Thread: Audi S3 8V 2018 Misfire when warm Fuel quality inadequate
  1. Audi S3 8V 2018 Misfire when warm Fuel quality inadequate
    Aug 2016
    My car just came out of warranty and now the problems start.....
    So the car has developed an issue when the engine reaches temperature, the engine idles rough and the EML light flashes and then turns solid. I connected VCDS to the car and it appears with a few fault codes. These were
    1) Cylinder 2 misfire detected
    2) Fuel quality inadequate
    This has happened 5-6 times now with the problem in cylinder 2 mainly and with cylinder 2 and 3 once. Initially I thought it may be the ignition coils so i swapped them between cylinder 1 and 2. However the problem still persisted in Cylinder 2 only. So i then swapped the spark plugs. Still the same issue. Wondering what to do next. How could Fuel quality inadequate error be affecting cylinder 2 only? swap injector next? Any ideas?
    Many thanks in advance
    full VCDS scan below, can has custom exhaust with flap open so Valve for Exhaust Flap error related to that
    Code:
    Tuesday,20,July,2021,19:25:46:40398
    VCDS Version: 21.3.0.0 (x64)  HEX-V2 CB: 0.4543.4
    Data version: 20210226 DS325.0
    www.Ross-Tech.com
    VIN: DELETED License Plate: S3 8V 2018
    Mileage: 41207km-25604mi   Repair Order:
    Chassis Type: 8V-AU37 (3Q0)
    Scan: 01 02 03 08 09 10 14 15 17 19 22 29 39 42 44 47 4B 52 5F A9
              BB BC D6 D7
    VIN: DELETED  Mileage: 41207km-25604miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    14-Susp. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    22-AWD -- Status: OK 0000
    29-Left Light -- Status: OK 0000
    39-Right Light -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4B-Multifunc. Module -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    A9-Struct. Borne Sound -- Status: OK 0000
    BB-Door Rear Drv -- Status: OK 0000
    BC-Door Rear Pass -- Status: OK 0000
    D6-Light Ctrl Left 2 -- Status: OK 0000
    D7-Light Ctrl Right 2 -- Status: OK 0000
    Address 01: Engine (J623-DNUE)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 259 N    HW: 06K 907 425 J
       Component: 2.0l R4 TFSI  H13 0001
       Revision: --H13---
       Coding: 0A2540122426010B2004
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM20TFS0208V0906259N 001002
       ROD: EV_ECM20TFS0208V0906259N.rod
       VCID: 4BC39B69B34CCCB32A1-801E
    6 Faults Found:
    21388 - Valve for Exhaust Flap 1 (N321)
              P3019 00 [047] - Open Circuit
              Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 41207 km
                        Date: 2021.07.19
                        Time: 17:48:42
                        Engine RPM: 0.00 /min
                        Normed load value: 0.0 %
                        Vehicle speed: 0 km/h
                        Coolant temperature: 35 °C
                        Intake air temperature: 34 °C
                        Ambient air pressure: 1010 mbar
                        Voltage terminal 30: 11.933 V
                        Unlearning counter according OBD: 40
                        Engine: operating status: ES
                        STATE_LS_SAE[1]: INI
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 102 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.899 V
                        FAC_TPS_1_SAE: 16.015625 %
                        FUP_H_SAE: 18710.0 kPa
    21399 - Valve for Exhaust Flap 2 (N322)
              P3023 00 [047] - Open Circuit
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 41207 km
                        Date: 2021.07.19
                        Time: 17:48:42
                        T_AST_SAE: 0 s
    20316 - Fuel Quality
              P30C0 00 [101] - Inadequate
              Not Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 41207 km
                        Date: 2021.07.19
                        Time: 18:36:38
                        Engine RPM: 1124.75 /min
                        Normed load value: 45.5 %
                        Coolant temperature: 101 °C
                        Intake air temperature: 39 °C
                        Voltage terminal 30: 14.238 V
                        Engine: operating status: PL
                        STATE_LS_SAE[1]: CL
                        T_AST_SAE: 327 s
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.026 V
                        FAC_TPS_1_SAE: 14.453125 %
                        FUP_H_SAE: 12160.0 kPa
    15131 - Cylinder 3
              P0303 00 [237] - Misfire Detected
              MIL ON - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 41207 km
                        Date: 2021.07.20
                        Time: 13:16:01
                        Engine RPM: 1361.75 /min
                        Normed load value: 26.7 %
                        Coolant temperature: 24 °C
                        Intake air temperature: 28 °C
                        Voltage terminal 30: 13.183 V
                        Engine: operating status: IS
                        N_TOOTH: 1350 /min
                        T_AST_SAE: 4 s
                        Engine oil temperature: 24.0 °C
                        STATE_LS_SAE[1]: OL_CDN
                        FUP_H_SAE: 19860.0 kPa
                        FUP_EFP_MES: 5999.25 hPa
    15128 - Cylinder 2
              P0302 00 [237] - Misfire Detected
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 41207 km
                        Date: 2021.07.19
                        Time: 18:39:24
                        Engine RPM: 744.75 /min
                        Normed load value: 23.1 %
                        Coolant temperature: 95 °C
                        Intake air temperature: 40 °C
                        Voltage terminal 30: 13.886 V
                        N_TOOTH: 730 /min
                        T_AST_SAE: 10 s
                        Engine oil temperature: 59.0 °C
                        STATE_LS_SAE[1]: CL
                        FUP_H_SAE: 14760.0 kPa
    15137 - Random/Multiple Cylinder Misfire Detected
              P0300 00 [101] - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 41207 km
                        Date: 2021.07.20
                        Time: 13:16:01
                        N_TOOTH: 1350 /min
                        T_AST_SAE: 4 s
    Readiness: 1010 0001
    Address 02: Auto Trans (J743)       Labels:. 0BH-927-711.clb
       Part No SW: 0GC 300 014 B    HW: 0GC 927 711 H
       Component: GSG DQ381     H06 2404
       Revision: 00H06V07
       Coding: 0014
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_TCMDQ381061 001
       ROD: EV_TCMDQ381061_VW37.rod
       VCID: 241110D57E5223CBCBB-8070
       No subsystems:
    No fault code found.
    Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
       Part No SW: 8V0 614 517 D    HW: 8V0 614 517 C
       Component: ESC           H25 0640
       Revision: 00000000    Serial number: 62578000000094
       Coding: 319C938D549A23AF8B960B644099698CC92AC4D1D0029677024150F48208420000000012121212B835351919323200
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 037008
       ROD: EV_Brake1UDSContiMK100IPB_037_AU37.rod
       VCID: 3A2DCEADECD6453B817-806E
    Address 08: Auto HVAC (E87)       Labels:| 8V0-820-043.clb
       Part No SW: 8V0 820 043 AF    HW: 8V0 820 043 AF
       Component: AC Automat    H03 0150
       Revision: 20003000    Serial number: 00000001687691
       Coding: 03100014000000011000000000001100
       ASAM Dataset: EV_AirCondiFrontVaAU37X 008025
       ROD: EV_AirCondiFrontVaAU37X_008.rod
       VCID: 76B51A9D984EE15BA5F-8022
       Humidity sensor: exterior:
       Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Component: AQ_Hum_Sensor  H02 0007
       Serial number: C870575900PAG0MUFU03
    1 Fault Found:
    262914 - Refrigerant Pressure
              B10AB F0 [009] - Too Low
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 8
                        Reset counter: 140
                        Mileage: 41205 km
                        Date: 2021.07.11
                        Time: 20:04:31
                        Outside temperature: 20.5 °C
                        Compressor current: actual value: 0.000 A
                        Temperature downstream of evaporator: 33.4 °C
                        Refrigerant pressure: 1.0 bar
                        System run time-Engine running time: 0 s
                        System run time-Terminal 15 on: 232 s
    Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
       Part No SW: 5Q0 937 084 DC    HW: 5Q0 937 084 CF
       Component: BCM MQBAB M+  H38 0273
       Serial number: 00001831600754
       Coding: 000000000000000000000000000000000000000000000000000000000000
       ASAM Dataset: EV_BCMMQB 019001
       ROD: EV_BCMBOSCH_019.rod
       VCID: 7CA108B5A662BB0BD3B-8028
       Wiper motor control module:
       Subsystem 1 - Part No SW: 8V2 955 119 C    HW: 8V2 955 119 A  Labels: 5QX-955-119-V1.CLB
       Component: WWS371 180930  043 0585
       Serial number:         181010012401
       Coding: 0A47F7
       Rain/Light Recognition Sensor:
       Subsystem 2 - Part No SW: 81A 955 547 A    HW: 81A 955 547
       Component: G397_RLFS  H06 0002
       Serial number: 21699034X81A955547A0
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
       Component: E1 - LDS MQB  H06 0032
       Serial number: 05 09 2018  20000003
       Anti-theft alarm system sensor:
       Subsystem 4 - Part No SW: 8V0 951 177     HW: 5Q0 951 172
       Component: Sensor, DWA  005 0316
       Serial number: 000000000ZY182803GWD
       Alarm horn:
       Subsystem 5 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
       Component: Sirene, DWA  005 0314
       Serial number: 00000000000045681292
       Sunroof control module:
       Subsystem 6 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS73.404  H04 0005
       Serial number: 0000FST0026S1KL00000
       Coding: 901E00
       Steering Column Switch:
       Subsystem 7 - Part No SW: 82A 953 521 AC    HW: 5Q1 953 549
       Component: J527 SMLS MQB  004 0060
       Serial number: 00000014111808491006
    2 Faults Found:
    721416 - Switch for Sunroof
              B13C4 29 [008] - Signal Implausible
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 4
                        Reset counter: 180
                        Mileage: 41205 km
                        Date: 2021.07.18
                        Time: 15:37:44
    721420 - Switch for Sunroof
              B13C4 01 [008] - Electrical Failure
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 4
                        Reset counter: 180
                        Mileage: 41205 km
                        Date: 2021.07.18
                        Time: 15:37:44
    Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-283.clb
       Part No SW: 5QA 919 283 C    HW: 5QA 919 283
       Component: PDC 4 KanalH07 0050
       Serial number: 000308419618302
       Coding: 0600040011
       ASAM Dataset: EV_EPHVA14AU3700000 009037
       ROD: EV_EPHVA14AU3700000_009_AU37.rod
       VCID: 4ACD9E6DBC36D5BB117-801E
    Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
       Part No SW: 8V0 907 376 H    HW: 8V0 907 376 F
       Component: DAEMPFUNGS-SG H11 0083
       Serial number:       010918023
       ASAM Dataset: EV_AudiMagneRide 003007
       ROD: EV_AudiMagneRide_003.rod
       VCID: 46D5AA5DA82E31DBF5F-8012
    Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
       Part No SW: 5Q0 959 655 BT    HW: 5Q0 959 655 BT
       Component: AirbagVW21    006 0403
       Serial number: 003FNR4RJCGH
       Coding: 98CCC0000C0000005C5400CA00C8000000C5
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
       ROD: EV_AirbaVW20SMEVW37X_VW37.rod
       VCID: 13734309ABFC5473221-8046
       Crash sensor for side airbag: driver side:
       Subsystem 1 - Part No SW: -----------    HW: 480 001 311 18
       Component: SideSensor_Df  001 0887
       Serial number: 35700000000B26F0653K
       Coding: 2D2D2D
       Front Passenger's Side Airbag Crash Sensor:
       Subsystem 2 - Part No SW: -----------    HW: 480 001 311 18
       Component: SideSensor_Pf  001 0887
       Serial number: 358000000000B9C4A53R
       Coding: 2D2D2D
       Rear Side Airbag Crash Sensor (on driver's side):
       Subsystem 3 - Part No SW: -----------    HW: 480 400 511 18
       Component: SideSensor_Dr  004 6149
       Serial number: 3510001062BF5A74531-
       Coding: 2D2D2D
       Passenger side rear thorax airbag crash sensor:
       Subsystem 4 - Part No SW: -----------    HW: 480 401 311 18
       Component: SideSensor_Pr  003 6149
       Serial number: 3520001B32C6240336EY
       Coding: 2D2D2D
       Crash sensor for front airbag: driver side:
       Subsystem 5 - Part No SW: -----------    HW: 480 401 207 12
       Component: FrontSensor_D  001 6149
       Serial number: 3550002A90BE4C351312
       Coding: 2D2D2D
       Driver's side crash data pedestrian protection:
       Subsystem 6 - Part No SW: -----------    HW: 480 402 910 18
       Component: PedP_Sensor_D  003 6149
       Serial number: 2280001A32C3E42367C5
       Coding: 2D2D2D
       Passenger's side crash data pedestrian protection:
       Subsystem 7 - Part No SW: -----------    HW: 480 402 910 18
       Component: PedP_Sensor_P  003 6149
       Serial number: 2290001A32C3E422319-
       Coding: 2D2D2D
       Driver's side crash data pedestrian protection 2:
       Subsystem 8 - Part No SW: -----------    HW: 480 002 010 18
       Component: PedPSensor_D2  001 0887
       Serial number: I0M000000001FB98A43F
       Coding: 2D2D2D
       Passenger's side crash data pedestrian protection 2:
       Subsystem 9 - Part No SW: -----------    HW: 480 002 010 18
       Component: PedPSensor_P2  001 0887
       Serial number: I0N000000000FB98A43F
       Coding: 2D2D2D
    Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
       Part No SW: 8V0 920 790 B    HW: 8V0 920 790 B
       Component: FBenRDW       H19 0108
       Coding: 24AD18423B8006000101E8001000000000000000
       ASAM Dataset: EV_DashBoardFPKAU37X 001032
       ROD: EV_DashBoardFPKAU37X.rod
       VCID: 3B23CBA9E3EC7C339A1-806E
    Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
       Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
       Component: GW MQB High   521 5366
       Serial number: 04111810520790
       Coding: 030100043F085A005B00826ABC0B00000001010000000000000000000000
       ASAM Dataset: EV_GatewNF 013025
       ROD: EV_GatewNF_AU37.rod
       VCID: 6E8532FDE01ED99B6DF-803A
       Generator:
       Component: 0-01-13-01-04
       Multifunction steering wheel control module:
       Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
       Component: J453 MFL  H04 0004
       Serial number: 20181105040221 20535
       Battery Monitoring Control Module:
       Subsystem 3 - Part No SW: 5Q0 915 181 J    HW: 5Q0 915 181 J
       Component: J367-BDMConti  H03 1050
       Serial number: 758860029118102600EE
    Address 22: AWD (J492)       Labels:* 0CQ-907-554.clb
       Part No SW: 0CQ 907 554 K    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7762
       Serial number: HA1-00016.08.18
       Coding: 0001
       ASAM Dataset: EV_AllWheelContrHA1VW37X 002015
       ROD: EV_AllWheelContrHA1VW37X.rod
       VCID: 4DC795714D58C283345-8018
    Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
       Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
       Component: LCM_MQB       H07 0022
       ASAM Dataset: EV_LCMLeftCONTIAU426 001009
       ROD: EV_LCMLeftCONTIAU426_VW41.rod
       VCID: 42DDB64D84060DFBD97-8016
    Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
       ASAM Dataset: EV_LCMRightCONTIAU426 001009
    Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
       Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
       Component: TSG FS001 0287
       Serial number: YE007RK217222
       Coding: 005E8A205001000000001002
       ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001010
       ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
       VCID: 44D1B0559E1203CBEBB-8010
    Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
       Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
       Component: EPS_MQB_ZFLS  507 5082
       Coding: 811F0000
       ASAM Dataset: EV_SteerAssisMQB 015157
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 3C21C8B5E6E27B0B93B-8068
    Address 47: Sound System (J525)       Labels:| 81A-035-466.clb
       Part No SW: 81A 035 466 B    HW: 81A 035 466
       Component: MIB2_amp_P_A3 H10 0440
       Revision: 00000001    Serial number: AUZ8ZAJ5F01YCGF
       Coding: 0173030000AAAA2AAA0000010000
       ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
       ROD: EV_AMPMst16C9Gen2ALPI.rod
    Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
       Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
       Component: FCM MQB Low   002 0345
       Serial number: 03111810523627
       Coding: 000000050900147606102B03020000000000000000000000000000000000
       ASAM Dataset: EV_MultiModulContiVW48X 002006
       ROD: EV_MultiModulContiVW48X_002_VW41.rod
       VCID: 3537DD91C5C8AA436C5-8060
    Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
       Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
       Component: TSG BFS001 0287
       Serial number: YE007RK11660C
       Coding: 005E82205C01000000001002
       ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001010
       ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
       VCID: 43D3B3499B1C04F3D21-8016
    Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
       Part No SW: 8V1 035 035 C    HW: 8V1 035 035 C
       Component: MU-P-LND-EU   055 1326
       Serial number: A698K0JS029300
       Coding: 017351010000000011111102000A00312F0027E701700100DE
       ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
       ROD: EV_MUHig6C3Gen2HBAS_VW37.rod
       VCID: 323DE68D34A6BD7B497-8066
       Data carrier:
       Subsystem 1 - Part No SW: V03 959 802 DD    HW: -----------
       Component: ECE 2018/2019  --- 0169
       Serial number: --------------------
       Multimedia System 1:
       Subsystem 2 - Part No SW: 8V0 919 604 C    HW: 8V0 919 604 C
       Component: DU High  H49 0014
       Serial number: AUZ8Z9J1Y0EPHF
       Multimedia system control head:
       Subsystem 3 - Part No SW: 8V0 919 614 BJ    HW: 8V0 919 614 BJ
       Component: ControlUnit_H  H85 0855
       Serial number: ALJAL127061800050640
       Compact disc data bank:
       Subsystem 4 - Part No SW: V03 959 800 EG    HW: -----------
       Component: Gracenote2  --- 1017
    Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
       Part No SW: 8V0 907 159 A    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0001
       Serial number: 181005201404
       ASAM Dataset: EV_SoundActuaGen2AU64X 003010
       ROD: EV_SoundActuaGen2AU64X.rod
       VCID: 3E25C2BDF0FE691BBDF-806A
    Address BB: Door Rear Drv (J388)       Labels:* None
       Part No SW: 8W1 959 595 D    HW: 8W1 959 595 D
       Component: TSG HFS003 0187
       Serial number: YE007RJF01573
       Coding: 000C82204001000000001002
       ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001010
       ROD: EV_DCU2RearDriveMAXHCONT_VW41.rod
       VCID: 4EC5927D405EF99B4DF-801A
    Address BC: Door Rear Pass (J389)       Labels:* None
       Component: TSG HBFS003 0187
       Serial number: YE007RJF00911
       ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001010
       ROD: EV_DCU2RearPasseMAXHKLO_VW37.rod
    Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
       Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A
       Component: LED1L         H09 0008
       ASAM Dataset: EV_LEDModLeftMELCOAU736 001004
       ROD: EV_LEDModLeftMELCOAU736_VW37.rod
       VCID: 176B3719BF0478535E9-8042
    Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
       Component: LED1R         H09 0008
       ASAM Dataset: EV_LEDModRightMELCOAU736 001004
    End----(Elapsed Time: 01:34, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
  2. Re: Audi S3 8V 2018 Misfire when warm Fuel quality inadequate
    131 Post(s)
    1973 Post(s)
    Is it a DNUE engine as VCDS shows? If you had left the VIN I could have checked.
  3. Re: Audi S3 8V 2018 Misfire when warm Fuel quality inadequate
    Aug 2016
    its DNUE
  1. Audi A8 2018
    By Cooper82 in forum Buying a used VAG Group vehicle
    Last Post: 30-03-2019, 06:09 PM
  2. 1.6 Misfire loss of power when warm
    By lostaudi in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 19-09-2009, 08:49 PM
  3. Question Fuel quality and additives
    By Naseem in forum Chat - Anything with wheels
    Last Post: 08-02-2009, 12:19 AM
  4. Making your engine last - oil change vs fuel quality
    By TheMatador in forum Chat - Anything with wheels
    Last Post: 19-12-2008, 01:02 AM
  5. A-6/ Fuel quality & catalytic converters
    By cnu captains in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 10-08-2007, 02:50 PM
