Thread: Steering wheel won't lock
Results 1 to 9 of 9
  1. Steering wheel won't lock
    Feb 2015
    bedford & england
    Hi All,
    Sorry if this has been covered before, but I have issue with steering wheel not locking when car is switch off and parked, car still starts and drives as normal. When I put the key in ignition it doesn't make noise when the key goes in anymore not sure what the issue is, any suggestions would help please.
  2. Re: Steering wheel won't lock
    Feb 2015
    bedford & england
    Hi all,
    Anyone able to i'm
  3. Re: Steering wheel won't lock
    Jul 2008
    Lisburn
    16 Post(s)
    the steering lock is on its way out - there is a few posts on here about it - one about a road side repair.
    Mine does it once and a while - you pull the key out and the lock does not activate, i shove the key in and out a few times to get it to go.
    to me there seems to be a door the key opens, and it has got weak, not closing on removal.
    must be a micro switch or something fitted to that. maybe a spray with an aerosol duster - or, i havent been brave enough yet, a small squirt of d-40? i mean small dont want to soak or get it where it will do more damage...
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  4. Re: Steering wheel won't lock
    Feb 2015
    bedford & england
    Thanks, i'll try some electrical contact cleaner to see if that work, if not i'll get someone to fix it, have seen someone on ebay who can do this.
  5. Re: Steering wheel won't lock
    Jul 2013
    76 Post(s)
    It helps if you add the details of your car ie year/ engine type/ gearbox type.
    Your problem could be one of 6 things.
    1. The E415 (ignition switch) has a broken cam.
    2. The E415 has a broken Micro switch.
    3. The J518 (Entry and start authorisation control unit- on the steering column) has broken relay or microswitch. Kits can be bought on Ebay if your handy with a soldering.
    4. The wiring between the E415 module to the J518 module is damaged.
    5. The solenoid in the J518 module has failed. This would the easiest fix if you could get a working solenoid (not the hardest this to source).
    6. Either modules have a damaged PCB.
    Electrical Cleaner will not solve your issue. Be wary of spraying on PCB's and not drying it correctly could be an expensive mistake.
    Dan
    2009/2010 2.0 TDIe SE
  6. Re: Steering wheel won't lock
    Feb 2015
    bedford & england
    Hi, My car is a 2006 A6 2.0 tdi s line bre engine 6 speed manual, can any of these faults be picked up on a OBD/VCDS scanner?
    thanks for the reply..
  7. Re: Steering wheel won't lock
    Jul 2013
    76 Post(s)
    A VCDS scan should throw up a fault.
    It may only show an implausable signal fault.
    There are codes for when the car stops the starting function.
    google it.
    Dan
    1 1 0
  8. Re: Steering wheel won't lock
    Jul 2013
    76 Post(s)
    Why the dislike?
    Dan
  9. Re: Steering wheel won't lock
    Feb 2015
    bedford & england
    Sorry mate i pressed the dislike button error, really appreciate the advise.
  1. Steering wheel lock
    By Braehead in forum Q7 - 4M Forum - 2016 -
    Last Post: 23-08-2019, 09:25 AM
  2. Please Help Passat B6 Steering wheel lock not going off
    By hatton101 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-01-2016, 01:59 PM
  3. Replies: 1
    Last Post: 28-02-2015, 12:31 PM
  4. Please Help ***BREAKDOWN*** Red Steering Wheel Light & 3 Beeps. No Steering/Steering Locked
    By Stuart_B in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 03-10-2013, 11:00 PM
  5. Steering wheel lock on an GT MFD wheel?
    By rgarner in forum Golf MK6 - 2009 - 2013
    Last Post: 10-08-2009, 09:49 PM
