Thread: Mysterious CAYC problem
Page 1 of 3 123 LastLast
Results 1 to 10 of 28
  1. Mysterious CAYC problem
    Jan 2014
    France
    Hi all and Happy New Year
    I am hoping that someone will be able to help me with a problem that I have with my sons SEAT Leon II 2010 1.6 tdi ecomotive VW/Audi CAYC engine.
    A couple of weeks ago the car cut out for no apparent reason but started again after switching ignition off for a few seconds. The next day it did the same and started again after same procedure. The next day it did it again, started again but would only run in limp mode.
    Now it will not start at all, although now and again it will fire up, run really rough for a few seconds and cut out.
    The strange thing is that the management light is only showing during the few seconds of rough running.
    I ran a diagnostic even though there was no management lights on and it came up with P228D00 – FUEL METERING VALVE, CONTROL VARIATION – PRESSURE TOO HIGH N- PERMANENT. I cleared the fault and it hasn’t shown itself since which makes me think that it could be an old one.
    I run diagnostic and it only comes up with 001D38 – Unknown fault code. I don’t have access to a proper VCDS unfortunately.
    Other than that the management lights do not light.
    Anybody got any ideas please?
    Much appreciated
  2. Re: Mysterious CAYC problem
    116 Post(s)
    1879 Post(s)
    Has it had a fuel filter recently? You need a proper VAG specific code read.
  3. Re: Mysterious CAYC problem
    Jan 2014
    France
    Hi, thanks for your reply.
    Yes It had one last January and I have just replaced it again to eliminate it from this problem.
    I know I need a proper VAG diag but I dont have access to one here (I am in France). The main ******** and garages here are worse than in the UK!!! Are they expensive to buy?
    Thanks again
  4. Re: Mysterious CAYC problem
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    " Now it will not start at all, although now and again it will fire up, run really rough for a few seconds and cut out. "
    Try blanking off the EGR at the front of the engine where access is easy & see if it will start.
    The engine will run in lip mode blanked off, but it might point you in the right direction.
    EGR sticking open will stifle the engine from running.
  5. Re: Mysterious CAYC problem
    116 Post(s)
    1879 Post(s)
    If you don't have a diagnostic system, how did you bleed the fuel system for 2 minutes after the new fuel filter?
  6. Re: Mysterious CAYC problem
    Jan 2014
    France
    Thanks for that. I will give it a go
    cheers
  7. Re: Mysterious CAYC problem
    Jan 2014
    France
    Thanks again
    I do have a diagnostic but it isnt a proper VAG one. Its one of these Delphi multi make things.
    If I go in via VW golf with CAYC engine it lets me operate components. Thats how I bled it.
    Could do with a VAG as I have several VW/Audi/SEAT vehicles.
  8. Re: Mysterious CAYC problem
    116 Post(s)
    1879 Post(s)
    Good, I was concerned you had not bled it and just fired it up the way we all used to.
  9. Re: Mysterious CAYC problem
    Jan 2014
    France
    What diagnostic kit do you guys normally use?
  10. Re: Mysterious CAYC problem
    116 Post(s)
    1879 Post(s)
    VCDS is the ideal system for DIY right up to professional specilsist use, the only system that can do more is the dealers ODIS which is appallingly slow, clunky and difficult to get access to. Only buy VCDS direct from Ross-Tech: Home or from one of their appointed UK distributors, beware of illegal dongles.
    U.K.:
    Gendan Limited
    Unit 8 Llys Caer Felin
    Felinfach
    Swansea SA5 4HH
    +44 0 1792 588002
    ilexa Onboard Diagnostics
    Truro
    Cornwall
    TR2 4YF
    p: +44 01726 884 010
    email: support@ilexa.co.uk
    Marshall's Industrial Ltd.
    Volkswagen Power Systems & Components
    IMPCO Gas Systems
    Beadle Estate
    Hithercroft Road, Wallingford,
    Oxfordshire, UK
    OX10 9DG
    p: +44 (0) 1491 834666
    f: +44 (0) 1491 839777
    email: sales@mi-uk.com
    V-Tech UK Ltd.
    SN Autohaus
    181 Forest Road
    Hainault, Essex
    London, UK IG6 3HZ
    Tel: +44 208 498 1288
    Fax: +44 208 498 1289
  1. 1.6 CAYC rough idle
    By lightbreeze in forum Golf MK6 - 2009 - 2013
    Last Post: 13-11-2020, 12:04 AM
  2. Mark 6 1.6 TDi DSG - CAYC engine - EGR
    By DSJ in forum Golf MK6 - 2009 - 2013
    Last Post: 27-08-2020, 11:43 PM
  3. CAYC 1.6 tdi diesel engine. Unresolved EGR problem.
    By nickbell1uk in forum Golf MK6 - 2009 - 2013
    Last Post: 10-10-2017, 04:55 PM
  4. Mysterious Brake Problem!
    By FWB in forum Golf MK6 - 2009 - 2013
    Last Post: 20-12-2016, 10:28 AM
  5. Serious and mysterious engine problem.
    By The Jeep in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-02-2011, 07:06 PM
