Thread: 3.0 tdi throttle valve issue
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. 3.0 tdi throttle valve issue
    Dec 2008
    Stoke-on-Trent
    hope someone can help.
    It all started last week where I was getting a pulsing from the engine, I knew it would be the gears on the throttle valve so i ordered a replacement set.
    Unfortunately the car decided otherwise and lost power on the M6, it didnt stall just lost all power.
    I stopped the engine and tried restarting, it fired but was only running at 400rpm, and no response from the throttle.
    Had it towed back and waited for replacement gears to arrive. I wipped off the throttle valve and as expected the gears were totalled chewed.
    New gears fitted and a clean whilst I had it apart, good movement from the gear operating the butterfly. Popped it back on and wonts start. Checked with my vcds and got this
    004203 - Throttle Valve
    P106B - 002 - Stuck or difficult to move - Intermittent
    I did scan it before initially took it off and had the same error.
    I unbolted the throttle valve and left it connected to the loom so I could see the butterfly doing its initialisation.
    It only opened about 25% and buzzed.
    Checked gears etc and no change.
    Bought a new throttle body and fitted it today, initialisation was correct on first key turn , fully closed and then open.
    bugger still wont start, cleared all the dtc's and rescanned but it not even attempting to start, got a battery booster connected to ensure its got full power.
    My normal mechanic (my cousin, cant get me in until mid next week) and ive been without a car all week. Its parked 15mins away in my caravan storage yard.
    Anyone got any tips ?
    thanks
    Simon
    2007 Avant 3.0 tdi Le Mans
  2. Re: 3.0 tdi throttle valve issue
    Jul 2008
    Lisburn
    16 Post(s)
    what codes did you get when you re-scanned? is there an output test for it in vcds?
    not even attempting? cant just see from here lol do you mean no response from key - engine wont crank, or cranks at low RPM......?
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  3. Re: 3.0 tdi throttle valve issue
    Dec 2008
    Stoke-on-Trent
    cant see any output test for it at all and I think the calibrations Ive seen are all for petrol versions
    engine cranks fine, just wont start
    not always but sometimes the same code comes back as in first thread
  4. Re: 3.0 tdi throttle valve issue
    Jul 2008
    Lisburn
    16 Post(s)
    did you check ross tech website it could give some direction. Are all the electrical connections in good order, a bad one could mean its not getting enough juice to fully function.
    Stewart
  5. Re: 3.0 tdi throttle valve issue
    Dec 2008
    Stoke-on-Trent
    the initial movement of the butterfly valve looks correct, ie as soon as you turn the ignition on it does a full close and back to open
  6. Re: 3.0 tdi throttle valve issue
    Dec 2008
    Stoke-on-Trent
    Ive found this
    Ill have a walk done an d try it
    Special Notes
    • When found on 3.0l CR-TDI (i.e. BKS/BUG) or 4.2l CR-TDI (BVN), the Learning Values have to be cleared after replacing the Throttle Body Control Module.
      • DO NOT CLEAR LEARNED VALUES IF YOU HAVE NOT REPLACED THE THROTTLE BODY CONTROL MODULE! Otherwise the proper values are being cleared and incorrect values are being learned.
    [Select]
    [01 - Engine] (for Bank 1/J388) or [11 - Engine 2] (for Bank 2/J544)
    [Coding-II - 11]
    • Enable the Learning Procedure by Entering 10021.
    [Do It!]
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    • Switch the Ignition OFF.
    • Switch the Ignition ON for 1 Second, then turn it OFF immediately.
    • Wait at least 30 Seconds, then switch the Ignition ON again.
    • Now Check if all remaining fault codes can be cleared.
  7. Re: 3.0 tdi throttle valve issue
    Dec 2008
    Stoke-on-Trent
    well ive tried that and no joy
    scan only shows issues with glow plugs which ive had for ages
    found a throttle body test and that seems to work fine
    Im baffled !!!!!!!
  8. Re: 3.0 tdi throttle valve issue
    Dec 2008
    Stoke-on-Trent
    If it was an immobiliser issue would that log up in vcds?
    or fuel supply problem?
  9. Re: 3.0 tdi throttle valve issue
    Dec 2007
    Dudley, West Midlands
    44 Post(s)
    I replaced mine with a new replacement unit i had no issues it just worked, i did not replace gears i swapped the throttle body.
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  10. Re: 3.0 tdi throttle valve issue
    Dec 2008
    Stoke-on-Trent
    Yes I bought a brand new throttle body this morning and have that fitted now
    gave up on the old one, I think there was a problem with it beyond the stripped gears
  1. How To How I fixed my Audi A6 throttle issue with "Throttle Reset OBD2" ELM327
    By MrMikeR in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-04-2022, 04:39 PM
  2. How To How I fixed my Audi A6 throttle issue with "Throttle Reset OBD2" ELM327
    By MrMikeR in forum Chat - Completely Off Topic
    Last Post: 01-03-2021, 01:33 AM
  3. Throttle Valve.
    By fmc51 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-04-2014, 02:27 PM
  4. EGR Valve/Throttle Valve, where is Fuse F8??
    By robtuke in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-11-2013, 07:43 AM
  5. Throttle valve/actuator issue
    By staffop1 in forum VCDS - Help Requests
    Last Post: 01-12-2010, 11:57 PM
