Thread: Possible overheating, common problem?
  1. Possible overheating, common problem?
    Sep 2020
    Somerset
    Hello, my 2013 2.0 TDI 170 has been running just fine since I bought it about a week ago but after a 10 minute drive to the shops a couple of days ago (at speeds not exceeding 30mph) I noticed a very hot smell after I parked up and got out. I assumed it was somebody else's car in Tesco car park so thought no more of it, however I noticed the smell again when I got home and then realised that the 2 radiator fans were running full speed even with the keys out. There was no warning message inside the car and the temperature guage wasn't showing anything unusual. I opened the bonnet and there was a huge amount of heat under there, coming from the exhaust/turbo area at the back of the engine, along with a very hot smell. It wasn't a hot day, about 15 degrees outside. Coolant level and oil level were fine. After it cooled down I drove it again and it did not get anywhere near as hot and the fans didn't kick in. I think it's happened once or twice since, usually on short journeys. I've Googled around a bit and had a look through previous threads on this forum and it looks like there were issues with some of the water pumps on some of the TDI engines. Do the symptoms I've described sound like it could be a water pump issue? Or something else (like the thermostat maybe?).
    Thanks,
    B@rnstormer
  2. Re: Possible overheating, common problem?
    Feb 2020
    Bradford
    40 Post(s)
    Almost certainly dpf regen, nothing to worry about if not accompanied by any other symptom. If these trips are your most common use of the car a longer drive (1/2 hour motorway run) may be required. Stop start driving with lots of overrun where engine output is minimised is not ideal for dpf regen.
    What the engine management system is doing is increasing the temperature inside the dpf so the soot particles are burned off. A clear run is perfect to complete a regen but it can't complete it in excessive stop start conditions, so it tries again.
    1 1 0
  3. Re: Possible overheating, common problem?
    Sep 2020
    Somerset
    That's great to hear and has saved us a lot of worries, many thanks Roverfan. I've read about that somewhere before but as our old car didn't seem to have a DPF I'd forgotten all about it! Very well explained as well, I shall see to it that it gets regular long-ish runs (not sure what the previous owner did with it obviously).
    Cheers,
    B@rnstormer
    Quote Originally Posted by Roverfan View Post
  4. Re: Possible overheating, common problem?
    Sep 2020
    Somerset
    Quote Originally Posted by B@rnstormer View Post
    Cheers,
    B@rnstormer
    A quick update on this one, there were ongoing problems with the car performing a DPF regen and it eventually kept going into limp mode when under load. Ultimately there was damage to the turbocharger which then required replacing. Fingers crossed we've had no further issues with it but I'm still not 100% confident that everything's as it should be. I don't think the previous owner did many long journeys in it so it probably spent its first 60,000 miles doing short trips and not properly cleaning its DPF.
  5. Re: Possible overheating, common problem?
    131 Post(s)
    1973 Post(s)
    We have had a lot o this with the Shalambra 2 where people think an boost issue is the turbo when in fact it is a blocked SCR unit under the floor, this gets blocked due to the reductant injector dribbling and forming urea crystals in the SCR unit as this cannot be cleaned out, it has to be replaced..
  1. Replies: 0
    Last Post: 22-08-2019, 10:01 AM
  2. Common oil light problem
    By bigbroony in forum Scirocco - Corrado
    Last Post: 06-03-2011, 07:42 PM
  3. Common problem ? - the car ( & me ) just not getting warm
    By hollo in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 10-02-2010, 03:42 AM
  4. Question Faulty Gearbox, or just common problem?
    By thomascy in forum Golf MK5 - 2004 - 2009
    Last Post: 18-09-2009, 08:19 PM
  5. Golf mk3 gearbox problem (probably common)
    By Basscrazy in forum Golf MK3 - 1993 - 1999
    Last Post: 22-08-2007, 09:54 AM
