Thread: Help will a s3 hpfp fit a golf gti mk5?
  1. Help will a s3 hpfp fit a golf gti mk5?
    Oct 2016
    birminghan
    hi i can not find a new high pressure fuel pump with the banjo all i can find is the barb fitting does anyone know if i remove the barb fitting will the banjo fit in cheers
  2. Re: Help will a s3 hpfp fit a golf gti mk5?
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    There's commonality in the pump part codes like 06F127025J (and others at various points in time), paired on the AXX with banjo fitting and BWA with barb which thread in. So good chance it'll work unless the specific pump doesn't have the interchangeable connection point.
  3. Re: Help will a s3 hpfp fit a golf gti mk5?
    Oct 2016
    birminghan
  4. Re: Help will a s3 hpfp fit a golf gti mk5?
    131 Post(s)
    1973 Post(s)
    I have swapped them over, it is easier than the modification to the later fitting.
  1. Important HPFP failures?
    By dweisel in forum Jetta MK3 - 2005 - 2013
    Last Post: 03-02-2017, 03:05 PM
  2. Please Help 1.6 FSI HPFP cam follower problem !
    By djweeble in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-07-2015, 06:13 AM
  3. Question Signs of a dying HPFP?
    By Samuel Masini in forum Golf MK6 - 2009 - 2013
    Last Post: 24-02-2015, 08:25 PM
  4. Attention 2.0L FSI and tFSI HPFP Cam follower threads
    By RichardSEL in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-11-2013, 09:49 AM
  5. upgraded HPFP new
    By bez101 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 11-06-2010, 12:10 PM
