Thread: How can I tell the difference between a multitronic and a s-tronic box externally.
Results 1 to 10 of 10
  1. How can I tell the difference between a multitronic and a s-tronic box externally.
    Apr 2012
    Ireland
    Hi All
    Looking for some help please, been away from Audi for a few years now but now looking at purchasing a a6 c7 model either in saloon or avant and have been reading of issues with the multitronic boxes so would instead will go for s-tronic box my question is can you tell from looking at the car externally if it has a multitronic box or a s-tronic box,some people comment if it has the twin exhaust to the left side it is multitronic and if it has the exhaust pipe to the right and the left it is s-tronic is this TRUE.
    I have to look at a 2013 a6 avant 177bhp with only 68kms with full service history tomorrow and also a 2015 a6 sline st ultra tech pack 190bhp full service history and 137kms and sport function.
    all help is greatly appreiated.
  2. Re: How can I tell the difference between a multitronic and a s-tronic box externally.
    Mar 2013
    Reading
    31 Post(s)
    177 is a multi, 190 is s-tronic. Simple.
    Sent from my KB2003 using Tapatalk
  3. Re: How can I tell the difference between a multitronic and a s-tronic box externally.
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    Read all through this forum, do a search for multitronic problems, won't find ANY post 2011. Just make sure it's had its oil changes at 38k and your good to go.
  4. Re: How can I tell the difference between a multitronic and a s-tronic box externally.
    Jul 2016
    Chestfield kent
    81 Post(s)
    My understanding in relation to exhaust pipes is this, two together on the same side it is a 2L, two round one each side a 3L and face lift has one each side for any engine size. The model year will give an indication to which box except for the C7facelift which I understand is S-Tronic. This info is not in relation to S or RS models which have multiple exhausts, and I wish I owned...
    2015 FL S-line 2L ultra & 2003 225 TT Coupe
  5. Re: How can I tell the difference between a multitronic and a s-tronic box externally.
    Apr 2009
    Surrey
    178 Post(s)
    Quote Originally Posted by pablo66 View Post
    Hi All
    The 2013 car will definitely be CVT, assuming it is not a quattro, and the 2015 will be an s-tronic. The 2015 car should also be a facelift car (exhaust on each side exiting through a trapezoid hole in the bumper). The Ultra engine was introduced pre the facelift so, in the UK at least, there are some pre-facelift cars with the ultra engine and they have round exhausts one each sire. The 177 car will have 2 pipes on the left side. The 2015 car, which you say has the Tech Pack, will have the revised 4G/LTE sat nav system and the ability to display the map between the dials in the intrument panel
  6. Re: How can I tell the difference between a multitronic and a s-tronic box externally.
    Apr 2012
    Ireland
    Hi ,the 2013 is 177 it is not the face lift but has the exhaust pipes to the right and left in circular shape ?
    Looked at a 190 ultra 2014 se saloon today and it had the same exhaust to the rear as the 2013 we are looking at tomorrow so confused now is there a code in the chassis number the tells you if it is multitronic or s tronic.
  7. Re: How can I tell the difference between a multitronic and a s-tronic box externally.
    Apr 2009
    Surrey
    178 Post(s)
    If it is a 190 ultra then it is s-tronic. If it is a 2014 then unlikely to be a facelift version.
  8. Re: How can I tell the difference between a multitronic and a s-tronic box externally.
    Apr 2012
    Ireland
    Thanks for the reply
  9. Re: How can I tell the difference between a multitronic and a s-tronic box externally.
    Mar 2014
    Aylesbury Bucks
    21 Post(s)
    Look at the build code stickers and look for the gearbox code. You'll 100% know which type of gearbox is fitted without grovelling around underneath.
  10. Re: How can I tell the difference between a multitronic and a s-tronic box externally.
    Apr 2012
    Ireland
    Very happy to say I purchased the 2014 with s-tronic gearbox.
    All oil and filters changed and two oil changed in gearbox.
  1. S tronic, multitronic or manual
    By crazy4alfa in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 26-04-2016, 09:15 PM
  2. What gearbox do I have multitronic or S tronic
    By Q7quattro in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 16-05-2015, 08:33 AM
  3. Question DSG and S tronic difference?
    By JayA3sline in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 10-10-2011, 07:27 PM
  4. 170 TDi with S-tronic / Multitronic
    By NWSRG in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 16-09-2010, 08:33 AM
  5. Question Please explain the difference between multitronic and tiptronic boxes
    By A4B6Cab in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-03-2009, 12:34 PM
