Thread: Polo 9N 1.2 with misfire fault code 16556 VCDS
  1. Polo 9N 1.2 with misfire fault code 16556 VCDS
    Jun 2006
    6 Post(s)
    I am getting a severe misfire about 30 odd seconds into a journey and last about 20 seconds before clearing completely. This only happens once in 20 odd trips in the car. Curiously the misfire disappears when I press the clutch pedal while revving or drop to a smaller gear (to reduce load). VCDS is showing 16556 fuel trim bank 1 PO172 - 35 - 10 system too rich intermittent. Some people have suggested the lambda sensor but Ross-Tech wiki is suggesting a number of other fuelling issues.
  2. Re: Polo 9N 1.2 with misfire fault code 16556 VCDS
    131 Post(s)
    1973 Post(s)
    I would replace the pre cat lambda sensor first, they are a life limited service component.
  1. Replies: 2
    Last Post: 27-10-2018, 08:58 PM
  2. Question fixed 1796 but now misfire cylinder 3 fault code
    By vwnewbie in forum VCDS - Help Requests
    Last Post: 29-07-2018, 06:05 PM
  3. Polo 1.2 (3cyl) Petrol, Intermittent Misfire - Code - P0302
    By robtherevelator in forum Polo - Derby - Lupo - Fox
    Last Post: 21-09-2016, 07:24 PM
  4. help on vcds fault code please
    By danny851 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 17-10-2015, 01:13 PM
  5. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
