car over a lot with the HPFP dry then you are likely to have damaged it and this throws metal particles throughout the fuel system front to back and they get stuck in the injectors. This is done by operating the starter for approx. 13 seconds with the N275 fuel pressure regulator disconnected so the engine does not start, do this three times waiting 20 seconds between each cycle. Audi does not give a procedure for testing the pump but you can see the pressure in measuring blocks.
  3. Re: Testing the high pressure fuel pump/troubleshooting
    Jun 2021
    clydebank
    thanks for the reply crasher.
    My vagcom arrived today and it found two faults with the n290 valve004738 valve for metering fuel-p1282-001-open circuit-intermittent
    004728 valve for metering fuel-p1278-001-short to plus-intermittent
    Also running vagcom whilst starting the engine showed fuel pressure hitting 540 bar but on checking the rails only a drip comes out
    So i'm wondering where vagcom is finding 540 bar from? If its the right hand rail (as you looking at the engine) then why does only a dribble of fuel come out?
  4. Re: Testing the high pressure fuel pump/troubleshooting
    131 Post(s)
    1973 Post(s)
    Could you post the code scan
  5. Re: Testing the high pressure fuel pump/troubleshooting
    Jan 2009
    Nuneaton England
    6 Post(s)
    Quote Originally Posted by fulham4eva View Post
    Did you solve the problem?
  6. Re: Testing the high pressure fuel pump/troubleshooting
    Dec 2023
    Edinburgh
    Fulham4eva what was the issue in the end ?? I'm having the exact same thing right now with my a5 3.0 TDI
    TIA
    Brodie
  1. Question Can a High Pressure Fuel Pump just fall off?
    By matapaca in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-07-2021, 01:10 PM
  2. 2.0 FSI High Pressure Fuel Pump Refurb
    By AudiYaDo? in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-06-2021, 11:25 AM
  3. Please Help GT TDI 170, hesitation, High pressure fuel pump failure/fuel contamination
    By Bruceakm in forum Golf MK5 - 2004 - 2009
    Last Post: 05-03-2014, 08:50 PM
  4. High pressure Fuel Pump Problems on 1.6 TDI
    By bdb in forum Golf MK6 - 2009 - 2013
    Last Post: 17-12-2010, 10:25 AM
  5. High pressure fuel pump replacement I THINK?
    By MathewRB in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-12-2008, 09:16 PM
