Thread: VCDS fault help. A4 Avant B8 2.0 TDCI
  1. VCDS fault help. A4 Avant B8 2.0 TDCI
    May 2021
    South Yorkshire
    Hi All,
    Absolutely baffled by the issue I'm having, could really do with some support, so here goes -
    Car originally had a very bad idle, where the car revs jumped from 800 to 1200, very erratically. After some research, I decided to replace the fuel rail pressure regulator and the fuel rail pressure sensor. This cured the erratic idle problem, which was great, but brought another problem with it.
    The first issue was as soon as I put the 2 x new parts in, it instantly came up with error code 5244 - fuel pressure sensor P0193, had the flashing glow plug code on the dash and was constantly in limp mode.
    I changed the new fuel pressure sensor and put the old one back in. The idle was still fixed and the error code disappeared. The problem now is that the car runs fine until I get to 2,000 revs and then it goes into limp mode and gives me error code 5211 - fuel rail/system pressure too low P0087. This disappears every time I restart the car but returns when I accelerate over 2k revs.
    I'm not sure on what the next step is. It did bring up a previous error code of 4985 - glow plug circuit electrical fault P0672, I'm not sure if this is related. I tested the resistance of each glow plug and glow plug 2 was the only one that came back without showing a result on my multimeter (all other glow plugs was between 0.5 and 2 ohms, but number 2 didn't respond. (This code doesn't show now since I've reset codes).
    I will post the results from VCDS below.
    The 1st Log is when I replaced both parts. The 2nd log is after putting the old fuel pressure sensor back in.
    Thank you in advance
  2. Re: VCDS fault help. A4 Avant B8 2.0 TDCI
    May 2021
    South Yorkshire
    1st log with new parts
    Code:
    Sunday,02,May,2021,11:14:36:17849
    VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
    Data version: 20210226 DS325.0
    Ross-Tech: Home
    VIN: WAUZZZ8K5AA028022 License Plate: LB09 PFG
    Mileage: 253510km-157523mi Repair Order:
    Chassis Type: 8K-AU48 (8T0)
    Scan: 01 03 05 08 09 15 16 17 19 42 46 52 53 56 5F 62 72
    VIN: WAUZZZ8K5AA028022 Mileage: 253510km-157523miles
    01-Engine -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    Address 01: Engine (J623-CAGA) Labels:. 03L-906-019-CAG.clb
    Part No SW: 03L 906 022 NN HW: 03L 906 019 AL
    Component: R4 2.0l TDI H20 9980
    Revision: 25H20---
    Coding: 12194012232503080000
    Shop #: WSC 01286 386 08256
    ASAM Dataset: EV_ECM20TDI03L906022NN A02016
    ROD: EV_ECM20TDI03L906022NN.rod
    VCID: 7EA5F5F2A0732E6BFDF-802A
    1 Fault Found:
    5244 - Fuel Pressure Sensor (G247)
    P0193 00 [175] - Short to Plus
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 253519 km
    Date: 2021.05.02
    Time: 11:42:06
    Engine RPM: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 37 °C
    Intake air temperature: 18 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 11.640 V
    Unlearning counter according OBD: 40
    Co Eng st: COENG_READY
    Co Eng st-Test_Program_Co Eng st COMPU VERB UBYTE: 1
    Readiness: 1 1 0 0 1
    Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
    Part No SW: 8K0 907 379 AK HW: 8K0 907 379 AK
    Component: ESP8 front H04 0070
    Revision: -------- Serial number: --------------
    Coding: 160504
    Shop #: WSC 06325 000 00000
    VCID: 025D8102D40B4A8B997-8056
    No fault code found.
    Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
    Component: BCM2 1.1 H02 0321
    Revision: 00002001
    Coding: 031200
    VCID: 015F8E0ED10D519380D-8054
    Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
    Component: FBSAUDIB8 IDG H37 0060
    Serial number: 0509000033087015
    Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
    Component: J764 ELV MLB H36 0042
    Serial number: 0209000045978011
    Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
    Part No SW: 8T2 820 043 AF HW: 8T2 820 043 AF
    Component: KLIMA 3 ZONEN H08 0160
    Revision: D0000000 Serial number: 01300620091628
    Coding: 34340000
    VCID: 76B5EDD288C3662BA5F-8022
    Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
    Part No SW: 8K0 907 063 K HW: 8K0 907 063 K
    Component: BCM1 1.0 H25 0380
    Revision: 06025001 Serial number: 00000000411210
    Coding: 690040B10134A7010001000000005F5F001D06080400014100 0000
    VCID: 372B20D6CF49DF237E9-8062
    Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 200609 H05 0070
    Serial number: SWF09060200124
    Coding: 00F511
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
    Component: RLS H04 0003
    Serial number: 10519990
    Coding: 025028
    Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
    Component: E1 - LDS H08 0090
    Serial number: 00000000002206091403
    1 Fault Found:
    03351 - Bulb for DRL and Marker Light; Left
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 145
    Mileage: 253519 km
    Time Indication: 0
    Date: 2021.05.02
    Time: 11:42:00
    Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
    Part No SW: 8K0 959 655 G HW: 8K0 959 655 G
    Component: AirbagVW-AU10 H37 0520
    Serial number: 003EFD03PFXZ
    Coding: 30363435363030303030554A3052384B3053
    ASAM Dataset: EV_AirbaECUVWAUDI010 003010
    ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
    VCID: 41DF4E0E910D9193C0D-8014
    Crash sensor for side airbag: driver side:
    Serial number: 6334MSME4934411DC
    Front Passenger's Side Airbag Crash Sensor:
    Serial number: 6344MSME49636E35O
    Rear Side Airbag Crash Sensor (on driver's side):
    Serial number: 6352QSME5E321D04J
    Passenger side rear thorax airbag crash sensor:
    Serial number: 6362QSME12324E38F
    Crash sensor for front airbag: driver side:
    Serial number: 63732SME1F331234V
    Crash sensor for front airbag: front passenger side:
    Serial number: 63832SME10310502C
    Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
    Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
    Component: Lenks.Modul H16 0014
    Revision: -------- Serial number: 90304IFP00068
    Coding: 000017
    VCID: 3D2732FEED75F573A45-8068
    Component: E221 - MFL H02 0003
    Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 980 N HW: 8K0 920 980 N
    Component: KOMBIINSTR. H19 0253
    Revision: 00100000 Serial number: BXW54GR69
    Coding: 2F04100002002600010000
    Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
    Part No SW: 8T0 907 468 T HW: 8T0 907 468 K
    Component: GW-BEM 4CAN-M H09 0101
    Revision: EB700052 Serial number: 5200E0961381BB
    Coding: 00CF07
    VCID: 52FD714244EB1A0B697-8006
    Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
    Component: J367-BDM H07 0125
    Serial number: 00000000002790593780
    Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
    Component: J532_DCDCStab H14 0037
    Serial number: 09155000281021200180
    Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
    Part No SW: 8K0 959 793 J HW: 8K0 959 793 E
    Component: TSG FA H11 0306
    Revision: Serial number: 0000101390410
    Coding: 011002204001410001
    VCID: 47CB5016BFA9AFA30E9-8012
    Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0119349757
    Coding: 013B0622203904400020020400000000
    Shop #: WSC 06335 000 00000
    Subsystem 1 - Part No: 8K0 951 177
    Component: DWA-Sensor H02 0040
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H03 1301
    Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
    Part No SW: 8K0 959 792 J HW: 8K0 959 792 E
    Component: TSG BF H11 0306
    Revision: Serial number: 0000101389925
    VCID: 46D55D12B8A3B6ABF5F-8012
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
    Component: EPB Audi B8 H09 0090
    Revision: 00000003 Serial number: 00000000396795
    Shop #: WSC 00000 000 00000
    VCID: 343117DADE3F343B5BB-8060
    Address 56: Radio (R) Labels: Redir Fail!
    Part No SW: 4F0 035 056 B HW: 4F0 035 056
    Component: Radio U STD H45 0020
    Revision: AB001007 Serial number: 342F.097628645
    Coding: 010003020100000001
    VCID: 1F1BE87647B98763969-804A
    Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
    Part No SW: 8T2 035 666 D HW: 8T2 035 666 D
    Component: H-BN-EU H41 0047
    Revision: -------- Serial number: 475G.097511493
    Coding: 01010101000681EC01000B1C000000030001
    VCID: 3C213FFAF66FFC7B93B-8068
    Subsystem 1 - Part No: 8R0 060 884 E
    Component: EUR 2009/2010 5805
    Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
    Component: DU7 High H43 0306
    Serial number: 9356FJ091024044
    Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
    Component: E0380 Bedient H08 0100
    Serial number: 00000000310621
    Subsystem 4 - Part No: 8R0 906 961 A
    Component: CD-Database 1293
    Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
    Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
    Component: TSG HL H10 0306
    Revision: Serial number: 0000101419494
    Coding: 010002204001210001
    VCID: 42DD4102948B8A8BD97-8016
    Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
    Component: TSG HR H10 0306
    Revision: Serial number: 0000101419498
    End----(Elapsed Time: 01:28, VBatt start/end: 12.1V/12.0V. VIgn 12.0V)---
  3. Re: VCDS fault help. A4 Avant B8 2.0 TDCI
    May 2021
    South Yorkshire
    2nd log after new regulator and old sensor
    Code:
    Sunday,02,May,2021,11:51:07:17849
    Ross-Tech: Home
    VIN: WAUZZZ8K5AA028022 License Plate: LB09PFG
    Mileage: 253520km-157530mi Repair Order:
    VIN: WAUZZZ8K5AA028022 Mileage: 253520km-157530miles
    Revision: 25H20---
    1 Fault Found:
    5211 - Fuel Rail/System Pressure
    P0087 00 [167] - Too Low
    MIL ON - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 253519 km
    Date: 2021.05.02
    Time: 12:41:19
    Engine RPM: 2746.50 /min
    Normed load value: 99.6 %
    Vehicle speed: 44 km/h
    Coolant temperature: 69 °C
    Intake air temperature: 23 °C
    Voltage terminal 30: 14.120 V
    Unlearning counter according OBD: 80
    Fuel temperature: 30.2 °C
    Mean injection quantity: 72.29 mg/stroke
    Rail pressure regulation: status-Bits 0-7: 5
    Fuel high pressure: actual: 1.1067e+006 hPa
    High fuel pressure: specified value: 1.4273e+006 hPa
    PCV fac Adapt: 1.0005
    Com vol Fl Tnk Qnt: 4.00 l
    Readiness: 0 0 0 0 0
    Coding: 160504
    Revision: 00002001
    Coding: 031200
    Coding: 34340000
    Coding: 00F511
    Coding: 025028
    Coding: 000017
    Coding: 00CF07
    End----------(Elapsed Time: 01:42, VBatt start/end: 14.2V/14.3V
  4. Re: VCDS fault help. A4 Avant B8 2.0 TDCI
    130 Post(s)
    1972 Post(s)
    Is the sensor new genuine? Have you had the fuel system fully opened up or changed the fuel filter?
  5. Re: VCDS fault help. A4 Avant B8 2.0 TDCI
    Feb 2020
    Bradford
    40 Post(s)
    Check for good flow on the low side to the hpfp just to rule out
  6. Re: VCDS fault help. A4 Avant B8 2.0 TDCI
    Apr 2018
    N.Ireland
    9 Post(s)
    Hi, i have had some similar issue in the past with a different engine but may be related in nature. Intermittent low fuel pressure (P0087 - to low)
    MK7 Golf Estate '14 GT TDI CR150 DSG. Engine Mods: Stage 1, Rear Intake Trim
  1. Help with VCDS scan for EGR fault
    By Jon Eagland in forum VCDS - Help Requests
    Last Post: 14-07-2017, 10:56 AM
  2. My mates old focus tdci is quieter than mine
    By Ian9 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-11-2015, 10:55 AM
  3. help on vcds fault code please
    By danny851 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 17-10-2015, 01:13 PM
  4. Vcds fault code on azq?
    By domleadenham in forum VCDS - Help Requests
    Last Post: 17-09-2014, 09:26 PM
  5. First time Audi noob - Avant 2.0 tdci
    By tugglesf78 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 05-11-2012, 11:53 PM
