Thread: Radio upgrade - RNS510 - Help and Advice Please
  1. Radio upgrade - RNS510 - Help and Advice Please
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    Hi looking for some advice regarding the RNS510 radio / satnav compatibility.
    Are all the RNS510 radios compatible with a MK5 Golf (1K1)?
    I know I need to fit a:
    Bluetooth Module
    Compass
    GPS Antenna
    Reverse Camera (optional)
    Seen a few guides around but remember seeing a good somewhere which was very detailed. Anyone seen this anywhere?
    Is this radio DAB or just standard FM/AM? Or is it revision specific?
    1T0 035 680 B
    I know revision P isn’t a DAB RADIO.
    Are the maps preinstalled or do you need a CD to update them or SD CARD?
    Also know the car will need recoding using VCDS so I can activate everything.
    Also will need the code for the radio otherwise it won’t work.
    Any help would be appreciated to perform the upgrade.
    Thank you
  2. Re: Radio upgrade - RNS510 - Help and Advice Please
    Sep 2020
    Odense SV
    I can recomend RCD 330 with Apple CarPlay.
    Just connect your iPhone and it will use it's "Maps" and display on the screen.
    Fits well in MK5
  3. Re: Radio upgrade - RNS510 - Help and Advice Please
    Jul 2018
    8 Post(s)
    Ok thank you shall get hunting for a RCD330 (with radio code!).
    Does this radio also suffer from parasitic drain issues? Read a lot about the RNS510 causing issues.
  4. Re: Radio upgrade - RNS510 - Help and Advice Please
    Sep 2020
    Odense SV
    Quote Originally Posted by willdudeuk View Post
    You need to update the cars CANBUS with a new one + getting it coded.
    Then it wont drain the battery. Get this shorted the same day as installing the radio, then you will be good to go.
    I am 3 years later still happy with the RCD
  5. Re: Radio upgrade - RNS510 - Help and Advice Please
    Jul 2018
    8 Post(s)
    Ive got VCDS can I do it with that? Or is the CANBUS a module / part?
  6. Re: Radio upgrade - RNS510 - Help and Advice Please
    Sep 2020
    Odense SV
    You need to change the gateway/CANBUS to a new updated version and copy the cars old codes over to the knew.
  7. Re: Radio upgrade - RNS510 - Help and Advice Please
    Nov 2013
    west midlands
    You will need the radio code yes
    A lot of stereos will work with the mark 5 golf but some are limited to not supporting steering wheel controls
    The 510 does come with dab and Bluetooth built in as well so easier to get all in
    My old golf has a rns315 out of a Tiguan fitted only thing you can’t do is use steering wheel controls
    I fitted a dab aerial and gps aerial and worked out or the box (with code)
    Never had any drain issues in last 8 months
  1. RNS510 Upgrade software
    By mike6265 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-10-2019, 09:20 PM
  2. VW EOS RNS510 Telephone prep upgrade
    By Hypnoman in forum Retrofits
    Last Post: 02-11-2018, 11:40 PM
  3. RNS510 Poor Radio Recpetion - Golf Mk6
    By ½cwt in forum In Car Entertainment
    Last Post: 10-05-2018, 05:36 PM
  4. Question VW RNS510 advice
    By Napier in forum In Car Entertainment
    Last Post: 17-07-2016, 08:13 PM
  5. RNS510 upgrade
    By BobbyBrown in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-04-2015, 12:26 PM
