Thread: Error p0238, p0113 cffb
Results 1 to 10 of 11
  1. Error p0238, p0113 cffb
    Dec 2020
    Morocco
    i'm new to this forum already checked some post about error p0113 and p0238 and tried some solution suggested by members, here is my problem, i got the preheating spin wire blink on dashboard and lose acceleration on my Passat b7 2.0 4motion diesel, CFFB motorisation, when i make a diagnostic using thinkcar i got the two error:
    P0113 : Intake Air Temperature Sensor 1 Circuit High
    P0238 : Turbocharger/ supercharger Boot Sensor A Circuit hight
    for information i already changed the Air Mass Sensor an got Bosch one reference 0 281 002 956 as i supposed that the Intake Air Temperature Sensor 1 is in this part (correct me if i'm wrong) cleared the errors and then make testing, boom the 2 errors still there even if the part Air Mass Sensor is new one, checked the wire everything seem ok i logged the Intake Air Temperature Sensor 1 from time to time i got -40 degree C it flash sometime but not constant it varies between the reel value and the minus value.
    i mesured the Turbocharger/ supercharger Boot Sensor using multimeter engine on and connector connected to the sensor, on pin 1 i got 12 volt and on the pin 2 i got value which varies between i guess 3 volts to 7.30 volt according to acceleration is that normal ?
    cannot mesure the value on the Air Mass Sensor as the pins are difficult to get when connected.
    Do i have to change the Turbocharger/ supercharger Boot Sensor which reference is 7.00868.02.0 it has 3 hoses connected
    below are the diagnostic report
    Also the video recording of sensor when driving to check the intake temperature sensor which flash -40 degree c sometimes
    Any suggestion what can cause this problem and how to resolve it?
    Thank You in advance
  2. Re: Error p0238, p0113 cffb
    Feb 2020
    Bradford
    40 Post(s)
    Check wiring harness. Could be a short circuit causing the reading
  3. Re: Error p0238, p0113 cffb
    Dec 2020
    Morocco
    I'm i supposed to check this connector i still have doubt if the IAT (Intake Air Temperature sensor) is integrated with the Mass Air Flow Unit!
  4. Re: Error p0238, p0113 cffb
    Feb 2020
    Bradford
    40 Post(s)
    Quote Originally Posted by jachkoune View Post
    Air temp sensor is built into the Map/charge pressure sensor, the pictured item is the Mass Air Flow sensor. A brief look online suggests 03G906051E is the part number, double check with supplier before buying.
    Visually inspect the loom for rub through or signs of damage to the wires. It could be the sensor itself and not a wiring fault but ideally I would eliminate the wiring as a potential cause before buying.
  5. Re: Error p0238, p0113 cffb
    Dec 2020
    Morocco
    I struggle to find that part 03G906051E in my engine still didnt find it where is located?
    is it in my case this part ? This part has 3 hoses one coming from the admission the second going to EGR and third to turbo
  6. Re: Error p0238, p0113 cffb
    Feb 2020
    Bradford
    40 Post(s)
    Those pictures are of a vacuum valve.
    The map sensor is on the large air pipe after the intercooler and before the throttle body. It measures the air temperature and air pressure in this intake pipe
  7. Re: Error p0238, p0113 cffb
    Dec 2020
    Morocco
    My engine look like this one, in which part i will look for ?
  8. Re: Error p0238, p0113 cffb
    Feb 2020
    Bradford
    40 Post(s)
    Its between the engine and the radiators. About where the oil dipstick is but lower down. Best accessed from underneath the car.
    Follow the large air pipe down from the throttle body (which is the silver part, to the right of the oil dipstick in the picture)
  9. Re: Error p0238, p0113 cffb
    Dec 2020
    Morocco
    Ok i will have a look tomorrow and give a feedback thanks for the help
  10. Re: Error p0238, p0113 cffb
    Feb 2020
    Bradford
    40 Post(s)
    The loom is best viewed from underneath as well. Once you find the sensor follow the wiring back visually especially where it touches other parts metal in particular.
  1. Question Some error codes and throttle body Train/update 2.0 TDI CFFB
    By Laher1992 in forum Golf MK6 - 2009 - 2013
    Last Post: 23-05-2020, 02:27 PM
  2. Error codes p0299 and p0113
    By arreff77 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-10-2019, 08:58 AM
  3. Please Help Golf MK6 ANNOYING CODES P0113 P0238
    By Golfmk6code in forum Golf MK6 - 2009 - 2013
    Last Post: 31-05-2018, 08:13 AM
  4. Replies: 12
    Last Post: 13-04-2017, 08:34 AM
  5. Fault P0238, P1556, P1103, P1136, P0011
    By *1.8 T Quattro* in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-04-2011, 06:35 PM
