Thread: Multiple simultaneous electronic problems 2006 Sharan 1.9TDI Sport
  1. Multiple simultaneous electronic problems 2006 Sharan 1.9TDI Sport
    Dec 2020
    Newry
    Hi Guys
    New member here, was wondering if anyone has encountered this problem and maybe its a simple fix, any help is much appreciated.
    2006 Sharan 1.9 TDI
    so the car drives great and does not get abused, reg services etc. has served me great so far.
    Last week as i was backing out I felt something in my break peddle very briefly, just as that happened multiple electronics failed and lights on on the dash, no horn, no blower or even its lcd display, no indicators (hazards still good) fuel needle reading false empty, ABS light permanently on, parking brake light flashing,
    Have tried disconnecting battery to reset... no good
    Got a friend with computer to read faults... the following came up, 5 faults, 4 remained after reset/clearance
    Any help is much appreciate, if i end up taking this to garage it could be quite expensive and not worth fixing as the car is not worth a lot, have a feeling its something simple, my mate with the computer suggested starting with ABS pump /connectors
  2. Re: Multiple simultaneous electronic problems 2006 Sharan 1.9TDI Sport
    Feb 2020
    Bradford
    40 Post(s)
    I suspect ignition switch internal fault.
  3. Re: Multiple simultaneous electronic problems 2006 Sharan 1.9TDI Sport
    Dec 2020
    Newry
    Hi Roverfan,
    thanks for the reply, I am still no further, have been chatting with my mechanic today who thinks it may be the abs pump/ecu moduale. what makes you think ignition switch?
  4. Re: Multiple simultaneous electronic problems 2006 Sharan 1.9TDI Sport
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    You had multiple electrical failures together, including the ABS.
    So I would agree with Roverfan, it could well be the ignition switch, or some other wiring or fusebox problem.
    Have you checked the engine bay fuse box for any sign of heat problem or water ingress.
  5. Re: Multiple simultaneous electronic problems 2006 Sharan 1.9TDI Sport
    Feb 2020
    Bradford
    40 Post(s)
    Quote Originally Posted by Marty20 View Post
    Hi Roverfan,
    Since the problems occurred at the same time we can assume that there is one cause. In such situations its best to go after the easiest circuit and during the course of that repair the culprit to all the other problems should be found.
    Although I did suspect the ign switch, it could be something else but personally I'd ignore the abs fault codes for now.
    What you need to do is have the easiest circuit looked at - I'd say the horn.
    Edit:sorry forgot to answer the question! The things you mentioned are all switched on with ign on. That is the reason for suspecting the ign switch, it is the potential common component of all the faults.
  1. Please Help Sharan Electric Problems (1.9tdi 130)
    By Witty in forum Touran - Sharan - Caravelle
    Last Post: 15-02-2011, 05:28 PM
  2. 2006 A3 1.9tdi Sport - Clutch Help
    By feroz28 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-12-2010, 10:29 PM
  3. Vw sharan sport 1.9tdi parking sensors
    By ally21 in forum Touran - Sharan - Caravelle
    Last Post: 11-12-2008, 03:36 PM
  4. ***Fix fo many 2001 Sharan 1.9Tdi problems***
    By ferrispedro in forum Touran - Sharan - Caravelle
    Last Post: 24-05-2008, 11:45 AM
  5. VW Sharan 1.9tdi sport 2001
    By chalkmyster in forum Touran - Sharan - Caravelle
    Last Post: 25-09-2007, 02:44 PM
