Thread: A3 cabriolet 1.6tdi 2011 window regulator
  1. A3 cabriolet 1.6tdi 2011 window regulator
    Jun 2019
    shawforth
    Hi, i am looking in to changing my passenger front regulator,i have sourcedone but cant find how to remove..
    I haveseen a few tutorials on a A3 standard car with a frame butnon for the A3 convertible ,i have taken the door card off along with the motor but cant find were the bolts are tat should connect to the regulator ,any help would be appreciated ,Thanks
  2. Re: A3 cabriolet 1.6tdi 2011 window regulator
    Jan 2016
    italy
    Quote Originally Posted by den9112 View Post
    Hello i have a situation with audi a6
    Horn work ok light in steering wheel work but buttons for mmi dont work how can
    I solve maybe need any coding or configuration
    Sent from my SM-J415F using Tapatalk
  3. Re: A3 cabriolet 1.6tdi 2011 window regulator
    Aug 2007
    Derbyshire
    I did a driver's side one earlier this year, 09 cabrolet which I assume is the same. If I remember correctly, two bolts at the top and then two mounts into the bottom of the door with odd 'spring-clip' type fastenings. Wasn't too difficult once I'd figured out how they worked. I'll see if I took any pics.
  4. Re: A3 cabriolet 1.6tdi 2011 window regulator
    Aug 2007
    Derbyshire
  5. Re: A3 cabriolet 1.6tdi 2011 window regulator
    Jun 2019
    shawforth
    Hi thanks for the reply any info you may have (photo) would help.Thanks
  6. Re: A3 cabriolet 1.6tdi 2011 window regulator
    Aug 2007
    Derbyshire
    I could only find those pics. The bottom fixing with the spring allows the adjustment to get it perfectly lined up - sorry, can't remember exactly how!
  7. Re: A3 cabriolet 1.6tdi 2011 window regulator
    Jun 2019
    shawforth
    Thanks for the help, i havetaken the door card off and managed to find two torx bolts behind a grommet couldn't find any at the bottom although the spring clip type fitting would make sense here ,i take it after the two torx bolts it pull up and out
  1. Question Drivers window regulator A4 cabriolet
    By leebarkshire in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 04-02-2017, 06:59 PM
  2. Please Help 2012 A3 cabriolet window regulator
    By Darren Ryan in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 10-05-2016, 08:20 PM
  3. Question Help Please with A4 Cabriolet window regulator
    By shadieb in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-06-2012, 08:04 PM
  4. Please Help Window Regulator 2002 Cabriolet
    By Phil Tur in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-09-2010, 08:37 PM
  5. VW Golf cabriolet mk4 o/s window regulator
    By gklute in forum Golf MK4 - 1999 - 2004
    Last Post: 06-03-2008, 10:42 PM
