Thread: 00003 Control Module: No or Incorrect Basic Settings
  1. 00003 Control Module: No or Incorrect Basic Settings
    Dec 2020
    Europe
    Hello. I bought a Audi A6 C6 2007, which had a non-working MMI Joystick Board, which resulted in MMI starting for few seconds and then auto shut down. I replaced the Joystick Board, now the MMI works fine but the steering wheel buttons does not work at all. The steering wheel buttons are lighted up, I tested with a vcds(In steering wheel module) and all buttons are functional, but still...I cannot use them, they don`t work with MMI. Also, I scanned with vcds and I got the error from the image. How could I solve this problem? How can I code the 00003 Control Module? Thank you and sorry for my damaged english, I am from Europe.
  2. Re: 00003 Control Module: No or Incorrect Basic Settings
    Jul 2013
    76 Post(s)
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: 00003 Control Module: No or Incorrect Basic Settings
    Dec 2020
    Europe
    Quote Originally Posted by dan2485 View Post
    Thanks for the reply. I looked at that page, but could not figure out how to code..
    Audi A6 (4F) Control Head Front (High) - Ross-Tech Wiki
    I acceessed channel 001, but Where I enter this code :
    • +04096 = Multi-Function Steering Wheel installed (PR-1XW) ?
  4. Re: 00003 Control Module: No or Incorrect Basic Settings
    Jul 2013
    76 Post(s)
    Ross-Tech: VCDS Tour: Adaptation
    In chanel 001 press the read button then add 04096 to the value in the new value box and press test.
    Remember to write down the original value to if this does not work so that you can set it back.
    If test is ok then click the save button and check the fault codes and reset them.
    Dan
  5. Re: 00003 Control Module: No or Incorrect Basic Settings
    Jul 2013
    76 Post(s)
    I hope that you are well and safe, did you get your issue sorted?
    Dan
  1. AUdi A5 Steering assist basic settings and control module issue
    By mazz in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 17-06-2020, 06:13 PM
  2. Please Help Old how can I do basic settings dsg ocw
    By maoyekanmi in forum 2.0T, TSI and TFSI - Engine
    Last Post: 27-11-2017, 05:54 PM
  3. Please Help A4 B8 DPF Fault P2452 No or Incorrect Basic Setting / Adaptation - Help Required
    By Mickyd98 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 09-04-2012, 08:26 PM
  4. TT dsg basic settings
    By Jimmy2scoops in forum VCDS - Help Requests
    Last Post: 17-06-2009, 09:46 PM
  5. Basic Settings On Vag Com
    By cyberduderen in forum VCDS - General Questions
    Last Post: 31-01-2008, 12:03 AM
