Thread: Golf Mk5 ABS & traction control lights on
  1. Golf Mk5 ABS & traction control lights on
    Jan 2021
    solihull
    I am new to this site as I have just got a mk5 golf 2.0 diesel
    It has the ABS and traction control lights on. I have plugged in my diagnostics but nothing comes up, only faults for glow plugs which I will check tomorrow.
    my diagnostics is only a cheap scanner so may not pick it up ???
    Are there any common faults with ABS / Traction control
    Nick
  2. Re: Golf Mk5 ABS & traction control lights on
    Nov 2020
    HARROW
    faulty wheel speed sensors can cause this problem.are you a competent diy person to tackle this job ?
    its not that difficult to repair but first you need a proper scan to detect which sensor is bad.maybe your scanner is
    a very basic one which does not come up with the goods
  3. Re: Golf Mk5 ABS & traction control lights on
    May 2009
    I had the same problem and it was a faulty wheel speed sensor. However, this had been caused by a failed wheel bearing, so check the bearing before replacing a faulty sensor.
  4. Re: Golf Mk5 ABS & traction control lights on
    131 Post(s)
    1973 Post(s)
    If the ESP light is on as well as the ABS, a common fault is the G201 pressure sensor inside the pump, there is an official repair kit for the problem.
  1. ABS, Glow plug, Traction control lights Flashing and no brake lights
    By bbq365 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-02-2011, 06:15 PM
  2. ABS and Traction control warning lights
    By garethl in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-12-2009, 01:20 AM
  3. ABS and Traction Control Lights.
    By Connor in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-12-2008, 08:41 PM
  4. abs and traction control lights on
    By mossi in forum TT - 8N Forum - 1998 - 2006
    Last Post: 29-09-2008, 10:48 PM
  5. epc & traction control warning lights
    By janfab in forum Fabia
    Last Post: 09-08-2007, 10:00 PM
