Thread: Air Con not working - Fault Code U111300
  1. Air Con not working - Fault Code U111300
    Jul 2007
    Co Durham
    The air-conditioning (4 zone climate control) in my Allroad isn't working. The fault code brought up on a scan is U111300 - Function limitation due to incorrect value received
    Has anybody else had that problem? Thanks
  2. Re: Air Con not working - Fault Code U111300
    May 2013
    I had AC failure earlier this year on my 63 plate A6. I don’t recall the fault code but the error description was the same. In my case I either had a broken compressor leading to the failure or the system didn’t have enough pressure.
    I went to a kwik fit owned garage that did a AC recharge for about £60. I used them, because if it doesn’t work after the recharge, or fails again soon after they don’t charge or refund.
    In my case, I just needed the recharge and my ac worked again. I’ve had the car from new, it’s the first time I had this problem.
    A6 Avant S-Line BiTdi | born Sept '13 | advanced tech pack | sports diff | privacy glass | 75l fuel tank | lighting pack | HB assist | rear cam
    Q5 S-Line Plus TFSI | born April '11 | tempted to add stage 1 Revo taking HP from 177 to 290.
  3. Re: Air Con not working - Fault Code U111300
    130 Post(s)
    1972 Post(s)
    What are you using to read the codes?
  1. P1641 Fault Code + Fans not working (to cool or for AirCon)
    By DannyBoyGolf in forum Golf MK5 - 2004 - 2009
    Last Post: 03-03-2016, 04:00 PM
  2. Question Cruise stopped working but no fault code
    By arnieboy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-12-2015, 08:47 PM
  3. Cruise control malfunction / fault code U111300
    By evenkg in forum Golf MK6 - 2009 - 2013
    Last Post: 29-06-2015, 03:03 AM
  4. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
